Hammer Hangers® by Archive Garage 2005-2023 Tacoma Shackle Hangers
Discussion in 'Archive Garage' started by ARCHIVE, Nov 13, 2017.
  1. Apr 5, 2019 at 2:19 PM
    #1001
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    Is anybody running the 3.6" shackle with a 14in shock on a SOA? Will a 14 give benefit over a 12 with that setup?
  2. Apr 5, 2019 at 2:25 PM
    #1002
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Spring Over. Just maxed my my 3 ton jack. Shackles haven’t even fully rotated yet, so I still have more droop left. All tires still on the ground.
    94FBA5CA-E217-4535-B507-51ABFBBFADE0.jpg B8FD4501-2DD6-4A26-AB0D-EE438162B982.jpg 031832F4-FF12-40ED-954B-B45D8E288E05.jpg
    mightym and Maveric like this.
  3. Apr 5, 2019 at 2:28 PM
    #1003
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    Should i have gotten the bigger shackle?
  4. Apr 5, 2019 at 2:32 PM
    #1004
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Depends on your leaf pack. You want to go with a shackle-leaf combination that will allow your leaves to fully droop out and allow for the shackle to fully rotate over. The OME dakar pack is short, so a longer shackle, once fully rotated on the hanger at full droop, is long enough to arch the shorter leaf pack. Thus creating more droop. If you go with a longer shackle with longer leaves, such as all pro expos for example, the shackle won't be able to rotate over fully because of the length of the longer pack. So in those cases, the 3.6" or stock shackles would be a better option.
  5. Apr 5, 2019 at 2:37 PM
    #1005
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    I have the Icon RXT leaf pack
    eyemajeenyus likes this.
  6. Apr 5, 2019 at 2:50 PM
    #1006
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    @ARCHIVE did i make the right move with the smaller shackle and the leaf pack I have? I want max travel/droopage!
  7. Apr 5, 2019 at 3:33 PM
    #1007
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Buy RCI skids, pick them up during your trip
  8. Apr 5, 2019 at 3:35 PM
    #1008
    hoarder23
    Shay
    NJ
    Scratches
    That's a really bad limit factor. You should extend them, we did when I did my relocate.
    Supra4x4[QUOTED] likes this.
  9. Apr 5, 2019 at 3:35 PM
    #1009
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    I like where your head is at, but alas, everything else on the truck is Mobtown and I want it all to work together!
    EatSleepTacos likes this.
  10. Apr 5, 2019 at 3:40 PM
    #1010
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @Alesimo congrats man! You’ll live them.
    @Supra4x4 you should really extend those wires. I extended mine by like 4” and that’s all you really need.
    Supra4x4 likes this.
  11. Apr 5, 2019 at 3:41 PM
    #1011
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    How does one go about extending abs lines?
  12. Apr 5, 2019 at 3:44 PM
    #1012
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Lol, yeah agreed I fully plan on extending them. I have them removed from the clip on the diff at the moment. under articulation, it should be fine. It's only at full vertical droop that they are stretched. Any tips for extending them? I'll probably strap' it just shy of full shock droop as well.
  13. Apr 5, 2019 at 3:47 PM
    #1013
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just cut them, and solder in some wire, and heat shrink. I cut up an old CAT5 cable and used that.
  14. Apr 5, 2019 at 3:47 PM
    #1014
    hoarder23
    Shay
    NJ
    Scratches
    I didn't do it but supposedly it's as simple as depinning the plug and splicing in some extra wire.
  15. Apr 5, 2019 at 3:51 PM
    #1015
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Sweet, thanks. If the sensor is a simple power and ground, that'll be easy.
  16. Apr 5, 2019 at 3:53 PM
    #1016
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  17. Apr 5, 2019 at 3:59 PM
    #1017
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
  18. Apr 5, 2019 at 4:02 PM
    #1018
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Thanks, I’m very happy with how it came out. Just enough slack at full droop on the lift.
  19. Apr 5, 2019 at 4:07 PM
    #1019
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    I already bought a pair.
  20. Apr 5, 2019 at 4:09 PM
    #1020
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    Love it. I'll need to get a soldering set up. No way I'm just splicing that in.
    This will be a perfect time to do my diff breather bs
    EatSleepTacos[QUOTED] likes this.
