Hammer Hangers® by Archive Garage 2005-2023 Tacoma Shackle Hangers
Discussion in 'Archive Garage' started by ARCHIVE, Nov 13, 2017.
  1. Nov 27, 2023 at 8:14 AM
    #3581
    CruisingCali4x4
    CruisingCali4x4 New Member
    2013 Tacoma 4x4 TRD Off Road
    Free Wheel Sensor Skids!? Awesome!
    Order placed on 11/23 :) Can't wait to install the Hammer Hangers and Ubolt flip kit (and sensor skids).
    H3llRid3r and dumontrider like this.
  2. Nov 27, 2023 at 8:37 AM
    #3582
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Yup, thanks for your support!
    10% SALE STILL ON TIL Nov 30th
  3. Jan 4, 2024 at 5:11 PM
    #3583
    jmc0369
    jmc0369 Member
    Jon
    '17 DblCab TRD OR 4x4
    I have searched aa few different ways, but havent seen explicitly any accounts of HH on stock TRD OR Suspension. I want to update my worn OE shocks without any lift.
    Am I to understand that I may need extended shocks like 5125 even if I keep the OE leafs? I would eventully get a custom leaf pack for my weight that doesnt provide anymore lift.
    Thanks
  4. Jan 4, 2024 at 6:50 PM
    #3584
    ARCHIVE
    Eric
    There is nothing special about stock TRD OR suspension, virtually exactly the same as the other trim levels except the Pro with Fox 2.5" shocks
    Hammer Hangers are a great combo with stock springs (or stock + AAL) for ride and handling
    I'd get away from Bilsteins, and move to custom valved Fox 2.0 Performance series Remote reservoir from AccuTune Off Road
    The rear Bilsteins on my 22 Tundra OR were atrociously bad, they're even worse with rear coil springs.
    H3llRid3r and Jr. like this.
  5. Jan 13, 2024 at 11:43 AM
    #3585
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
    hey Eric, just curious about this Bilstein comment. is there any compatibility or performance issues with using a 6112/5160 kit with Archive Garage products?
  6. Jan 13, 2024 at 5:11 PM
    #3586
    Hami0528
    Hami0528 Well-Known Member
    Brayden
    Tulsa, Oklahoma
    2011 Timberland Mica Tacoma TRD Off Road
    Dobinson IMS shocks and coils, SPC upper control arms. Archive garage rear shock relocation kit with king 2.5x12 smoothies with adjusters and archive medium duty leaf pack.
    What’s the discount code for 5% off?
  7. Jan 13, 2024 at 5:19 PM
    #3587
    ARCHIVE
    Eric
    Please start a conversation, thank you
  8. Jan 13, 2024 at 5:20 PM
    #3588
    ARCHIVE
    Eric
    No, other than my opinion based on experience is just that 5100s are throwing money away, they're just not good
  9. Jan 14, 2024 at 4:19 PM
    #3589
    Way Way Afar
    Way Way Afar Well-Known Member
    2022 TRD OR 4x4 DCSB AT
    Agree. I went this route and regret it. I have a clunk now most times as a I come to a stop.
    RoostrC0gburn likes this.
  10. Jan 17, 2024 at 1:37 PM
    #3590
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    Hi Eric,
    I bought a set of hammer hangers from a member here who sold his truck before installing. I didn’t receive the M14 shackle bolts in the purchase. What length are those bolts?
    If I buy a set of shackles from you, do they come with the bolts?
  11. Jan 17, 2024 at 8:53 PM
    #3591
    ARCHIVE
    Eric
    We can sell the bolts separately and the shackles, please message or email us
    crashngiggles and dumontrider like this.
  12. Jan 17, 2024 at 8:57 PM
    #3592
    TomHGZ
    My rear end sits a little higher than I would like. Any reason for me not to go with 4 inch shackles to bring the rear down a half inch?
    Will I get any extra flex from the 4’s vs. the 3.6’s? Deaver U402’s, 11 inch shocks.
  13. Jan 18, 2024 at 10:11 AM
    #3593
    ARCHIVE
    Eric
    No, 4.0 shackles will have less maximum droop that the 3.6s because the Deavers are longer springs. But with 11" shocks you won't get to max droop
    TomHGZ[QUOTED] likes this.
