Handheld CB range
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jake slatnick, Mar 23, 2017.
  1. Mar 23, 2017 at 8:12 AM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    What's the range on a handheld CB? Any better than a nice walkie talkie?
    I'm trying to avoid the whole mount and wiring process while still maintaining a decent line of communication.
    Any advice?
  2. Mar 23, 2017 at 8:14 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    depends on how far you are wanting to talk to the other person. Walkie talkies have a decent range nowadays.
  3. Mar 23, 2017 at 8:15 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I run a Midland 75-822. It's a great piece of kit- you can slide a battery pack and a rubber ducky on it and use it as a handheld, or run an actual antenna into the bottom and plug it into your cig lighter for a 'docked' CB. I am currently using a Wilson Lil Wil mounted on my hood with the wire run through my firewall (mega easy, there's a big plug on the left side of the engine bay you can pull out and route it through into the passenger footwell). With the actual antenna, I have measured about 8-9 miles of range with a friend before we lost each other.
    We use the handhelds on backpacking trips sometimes and handheld to handheld we got about a mile and handheld to antenna I was able to receive my buddies handheld at about 2 miles, but that was from the top of one ridge to another ridge.
  4. Mar 23, 2017 at 8:28 AM
    T6A1C9O
    T6A1C9O Well-Known Member
    San Diego, CA
    2017 SW DCSB TRDOR 4x4 w/Tech
  5. Mar 23, 2017 at 8:30 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
  6. Mar 23, 2017 at 10:28 AM
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    Jibbs, I have the same setup as you. Did you tune the antenna or just use the given length?
    Thanks, Hiker
  7. Mar 23, 2017 at 10:30 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Based on the recommendation of the guy from the CB shop i bought the antenna from, I just pushed the whip all the way down into the mount. I think it could be improved by tuning, but I'm not overpowering it or running the risk of frying my radio. Still going to get a SWR meter and tune it "when I get around to it"
  8. Mar 23, 2017 at 11:33 AM
    Hiker46
    Tim
    Colorado
    OVRLND Camper.
    I'll probably do the same..
    Thanks.
  9. Mar 23, 2017 at 11:43 AM
    DoubleAction
    DoubleAction Well-Known Member
  10. Mar 23, 2017 at 2:06 PM
    dorton
    dorton rockcreekoverland
    Winston Salem NC
    2016 TRD Off Road
    Old Man Emu Nitro Chargers, CS047R leafs w/ D29XL extra leaf, CBI front and rear bumpers, CBI armor, rock sliders,ditch light brackets, and bed rack, Free Spirit Recreation Extreme Series roof top tent, VTX Viper wheels, General X3 Grabber tires, 4.88 gears front and rear, Kenwood TM-710G UHF/VHF radio. Icom IC-706MKIIG UHF/VHF/HF radio,KC Hilites 20" Flex Bar and ditch lights, Safari snorkel, BedSlide Classic, SnoMaster USA expedition series fridge.
    A handheld CB, with the factory rubber antenna is not super effective. Even a 3ft, or 4ft CB antenna is a compromise.
    We wrote some articles getting into the basics of radios:
    https://www.rockcreekoverland.com/single-post/2017/02/13/Ham-Radio-Intro-Part-2
    uurx likes this.
  11. Mar 23, 2017 at 2:15 PM
    Nexusix
    Nexusix Well-Known Member
    2017 Toyota Tacoma TRD Offroad 4x4
  12. Mar 23, 2017 at 2:22 PM
    dorton
    Winston Salem NC
    2016 TRD Off Road
    They do work well especially for the $, but do not transmit of frequencies in the CB band, and though very often used on FRS, and GMRS frequencies,
    it is also illegal to do so(full disclosure).
  13. Mar 23, 2017 at 2:24 PM
    Nexusix
    I'm getting my tech license soon. Just got into the ham world.
    dorton[QUOTED] likes this.
  14. Mar 23, 2017 at 2:55 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    As easy as it is to get your Tech and as cheap as the Chinese handhelds are (Some are even in the $30 range)..... just get an external antenna.... I really don't see why people don't go ham more often.
    Rambo54 likes this.
  15. Mar 24, 2017 at 5:09 AM
    dorton
    Winston Salem NC
    2016 TRD Off Road
    Awesome, congratulations! It can open a world as big as you want, or as small as you need.
    If everyone knew how easy it was, and how much better it worked everyone would be a ham.
  16. Mar 24, 2017 at 6:20 AM
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
    ham is so much better
  17. Mar 24, 2017 at 6:48 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    For range maybe but useless here as no one uses it. Just cb
  18. Mar 24, 2017 at 7:07 AM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    What's easier to carry around with the best range?
  19. Mar 24, 2017 at 8:05 AM
    dorton
    Winston Salem NC
    2016 TRD Off Road
    Yes, and no. Would you be better off having a more common mode, but not be able to talk far enough to contact someone, or
    a less common mode and better range? With ham, using line of sight VHF my farthest has been 90'ish miles. Utilizing a repeater(thousands
    across the USA)your range is greatly extended(to worldwide audience if connected to the internet), and on vehicle mounted HF(not an entry level license)
    have talked as far as Russia. CB, especially a handheld is going to be really handicapped for range.
