Handling at highway speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vols, Aug 3, 2015.
  1. Aug 3, 2015 at 9:51 AM
    Vols
    Vols [OP] Well-Known Member
    Mid TN
    Anybody notice their steering wheel feels jerky of sensitive starting about 60 mph. For being a brand new truck think it should handle better.
  2. Aug 3, 2015 at 9:55 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Go get an alignment. You have stock suspension?
  3. Aug 3, 2015 at 9:56 AM
    Vols
    Mid TN
    Yes. I have stock suspension. Last oil change they said they re aligned it. Doesn't seem to drive any better. Didn't know if this was a common problem or just my truck.
  4. Aug 3, 2015 at 10:03 AM
    Crom
    Nick
    San Diego, CA
    Millions
    It should drive great. I would get a new alignment and make sure they deliver to you the report showing the numbers pre and post. Low caster values result in twitchy handling at interstate speeds.
    Vols[OP] likes this.
  5. Aug 3, 2015 at 11:24 AM
    Vols
    Mid TN
    Ok. Next oil change I'll get em to check it out. Thanks man
  6. Aug 3, 2015 at 4:03 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    Driving my '13 home (about an hour) after purchase scared the hell out of me. Truck drifted all over the place driving down the highway. After about 10k miles it either settled down or I got used to it.
  7. Aug 4, 2015 at 3:36 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    My current Tacoma is the 4th I've owned. That said, there was a 10 year gap between this one and the previous one. During that time, I drove an '04 Dodge 2500 Quad cab, long bed, 4wd, Hemi/Auto gas guzzling, school bus handling tank. I always ADORED my Toyotas, so when the Dodge got smashed in a wreck, my first instinct was to go find me another Tacoma! And I did. Got a real bargain on a VERY low mileage 2011. On the drive how, I though, "DANG! There's something wrong with this truck".....Steering seemed kinda "nervous" at highway speeds.
    a few days and a 1000 miles later, it drives like a dream. It just took a few days to get used to driving something that had some feel of the road.....The Dodge most definitely DIDN'T.
  8. Aug 4, 2015 at 4:02 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    My 2011 is the same way. At first it was a little interesting getting used to it, but after a few days everything was ok. It does like to hug any little bump and dip though and follow all the imperfections in the road. Like others said though, get them to show you a before and after report for the alignment next time you get it checked out. Something may just be a tad off. It may be within spec, but right at the edge. A report will give everyone else here with more knowledge a better view of things.
  9. Aug 4, 2015 at 5:28 AM
    mrothwell
    mrothwell Well-Known Member
    Raleigh, NC
    2014 4x4 V6 TRD Sport 6-Speed!
    Bone Stock.
    For some reason, they specify no toe in the alignment specs. I asked for a little bit of toe at the dealership (1/16") and it tracks better on the highway now. I'd really like more caster too, to make the steering heavier, but no one will set it outside the factory specs. Eventually I'm going to try going to a race/tuner shop to see if they'll set the caster higher, or maybe get a set of the light racing control arms to allow even higher caster numbers.
    Crom likes this.
  10. Aug 4, 2015 at 8:08 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Check your tire pressure (COLD, no driving, no sun on tires). Try 33-front, 30-rear.
  11. Aug 7, 2015 at 11:54 PM
    Vols
    Mid TN
    Dealership must've messed up the alignment, took it to a local shop and it's driving good now.
    DoorDing and Crom like this.
  12. Aug 8, 2015 at 12:00 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I misread the title and thought it said handling at high speeds. My truck handles better at 90 than it does at 60. At 60, it will do everything it can to find the grooves in the highway.
    Glad you were able to find someone to fix it. Not always the trucks fault, sometimes it's an idjit with a wrench.
  13. Aug 8, 2015 at 10:40 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Glad you got it fixed. Was about to recommend checking tire/wheel balance as that's a known issue for Tacomas.
  14. Aug 8, 2015 at 11:08 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    I bought my truck just outside Boston and drove it across the state back home. It did great.
  15. Aug 8, 2015 at 4:53 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Check your alignment, just had mine in for an oil change, alignment was out.
    I could tell something was wrong, could feel it at about 60 mph, thought it might be an out of balance tire.
  16. Aug 16, 2015 at 7:51 PM
    Vols
    Mid TN
    Drives like a dream now that alignment is fixed. Hit about 117 going down hill today. Handles great even at that high speed now.
  17. Aug 16, 2015 at 8:01 PM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Yikes! But good to know it's still handles at that speed.
  18. Aug 16, 2015 at 8:08 PM
    Vols
    Mid TN
    Had to see what it would do once lol
  19. Aug 17, 2015 at 7:57 AM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Just curious, did you happen to notice your rpms at 117? Mine will never get there.
  20. Aug 17, 2015 at 8:37 AM
    Vols
    Mid TN
    About 4700. It was 117 or 112. Can't remember for sure.
