Hand wash cloth to get without micro scratches
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The_vue's, Aug 1, 2018.
  1. Aug 1, 2018 at 5:27 AM
    The_vue's
    The_vue's [OP] Well-Known Member
    18 cement
    Anything to avoid buying and what to get at my big box store that will be good to get to wash my car with?
  2. Aug 1, 2018 at 5:28 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Microfiber, but it's not necessarily what you wash with, it is what may still be on the paint after you rinse and the ability of your soap to keep cloth and paint lubricated while washing. That's why clay bar is important.
    Also make sure you "scrub" in straight lines, not in circles.
    kgilly, ChadsPride and BillW like this.
  3. Aug 1, 2018 at 5:36 AM
    s.e.charles
    s.e.charles Well-Known Member
    kite_325 and BillW like this.
  4. Aug 1, 2018 at 5:43 AM
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    And use two buckets. One to rinse your dirty mit, the other has soap. And I use a dedicated bucket for wheels only.
    ChadsPride likes this.
  5. Aug 1, 2018 at 5:44 AM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    I spray on soap with a hose attachment and use a pole brush to wash. Did that for 11 years with my 07 and people thought the paint looked brand new.
    I used a few different waxes on my 07. On my 18 I'm just using the hybrid wax from car guys but I'll do a semi yearly/yearly full wax with a buffer.
    Never had a swirl, but then again mine is silver and it's way more forgiving.
    Your biggest caution will be cleaning that plexi in the instrument cluster. Gotta be real careful there.
  6. Aug 1, 2018 at 6:10 AM
    luminous
    luminous Well-Known Member
    Clay is an abrasive and has nothing to do with love marks from washing. Clay removes contaminants from the clear that otherwise could not be removed with a normal wash, these contaminates are not causing those love marks. You should not be using clay often as it will mar the paint, and will require a compound/polish step to fix.
    Use the two bucket method with good soap and keep the paint wet. Do not use excessive force. I use these: https://www.detailersdomain.com/collections/wash/products/detailers-domain-microfiber-wash-mitt
    rickm likes this.
  7. Aug 1, 2018 at 6:29 AM
    Kirbstomp1287
    Kirbstomp1287 @MilSpecTaco
    17’ Inferno SR5 V6 DCSB XP
    Check out TheRagCompany. They make some amazing Microfiber stuff for any use.
    I pretty much only use TheRagCompany and Adams Polishes on my vehicles.
    Also the two (or three) bucket method is huge like others have said. And if you have/can get a power washer and a foam cannon it helps a ton with getting most all of the debris off your paint before you even touch it with the wash mit.
    Only use the wash mit in straight lines, never in circles. If for some reason your mit does scratch the paint, straight line scratches are much easier to fix than swirls.
    Also pay attention to the soap you use, some are meant to strip all your waxs/sealants off, most do not. So if you just waxed your truck you don't want to use a strip wash cause then youll end up having to do a full detail every time you wash instead of just maintaining the wax/sealant you already have on it. However every so often you will want to strip it all off and start fresh to keep the paint from looking cloudy from adding layer on layer of wax/sealant.
  8. Aug 1, 2018 at 6:59 AM
    CanisLupus
    Stokesdale | NC
    Clay can remove some contaminants that would not be dislodged with a rinse or light wash, but would otherwise be knocked loose by using a mitt/cloth, and then dragged underneath. 2-3 bucket method is probably the most important thing to remember just doing a normal wash as others have mentioned.
    I only clay 1-2 times a year for the reason you mentioned as well.
  9. Aug 1, 2018 at 9:50 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Go to a drive through. Been doing it for years and my trucks always look great.
    G.
  10. Aug 1, 2018 at 10:33 AM
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    This may not be a big deal if you have a car that ISN'T black. But I get scratches from automatic car washes every time I go through there. Because instead of being washed off, the dirt is pounded into the sides of your car by those dirty spinner machines. I've gone thru twice and I can already see where it scratched up my car. Never again.