  14. Jan 18, 2024 at 10:18 AM
    #3594
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    The 3.6" shackles dropped my rear end about 1/4" over the stocks (Deaver J66 FWIW). Made a bigger difference than expected in overall appearance. The rear ride quality and handling after doing the Hammers and shackles is amazing and I appreciate it every day.
    My review here if interested: drizzohs '21 off-road build | Page 11 | Tacoma World
    Also installed their bump stops a bit after this and those are amazing as well. Review here: https://www.tacomaworld.com/threads/drizzohs-21-off-road-build.748190/page-12#post-28871527
    TomHGZ[QUOTED] and ARCHIVE[OP] like this.
  15. Jan 28, 2024 at 8:29 PM
    #3595
    custmpaint16
    custmpaint16 Active Member
    Phoenix
    Review: Installed Hammers on 2012 w/3.6 Archive shackle. Thanks to this thread the install went really smooth. It was my second time tackling the frame rivets, which helped. I used an angle grinder to cut an X in the head, air chisel to take the rest of the head off. Flapper wheel to grind smooth with stock hanger. Pried off the stock hanger, after hacking the bottom of it off with a sawzall (for ease of access). Flapper wheel to grind smooth with frame. Then, top ones came out with the air chisel point attachment, on the bottom I used a balljoint press with a bolt. This damaged the washer welded on the top of the crossmember, but those came off real quick with the air chisel. I just added an additional fender washer in the same place during the install, since I trashed the stock one. But this approach was worth it, not having to drill out the rivets just to save the washer.
    The ride improvement is significant. I really noticed the improvements at speed in rollers and big hits. It almost feels like long travel now. The increased droop really allows the shocks to do their job. It's more planted, soaks up big hits, and balanced with the front. One of the best upgrades. Crawling was greatly improved too, more articulation. Someone on here said they thought it feels like they have weight in the bed when it's empty now. I totally agree.
    Eric at Archive was great to work with, responded to emails quick, and shipped really fast. Well built, great company!
    Icon Stage 9, Hyd bumps
    Dirt King stock LCA
    RXT Leafs in option 2.
  16. Jan 28, 2024 at 9:31 PM
    #3596
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s the exact process I’ve used half a dozen times, and it works really well. An air hammer makes the job a lot easier.
  17. Feb 27, 2024 at 9:33 AM
    #3597
    tacoman_13
    tacoman_13 Well-Known Member
    Triston
    San Diego
    2007 TRD Off-Road
    JD Fab LT, Archive Garage Hammer Hangers, soon to be on 35's
    So this is my next upgrade. I've only heard great things about the hammer hangers. My only question that I have is about the crossbar. Is it necessary? How much does this help and what exactly does it help the hangers with? My only concerns with doing it is then jumping to relocate my spare in my bed and finding a way to relocate it that works with my day to day. thanks.
  18. Feb 27, 2024 at 9:45 AM
    #3598
    Jr.
    Jr. Well-Known Member
    Dave
    San Bernardino/San Diego CA
    2021 TRD offroad
    I literally just ordered some hangers and the option 3 flip kit bumps 10 minutes ago
    ARCHIVE[OP] likes this.
  19. Feb 27, 2024 at 9:57 AM
    #3599
    ARCHIVE
    Eric
    The Hammer Hangers are rigid, but the stock cross member remains flexible. Our Hi Clearance cross tube ties the HH together, greatly reducing the bending force on stock cross member.
    Plus our tube ties HH together torsionally as well, sharing torque across both frame rails, in case you drop a hanger on a rock (How stock hangers lead to bending frame bottom flange)
    So it's not necessary but it does deliver maximum ride quality improvement and durability off road.
    drizzoh likes this.
  20. Feb 27, 2024 at 10:48 AM
    #3600
    tacoman_13
    Triston
    San Diego
    2007 TRD Off-Road
    is it possible to install just the hangers and then
    It is possible to just install the hangers and then later down the road by the cross member and put that in?
    Klinc207 likes this.
