Hammer Hangers® by Archive Garage 2005-2023 Tacoma Shackle Hangers
Discussion in 'Archive Garage' started by ARCHIVE, Nov 13, 2017.
  1. Apr 20, 2021 at 8:01 AM
    #2741
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Every inch matters so the girls tell me
    dumontrider likes this.
  2. Apr 20, 2021 at 8:12 AM
    #2742
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    FIFY
  3. Apr 20, 2021 at 10:44 AM
    #2743
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    You want bump travel... buy my shackles and go SUA. That’ll free up bout 3 inches of the stuff. :evil:
  4. Apr 20, 2021 at 11:10 AM
    #2744
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Not to be contrary, just to drop some truth.
    The bump travel between a 3" lifted SOA spring and 1" lifted SUA setup is negligible or equal, and SUA has compromises in handling, ground clearance, cost and labor, and axle wrap, that's right, SUA conversion on the Tacoma has more axle wrap than a good SOA spring. All about the geometry and direction the front spring eye pushes on the front hanger to push the truck.
    I starting working on a pros/cons/facts between SOA and SUA, coming soon
    dumontrider and H3llRid3r like this.
  5. Apr 20, 2021 at 12:55 PM
    #2745
    Chadr7858
    Chad
    Colorado
    Bump travel and usable travel is way more important for me than an extra inch for the gram, but the more of both the better. Maybe I'll make a lover shackle to try out. I already cylce a lot of travel and am quite honestly being greedy for no reason other than I can't not tinker.
  6. Apr 20, 2021 at 1:06 PM
    #2746
    Dean62
    Dean62 Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    will the hammer hanger still be worth it if I only use stock leaf springs with an add a leaf on some fox 2.0 resi shocks
    I see most of you have the shock relocate kit just not sure how much of a difference it will make
    has anyone also fabricated their own crossmember with archive build your own kit so that you can keep the factory spare location? If possible i was thinking of going around the spare or tying into the stock hitch receiver
  7. Apr 20, 2021 at 1:13 PM
    #2747
    ARCHIVE
    Eric
    Hh are about way more than droop
    They will make a noticeable difference in ride quality, handling and big increase in durability. Check out the posts by @greenEFSI in this thread, impressive droop with stock +AAL, but he has long shocks in stock location that by my math would probably limit bump travel, but he does rock stuff so probably not intrusive
    You can't make a cross tube that works with spare tire under and bolts to inboard side of Hh
    greenEFSI and H3llRid3r like this.
  8. Apr 20, 2021 at 1:20 PM
    #2748
    Dean62
    Jacob
    Florida Panhandle
    I have the somewhat extend travel rear shocks at 9.1" FOX-985-26-117 for lift from 0-1.5"
  9. Apr 20, 2021 at 1:32 PM
    #2749
    ARCHIVE
    Eric
    Those will limit droop ~1.5-2" inches with stock springs and 3"+ with aftermarket springs
  10. Apr 20, 2021 at 1:42 PM
    #2750
    Dean62
    Jacob
    Florida Panhandle
    Are they a bad shock to have with the HH? do I have to worry about over extending the shocks?
    Should I have gone with the 9.6" for 2"-3" of lift FOX-985-26-118?
    how much off a difference will adding the poly bushings with stock shackles make?
  11. Apr 20, 2021 at 2:43 PM
    #2751
    ARCHIVE
    Eric
    Not bad with Hh, those 9" are limit with stock hangers probably. Run straps if want.
    Why do poly bushings when your shocks are the limit?
    H3llRid3r likes this.
  12. Apr 20, 2021 at 3:26 PM
    #2752
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Got my HH in last week and they are BEEFY! Thanks, Eric!
    Should I be running them in “stock” or “droop” position with Dakar leaf packs on a 2nd gen?
    Edit: Nevermind...after a beer I now understand how the mounting positions differ. The hanger slides forward for the “stock” position.
    ARCHIVE[OP] likes this.
  13. Apr 20, 2021 at 9:17 PM
    #2753
    OrangeCrash
    OrangeCrash Well-Known Member
    Kingman, Az
    I'm having someone install this for me, are there any written instructions?
  14. Apr 20, 2021 at 11:10 PM
    #2754
    OrangeCrash
    Kingman, Az
    whatstcp[QUOTED] likes this.
  15. Apr 21, 2021 at 4:34 AM
    #2755
    ARCHIVE
    Eric
    Yes, included in box (usually), can email as well
  16. Apr 21, 2021 at 5:37 AM
    #2756
    Dean62
    Jacob
    Florida Panhandle
    would these have been a good set of stock location shocks?
    Fox Shock 2.0 Performance Series, Remote Reservoir, 10.1″ Travel, CD Adjuster
    SKU: FOX-985-26-057
  17. Apr 21, 2021 at 8:29 AM
    #2757
    ARCHIVE
    Eric
    Yeah that is a pretty good choice, if the collapsed length is 15.2", you really don't want to exceed that collapsed length or you start bottoming shocks requiring bump spacing, which is counterproductive.
    This is the reason for doing an Archive shock relocation, getting great droop without hurting your bump travel.
  18. Apr 24, 2021 at 7:35 PM
    #2758
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    So 1/4” ride height loss in the rear is the standard?
    V3 looks very nice! :thumbsup: Will pick between one of two companies.
  19. Apr 25, 2021 at 5:30 AM
    #2759
    ARCHIVE
    Eric
    Thank you. There is no drop, and no lift.
    Start a conversation for the TW discount code
  20. Apr 25, 2021 at 7:56 AM
    #2760
    Round the world
    Round the world Well-Known Member
    Andy
    Home's our Tacoma
    2019 Tacoma AC LB TRD Sport MT
    flatbed with 4WC Fleet with extensive mods
    Thanks Eric for making a great, beefy product!
    Before photo. After 20,000 miles of mostly highway, but definitely some rough roads, our stock hangers were bent and touching the frame, shown by the dust free point
    Afterwards:
    Notice our custom Deaver springs, beefy as well. The ride has definitely improved.
    Closeup of our setup. Thanks to Aiden James Customs of Santa Ana, we’re back on the road with a shipping date to Europe of July 15th! Our round the world adventure begins!
