hand gun for black bear hunting
Discussion in 'Guns & Hunting' started by Huntn57, Aug 12, 2014.
  1. Aug 13, 2014 at 5:50 AM
    #61
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    Beautiful!!!!!!! handgun or cannon I would go with either .475 or .500 thay will do for anything.
  2. Aug 13, 2014 at 5:52 AM
    #62
    darrinhutch
    darrinhutch Well-Known Member
    darrin
    VA
    83 toyota pickup
    Lift with springs, BFG KM2, yeasu ham radio, custom flat bed, browning shift knob, tools box, mag lite, seat and steering wheel cover
  3. Aug 13, 2014 at 6:11 AM
    #63
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    http://en.m.wikipedia.org/wiki/.45_Colt
  4. Aug 13, 2014 at 6:20 AM
    #64
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Good a wounded bear falling out of a tree hitting the ground pissed!
  5. Aug 13, 2014 at 6:25 AM
    #65
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  6. Aug 13, 2014 at 6:44 AM
    #66
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Why not go with a .454 casull? Plenty of knock down and is also available in the Taurus raging judge magnum. Would allow for use of .410, .45 LC , AND .454 CASULL. Three cartridge options in one package. Would also allow for hotter hand loads for the.45 lc so it can be used to its true potential.
  7. Aug 13, 2014 at 10:35 AM
    #67
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    :drool: Yeah, this and a Casull both seemed snappier than a 500 Mag. Awesome guns, though. :drool:
  8. Aug 13, 2014 at 11:04 AM
    #68
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Check local laws and go from there. In NV you cannot hunt with any caliber that has a case length shorter than .357mag. I would think a hopped up .357 would get it done, but I would choose .44 mag for bear.
  9. Aug 13, 2014 at 11:20 AM
    #69
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    44 Mag or one of the 454, 500 revolvers with a 357 mag being the absolute lower limit. I would not attempt a bear with a 45acp in anything but a desperation/survival situation. In an auto I really thing it narrows down to 10mm. You could try with a 357 sig, but you would probably be better off with a 9x23 or 38 Super if you were going to go to a .356/.357 bullet.You would need to handload the 38 super to get a round that would be up to snuff. But again, I would recommend the larger caliber revolvers. Just my .02
  10. Aug 13, 2014 at 11:20 AM
    #70
    MateoTorgy
    MateoTorgy Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    It takes just a few years of reloading ammo and a basic understanding of ballistics and physics generally to know which rounds are capable of harvesting a black bear safely and humanely. Up until I had posted my comment (from which you justifiably detected arrogance), members had posted rather ridiculous comments that could have misdirected the well intentioned questioner onto a path of embarrasment or a safety risk. These comments evinced a lack of understanding of the difference between self-defense rounds and those designed to effectively take down a bear. For instance, one person indicated that the .40 S&W and .357 Sig were acceptable bear rounds. I do apologize if I came across as an arrogant know-it-all, but.... My God. Come on.
  11. Aug 13, 2014 at 11:22 AM
    #71
    T4RFTMFW
    T4RFTMFW Well-Known Member
    101...
  12. Aug 13, 2014 at 11:27 AM
    #72
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    44 Mag.
    I shot and killed a 130# doe with a 357 Mag. once. I would never do it again. Granted it was a pretty far shot, (~50 yards) but hit her right in the heart broadside. No exit wound and not one drop of blood. I found her because there was a trace of snow on the ground. That was no where near enough gun. ...and it weren't no bear......
  13. Aug 13, 2014 at 11:32 AM
    #73
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    A .357 mag could work if you have good shot placement and load them hot. But I still wouldn't trust it
  14. Aug 13, 2014 at 11:45 AM
    #74
    MateoTorgy
    Mateo
    Minnesota
    X2
    I'm pretty sure the maximum weight bullet for the .357 mag is 158 gr and, at that weight, you get significantly slower velocities and thus less penetration. For that very reason, most LEOs who carried the .357 revolver used the 125 gr bullet, which was (and likely still is) considered to be the optimal personal defense round due to its velocity and resulting hydrostatic shock (immediate stopping power) and penetration of at least the 12 inches in satisfaction of the FBI ballistics protocol developed after the 1986 incident. You can find 300 gr. bullets for the .44 mag. In fact, a person with a .44 mag would have a choice of loads between 180 gr and 300 gr, thereby allowing him to use the same gun for hogs, deer, bear, and elk. Personally I'd throw the .357 out as an option for bear or even deer knowing that the .44 mag is available. Although that S&W 686 is a dream to shoot.
  15. Aug 13, 2014 at 12:38 PM
    #75
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    No one said 40 s&w was a good bear round, I said it would be better than a 9mm as the op asked. I even said that my cousinshot a hog 8 times in the head with jhp 40 s&w so I wouldn't use it.
  16. Aug 13, 2014 at 12:42 PM
    #76
    MateoTorgy
    Mateo
    Minnesota
    In the context of discussing ideal bear hunting rounds, you stated -- and I quote, "If you want auto maybe 10mm, 40s&w, or 357 sig."
    Therefore, I would greatly appreciate it if you stopped denying you stated it, especially when it's documented in your own posting. My God.
  17. Aug 13, 2014 at 12:54 PM
    #77
    06 tacoma owner
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    Hollow points are for shit hunting anyways. Soft tips is what you need or hard cast bullets
  18. Aug 13, 2014 at 1:51 PM
    #78
    muddedtaco
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Fuck you and Tacoma world, I am sick of every one having a pissing contest, I say goodby:cool:
  19. Aug 13, 2014 at 2:27 PM
    #79
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    That makes two of us. I wouldn't even trust a 9mm on a person on drugs. I like stopping power over how much the mag can carry. On the Alaska bear hunting show they use the 500 revolver I think, it's something like 500 grains of powder. I'm sure a 10mm could be used, just ask Razor Dobbs, he uses his Dan Wesson 10mm for just about everything, but I think it's going to take a few shots and when a bear is charging you don't have much time. Even my tried and true Colt .45 would leave me a bit concerned.
  20. Aug 13, 2014 at 3:32 PM
    #80
    T4RFTMFW
    Jesus this thread. If you're going to bear hunt with a pistol, buy a revolver and buy as much gun as you can afford. If you can't afford a large enough or too large pistol, stick with your rifle.
