handling problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluebeast, May 16, 2010.
  1. May 16, 2010 at 12:41 PM
    bluebeast
    bluebeast [OP] Active Member
    06 bluebeast
    smitty bulls bar procomp 3in lift westin nerf bars
    i just got my truck lifted 3 inch with the procomp set up. springs and shocks in the front and aal and shocks in the rear. i running on 18s with 295 65 goodyear duratrac. the truck has been align with the 3 inch lift and the tires been balance. it seem sometime when i drive i have little control over the handling. everytime it hits a bump on the road, i can feel the truck and the steering going out of control and sometime i even think that the truck is hoping when i hit pot holes. is there anything out there i can use to minimize this problem
  2. May 16, 2010 at 2:38 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Do you have stock UCA's? It's hard to get a tacoma with a 3" lift aligned properly without aftermarket UCA's. Did the shop that aligned it give you an alignment spec sheet? Did they mention that they had difficulty aligning it properly?
  3. May 16, 2010 at 2:40 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    I had the same prob but it turned out to be just my alignment. Not sure whats wrong in your situation
  4. May 16, 2010 at 4:31 PM
    bluebeast
    06 bluebeast
    i have stock uca. my steering does not pull to the right or left. anymore input will be helpful
  5. May 16, 2010 at 4:38 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    UCA's are needed to get the alignment into/closer to spec and it will reduce the bumpsteer
  6. May 16, 2010 at 4:42 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    wider wheel offset has seemed to add a shit-ton of bump steer to my truck. Going from 5" backspaces wheels to 4.5" backspace wheels added a ton for some reason. But UCAs will help a bit.
