Hand made carbon Intake
Discussion in 'Performance and Tuning' started by zach nunes, Sep 22, 2012.
  1. Sep 22, 2012 at 11:41 AM
    zach nunes
    zach nunes [OP] it looks stock, but with a little zest
    zach
    chico/carmel
    09 4x4 SR5
    a little zest here and there
    ALRIGHT THIS IS MY FIRST THREAD, SO GO EASY.
    So after having my truck for a couple years and doing little things here and there, I figured it was time to look into some performance upgrades. Right off the bat, I started with the intake as I thoughtit would be the cheapest place to start. Turns out, intakes are pretty damn pricy. Anywhere from two to three hundred and some, plus I was not to impressed with what u get for the money, A BUNCH OF PLASTIC. So after thinking about it I decided to dive right into a new project and make my own Intake.
    STEP 1
    I started off by removing the stock air box, making a large block of foam and sculpting the required bends to clear STUFF and THINGS under the hood resulting in a tube that transitions from the 3 inch carb to a 4 inch filter.
    STEP 2
    Once I had my plug done, I made a box to section half of the plug off at a time in order to make my negative molds. This was done for each side.
    STEP 3
    After the negative molds cure, it’s a matter of layering carbon fiber and fiberglass to creat the two halves of the tube.
    STEP 4
    The two halves were then “stitched” together with several layers of carbon on the inside and out.
    STEP 5
    After coating the tube with several layers of resin and countless hours of sanding inside and out, the final product was showing.
    STEP 6
    The filter box was somewhat easier to make as I found a plastic tub from good old wall mart that, with a few minor altercations,would do the job. So I used the tub as a negative mold, stuffing resin and layers of carbon. After an overnight sit I pulled it from the tub trimmed it up and BAM not bad.
    STEP 7
    As soon as I found a decent way for mounting the top,I stripped it and started the lengthy process of coating in resin and sanding.
    STEP 8
    Once it was all sanded, polished, and cut. It was time to assemble the thing.
    STEP 9 :)Install:)
    All the important crap was integrated behind the tube to help keep clutter to a minimum. I had this thing on for only a day now,and easily notice a gain in power, makes a wicked sound too. It has thrown a check engine but I believe that’s due to my breather hose crimping, but all getback on that. You may have notice but this was a real budget build as I am in college at the moment and could not afford to do everything right. This was a little side project for me. There areseveral reasons I went with carbon fiber, one because I had a fat roll of it in my closet so it was there to use, also it is a great material to use if you are trying to create difficult corners, bends and edges. Plus I did not see much in the carbon fiber intake market out there, and what was out there sure was pricy. The end result is that it does make a gain, how much is the question. Also, it’s not user friendly by far and there are a lot of things that I would like to do differently and correctly during the build process that will help to end up with an easier and cleaner setup, as I plan on making a second version and stronger molds. I’m also planning on making an air funnel or “ram”that goes from the front grill to that 4 inch hole on the side on the box. I would like to get my truck dynode with the setup and with the stock to find out the gains or losses and see how I can improve. please let me know if you have any ideas.
  2. Sep 22, 2012 at 11:44 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    SICK!!
  3. Sep 22, 2012 at 11:45 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Unique and cool. Check engine light will probably stay on though...
  4. Sep 22, 2012 at 11:46 AM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Wow great project. I'm impressed.
  5. Sep 22, 2012 at 11:47 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Woah! Nice work man! I'm interested to see the ram scoop
  6. Sep 22, 2012 at 11:47 AM
    zach nunes
    zach
    chico/carmel
    09 4x4 SR5
    yup I did make sure of that by positioning it between the transition of 3 to 4
  7. Sep 22, 2012 at 8:23 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Nice job!
    The check engine light is result of the diameter of the intake and maf placement. Crimped breather hose will not throw a check engine light.
  8. Sep 22, 2012 at 8:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Make it connect to a hood scoop like this [​IMG] and I'm in!
  9. Sep 22, 2012 at 8:33 PM
    bellero
    bellero Well-Known Member
    Wainwright, Alberta
    Tacoma 2003
    Looks real good!
  10. Sep 23, 2012 at 9:02 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  11. Sep 23, 2012 at 9:12 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Good work OP! I'm impressed. How many hours total? Do you know what code your throwing?
  12. Sep 23, 2012 at 1:01 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I'd buy that all day long.
  13. Sep 23, 2012 at 1:07 PM
    zach nunes
    zach
    chico/carmel
    09 4x4 SR5
    Im not sure on the code but like 05redtaco said its prolly the placement of MAF sensor. I tried to put it within the same size diameter as the stock, but maybe its cus of how un restricted it is. Total houres im not sure????? :confused: I started back in May and took breaks here and there.
  14. Sep 23, 2012 at 1:08 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Pretty neat! Nice work :thumbsup:
  15. Sep 23, 2012 at 1:08 PM
    zach nunes
    zach
    chico/carmel
    09 4x4 SR5
    Tiss the plan to make more.:D
  16. Sep 23, 2012 at 1:31 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Nice work OP, looks clean, like a pro!
  17. Sep 24, 2012 at 7:43 AM
    05RedTaco
    Tony
    Scottsdale
    I have cheap ebay intake, have had it for a year and no CEL :confused:
  18. Oct 7, 2012 at 2:53 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Your check engine light is likely from induced sensor error. The size and shape of the tube looks different than stock and that likely has caused the calibration of the MAF sensor to be very off.
    Use a scan tool and check the fuel trim deviation at idle and a steady 60 MPH and see how far out the trims are. If that is your problem you can recalibrate the MAF sensor to the new tube using the URD MAF Sensor Calibrator and fix that problem up pretty easily.
    G
  19. Oct 7, 2012 at 4:30 PM
    zach nunes
    zach
    chico/carmel
    09 4x4 SR5
    awesome :D yeah im most likely going to make another one with improvements. and will check that out. would there be a noticable difference by calibrating it? also if I just left it the way it is now throwing a check is it going to do any long term damage to the engine. It has been bugging me and have been thinking about throwing the stock one back on.
  20. Oct 7, 2012 at 6:39 PM
    Gadget@URD
    If it is running to lean or two rich it can damage the engine. No doubt about it.
    G
