Hanger Pins on Leaf Springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by eviele, Oct 30, 2011.
  1. Oct 30, 2011 at 1:12 PM
    eviele
    eviele [OP] Well-Known Member
    Hello all.
    I spent yesterday trying to install new leaf springs with AAL's. Like a lot of others in the Northeast it seems my Hanger Pin is frozen in the metal sleeve of the rubber bushing.
    PB Blaster, Impact Wrench and lots of cursing to no avail. :mad:
    Cutting the pin will be my next approach, but I'd like to replace it with a greasable pin. Any ideas where to get that?
    I've poked around the interweb, but without much luck.
    This is all I've found so far:
    http://www.northwestoffroad.com/parts/shackles_tierod.php
    N76160
    Any other suggestions?
    Thanks everyone...
  2. Oct 30, 2011 at 1:16 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
  3. Oct 30, 2011 at 1:17 PM
    jrich44
    jrich44 Well-Known Member
    96 Tacoma 2.7L
  4. Oct 30, 2011 at 3:41 PM
    eviele
    Hmmm...
    But then I'd have to replace the bushings I already have in the leafs, no?
    Never thought of that. The stock bushings probably wouldn't allow for a greasable pin.
    Gonna hafta do some searching. Not sure how I'd remove the stock bushings. Drill them out? That must be some tough rubber...
    Anyway, thank you both.
    I'll see if that's a job I can manage myself.
  5. Oct 30, 2011 at 3:49 PM
    JDMcQ
    You will likely destroy the bushings getting the sleeve with the bolt stuck in it out. Probably a pain in the ass, but the right way to do it.
  6. Oct 30, 2011 at 4:16 PM
    eviele
    Well, I cheated. I have leafs on the truck of course, but bought a used second pair in great shape that I put the AAL's on.
    My goal was to just swap out the old for the new.
    Now, the new needs to have the bushings removed so I could add a greasable pin and I'm not real sure how to do that.
    Any ideas how to go about it?
  7. Oct 30, 2011 at 4:20 PM
    JDMcQ
    Torch?
  8. Oct 30, 2011 at 4:20 PM
    JDMcQ
    I am going to use a press or a big C-Clamp.
