Hamster wheel spinning (sounds like)when AC is on! You?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w8n4mud, Jun 8, 2008.
  1. Jun 8, 2008 at 7:38 PM
    w8n4mud
    w8n4mud [OP] I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Any of you Taco owners here something spinning when you turn "ON" your air/AC? After a while, I've got to turn it off because it's the most annoying sound ever. I'm hoping it's a "do-it-yourself" job. Please advise. Thanks brother.:)
    Hey...on a side note, what about the molding around the window. My is coming off on the bottom left side. The whole strip and the black rubber piece are loose and can't seem to figure it out. Can't take it to the dealer because Im at 54k miles. Don't feel like paying for that since they're service is already a premium here. :help:
  2. Jun 8, 2008 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you have glass coverage on your auto policy, just call insurance company and tell them. If you dont have it on your policy, get it, then call them. :)
  3. Jun 8, 2008 at 8:50 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    crack your window and call it vandalism, they should fix the whole thing......dont forget to mention that picasso that got stolen too:)
  4. Jun 9, 2008 at 5:09 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I don't have the answer to either but my AC just started making a strange noise similar to what you are describing but only when my vehicle is in neutral or park and the air is on. Dosen't matter how high I have it set.
  5. Jun 9, 2008 at 8:38 AM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Probably either brush noise in the motor or a piece of foliage got into the blower section.