    It should be said though, that if you go to a car wash place advertises hand washing your car, you'll be alright. Still cheaper to wash your own though.
    Getting back to the topic though, I would avoid waxes that leave white residue on plastics. I've found that its pretty much impossible to do a wax job without getting at least a little of that stuff on my car's plastic (usually the fenders since mine's the OR model). Nu Finish leaves a residue and some of the others (I think its the carnuba wax in them?). I know meguires doesn't and some others with special carnuba formulas have found a way around it, but just check the bottles and see if they say to stay away from plastic trim or if they advertise that they don't discolor plastic or rubber. There's so much plastic on cars these days, its worth it to avoid these waxes imo.
    If you do get some residue on the plastic, don't freak out. It won't hurt the plastic, it just doesn't make it look clean and you can get it off with some detailing spray or some of plastic restorer (but be prepared to do all the plastic if you choose the restorer route to make it look uniform since it darkens the color)
  11. Aug 1, 2018 at 10:53 AM
    Garyji
    Gary
    True, about black.
    G.
  12. Aug 1, 2018 at 10:59 AM
    Kirbstomp1287
    Yeah, I started really getting into detailing my own cars a few years ago, and will never take mine back to an automatic wash. I have a 2014 Charger that got a huge scratch up the hood and the roof from something that was embedded in the wash mat.
    I will say though, it's not always cheaper, you can get into some pretty spendy detailing equipment and products lol.
    Ensemble88[QUOTED] likes this.
  13. Aug 1, 2018 at 11:13 AM
    luminous
    You have two options to stop staining your plastic:
    1) Masking tape all plastics off (personally this is what I use because I use a DA to apply)
    2) Stop waxing about 1" away from plastics, come back with a clean applicator and be more careful/go slower
    If you do get some wax on a piece of plastic, Meguiars M39 and a toothbrush will take care of it.
  14. Aug 1, 2018 at 11:54 AM
    Ensemble88
    San Diego, CA
    2017 Black OR DCLB
    Absolutely. It's expensive to get started. But there's also a big difference between a simple wash and a full detail. If all you're doing is washing, a couple buckets and some no rinse car wash w/ a 6 pack of microfiber towels is all you need. I guess he didn't really ask about waxing and detailing. So I probably didn't need to bring it up, whups :anonymous:
  15. Aug 1, 2018 at 11:55 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    You must not like your paint to punish it like that.
    Can we take a swirl finder light to it or sit back 10'.
  16. Aug 1, 2018 at 12:00 PM
    reddit.com/r/autodetailing has a lot of information in the side wiki. Also I just waxed my car with Meguiars Ultimate Liquid Wax and it left no residue on the black trim, but Meguairs ULW is more of a sealant than a wax.
    Vbpiper likes this.
  17. Aug 1, 2018 at 12:05 PM
    jdr3366
    jdr3366 Well-Known Member
    I only use the wash with no brushes. Just high pressure wash.
    Have done it with all my cars/trucks. Clay once a year and it looks great.
  18. Aug 1, 2018 at 12:08 PM
    Kjntaco
    Kjntaco Well-Known Member
    Oahu, Hi
    Here's a few tips:
    Use the 2 bucket method with grit guards to minimize a dirty wash cloth.
    DO NOT use a drive thru car wash and those broom type scrubbers to wash your car. I promise, you will get swirls or scratches.
    Use a good soap to keep the paint lubed when washing your car. You can get a foam gun fairly cheap from Amazon for pre-soaking before the initial wash.
    Buy some quality microfibers for drying because I have seen cheapie ones cause swirls.
    Here's a wash mitt I recommend:
    https://www.amazon.com/Meguiars-X30...&qid=1533150363&sr=1-7&keywords=car+wash+mitt
    But remember the main thing is to keep it clean from contaminates and never use to much pressure when scrubbing.
  19. Aug 1, 2018 at 12:13 PM
    Kjntaco
    Oahu, Hi
  20. Aug 1, 2018 at 1:10 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
