Hammer Hangers® by Archive Garage 2005-2023 Tacoma Shackle Hangers
Discussion in 'Archive Garage' started by ARCHIVE, Nov 13, 2017.
  1. May 17, 2023 at 11:51 AM
    #3561
    Paucoma
    Paucoma Member
    Paulo
    Hi Eric, looking to order just wanted to make sure correct. Im running icons rxt leaf pack, 8112/8100 bilstein full suspension. ordering option: stock shackle, cross tube (reroute spare), would opting for poly bushing help with mid travel or stick to stock bushing. PM me with the discount code haha.
  2. May 17, 2023 at 1:53 PM
    #3562
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Hey, any shock that is between stock extended length of 23.5" and maybe 25" will not benefit from poly bushings in the shackle, because the shock is the limit to droop at that point. If one is staying with that length shock for the foreseeable future, and staying with stock shackles, then I'd recommend staying with rubber bushings if you're running stock shackles as they're zero maintenance.
    The Achilles heal of the Tacoma rear suspension is the stock hanger, while the shackle is not bad. So the Hammer Hangers are the most important part of this upgrade, not as much the shackles.
    dumontrider and H3llRid3r like this.
  3. May 31, 2023 at 5:32 PM
    #3563
    Yeti with a Bourbon
    Yeti with a Bourbon New Member
    2018 Trd Pro
    Eibach front springs, Deaver stage 1’s, hammer hangers, shackles.
    Hello Eric @ Archive, was on your site looking at HH and some shackles, saw the note for the discount if I sent a note through Tacoma world. Thanks Eric! Talk to you soon.
    Yeti
  4. Jun 21, 2023 at 3:55 PM
    #3564
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    dumontrider likes this.
  5. Jul 27, 2023 at 2:55 PM
    #3565
    ARCHIVE
    Eric
    Hammer Hangers, 3.6"/4.0" shackles, and HC X-tubes in stock!
  6. Jul 29, 2023 at 12:27 PM
    #3566
    ARCHIVE
    Eric
    H3llRid3r, LOLLY and dumontrider like this.
  7. Aug 8, 2023 at 12:06 PM
    #3567
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Best and OG Hammer Hangers! Saved my ass many a time lol.
  8. Aug 8, 2023 at 1:12 PM
    #3568
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    Eric,
    I originally installed my hangers in the extended length configuration. I'm now considering drilling the extra hole and moving them forward to the OEM position. Any problems with reusing the bolts when/if I do this, or would it be recommended to replace them like U-bolts?
  9. Aug 8, 2023 at 1:24 PM
    #3569
    ARCHIVE
    Eric
    Thanks Brian! Hammer Hangers® is now a registered trademark for Archive Garage!
  10. Aug 8, 2023 at 1:26 PM
    #3570
    ARCHIVE
    Eric
    New bolts are not mandatory but we can supply you a bolt kit. FYI we are now supplying zinc plated hardware
    H3llRid3r and crashngiggles like this.
  11. Aug 9, 2023 at 8:51 AM
    #3571
    ARCHIVE
    Eric
    H3llRid3r likes this.
  12. Aug 28, 2023 at 11:06 PM
    #3572
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    These do really change the ride in the rear. Only 700 miles so far. Next weekend going to put them to the test.
  13. Aug 30, 2023 at 8:53 PM
    #3573
    ARCHIVE
    Eric
    Desert season, Hunting Season, Fall and Pumpkin Spice season is upon us 15% off Sale, Get it!
    www.archivegarage.com
  14. Aug 30, 2023 at 9:53 PM
    #3574
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
  15. Sep 12, 2023 at 10:34 PM
    #3575
    NormanPerez
    NormanPerez Well-Known Member
    Norman
    Rolling Hills Estates
    2018 TRD Off-Road
    stock a fawk!
    Need to order a pair of leaf springs and once those come in. I Can install the hangers and the springs and be done with the rear end. Great stuff!
  16. Sep 23, 2023 at 11:18 AM
    #3576
    ARCHIVE
    Eric
  17. Oct 4, 2023 at 1:00 PM
    #3577
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Has anyone used the Dobinson's greaseable leaf spring bolts in their Archive Garage Hammer Hangers/Fabbed Shackles? Just looking to make sure there is clearance.
    Will plan to drill out the bushing sleeve in the leaf pack so that grease has a slight chance of making it where it needs to go.
    Growing tired of my leaf springs creaking and squeaking and need to do anything to mitigate it. Losing my mind with dousing them in silicone spray weekly.
  18. Oct 4, 2023 at 2:30 PM
    #3578
    ARCHIVE
    Eric
    See post #1. We do not advise doing so, there isn't enough room and they supply a standard nut and a horrible split lock washer.
  19. Nov 17, 2023 at 12:57 PM
    #3579
    straitbad01
    straitbad01 New Member
    Scott
    2012 Tacoma 4x4 MT
    @ARCHIVE I'm looking at getting a set of your hammer hangers. Do you mind sending over a discount code please
    ARCHIVE[OP] likes this.
  20. Nov 23, 2023 at 8:56 AM
    #3580
    ARCHIVE
    Eric
    BLACK FRIDAY DEAL:
    Hammer Hangers® 6 year anniversary celebration, Thursday 11/23 & Friday 11/24 til midnight PST only!
    Any direct purchase of Tacoma Hammer Hangers, get 10% with code nov2023,
    PLUS a FREE set of Wheel Sensor Skids ($60 value)
