Handbrake Indicator Stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BBiggs, Apr 29, 2010.
  1. Apr 29, 2010 at 7:23 PM
    BBiggs
    BBiggs [OP] Well-Known Member
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    Hello all. 2005 SR5 Access Cab, 6 Spd Manual Trans.
    The... handbrake indicator light won't go off when I take the handbrake off. Has anyone else had this problem?
    It's not a big deal I guess, but fixing it would be nice.
    Thanks!
  2. Apr 29, 2010 at 7:32 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Check your brake fluid level... if that's good:
    First I'd look at the switch for the sensor... then look for a short... ect ect.
  3. Apr 29, 2010 at 8:52 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    x2
  4. Apr 30, 2010 at 12:17 AM
    BBiggs
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    I topped off the brake fluid. Problem solved! Thanks for the assistance!
  5. Apr 30, 2010 at 4:05 AM
    Regaj
    Regaj Member
    Virginia
    2010 Tacoma v6 4x4 6-sp Manual
    Your parking brake cable needs to be adjusted.
  6. Apr 30, 2010 at 5:27 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    No problem, glad it was an easy fix!
    Uh, he already solved the issue? :p
  7. May 3, 2010 at 10:38 AM
    BBiggs
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    ...It came back on.
    Is my brake fluid leaking? I haven't had a chance to investigate yet. But yeah, it's stuck again. UGH!
  8. May 3, 2010 at 3:34 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    That sucks, check the level again and see if it's low. If it is.. time to get the flashlight out and start looking for leaks in the lines :/
    If there are, look at the bright side... Stainless Steel braded line upgrade time :D
  9. May 5, 2010 at 3:11 AM
    BBiggs
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    It seems I have a minor brake fluid leak.
    Does anyone think it would be bad for my truck in any way if I just kept adding brake fluid to the master cylinder everytime it's level got to "MIN" until I work up the courage to go searching for the leak?
    This would probably go on for a couple of weeks.
  10. May 5, 2010 at 4:38 AM
    Brunes
    Brunes abides.
    Rotorhead
    If you keep it full you should be fine- just be careful not to leave it low for too long- Can pull air into the lines and you'll get mushy braking feel or no braking power at all.
