Handheld GPS recommendations
Discussion in 'Technology' started by blackcloud08, Nov 12, 2017.
  1. Nov 12, 2017 at 2:45 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    you can still use your Garmin to see where youre at. And to see where the trails are at and what not
  2. Nov 12, 2017 at 2:47 PM
    ramonortiz55
    Ramon
    Texas
    stock
    But if you want to select a destination thru your Garmin unit it may or may not send you to your destination via turn by turn directions.
    Some Garmins do it.
    the ones that dont require you to plan your routes beforehand and upload them to your unit
  3. Nov 12, 2017 at 2:49 PM
    blackcloud08
    blackcloud08 [OP] Well-Known Member
    WNC
    I don’t want turn by turn directions. Google maps just seem to be the most detailed maps.
  4. Nov 12, 2017 at 2:51 PM
    ramonortiz55
    Ramon
    Texas
    stock
    The Garmin Maps are just as good or even better.
    If you dont want turn by turn directions, then youre good w pretty much any Garmin.
  5. Nov 12, 2017 at 2:51 PM
    blackcloud08
    WNC
    I just need to see where the roads go with detailed maps.
  6. Nov 12, 2017 at 2:55 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Garmin etrex 20 has never let me down yet.
    dziner, dtaco06 and blackcloud08[OP] like this.
  7. Nov 12, 2017 at 2:56 PM
    blackcloud08
    WNC
    Does it have FS roads in it?
  8. Nov 12, 2017 at 2:58 PM
    TomTwo
    Bill
    I-85 Southbound
    I have never used it close to a FS road. So now I need to check this out. I did buy a program off Amazon so I can use it on city streets.
  9. Nov 12, 2017 at 3:25 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Depends on the base map you install. I would think any good topo would have USFS roads on it.
  10. Nov 12, 2017 at 3:27 PM
    blackcloud08
    WNC
    I’m good with electronics but I’ve never messed with a handheld gps. Where do I get the base map?
  11. Nov 12, 2017 at 3:30 PM
    ramonortiz55
    Ramon
    Texas
    stock
    From Garmin. It would have all the USFS roads.
  12. Nov 12, 2017 at 3:31 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    You can buy 24K and 100K topo maps from Garmin.
  13. Nov 12, 2017 at 3:36 PM
    blackcloud08
    WNC
    Does Garmin have road names or will it just show you’re on a road? Also, what’s the difference in 24k vs 100k maps? I’m seeing it’s just more terrain detail that both have all known trails/roads, correct me if I’m wrong.
  14. Nov 12, 2017 at 3:46 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    http://lmgtfy.com/?q=24k+100k+topo
    It boils down to level of detail. A 24K map means the map scale is 1:24,000 and 100K means 1:100,000. So 1" on the map represents 24,000" on the ground. In USGS terms 1:24,000 represents 7.5 minutes of latitude and 7.5 minutes of longitude, e.g. a 7.5 minute quad. The reason to use a 100K map would be to shrink the physical size, which has no meaning on a GPS receiver. What a 100K digital map does is saves storage space but since SD cards and memory in general is cheap there's no reason to bother with anything but 24K maps now.
    blackcloud08[OP] likes this.
  15. Nov 12, 2017 at 3:50 PM
    #35
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I don't use the Garmin topo maps, so someone who does will have to answer. The maps I use list the FS number or both a name and a FS number but it seems to depend on the source for the map. Since OpenStreetsMaps is what maps I use it's usually both.
  16. Nov 12, 2017 at 3:56 PM
    #36
    blackcloud08
    WNC
    I think a handheld Garmin with 24k maps is the way I’m leaning.
    dziner likes this.
  17. Nov 12, 2017 at 5:49 PM
    #37
    blackcloud08
    WNC
    Would Garmin have more detailed maps than the factory navigation?
  18. Nov 12, 2017 at 5:52 PM
    #38
    ramonortiz55
    Ramon
    Texas
    stock
    factory? as in the Tacoma navigation?
  19. Nov 12, 2017 at 5:54 PM
    #39
    blackcloud08
    WNC
    Yes.
  20. Nov 12, 2017 at 5:58 PM
    #40
    ramonortiz55
    Ramon
    Texas
    stock
    Definitely.
