Hankook Dynapro ATM RF10s in LT or P metric size
Discussion in 'Wheels & Tires' started by andrew7940, Dec 3, 2011.
  1. Dec 3, 2011 at 9:24 PM
    andrew7940
    andrew7940 [OP] Well-Known Member
    Andrew
    Lousiville, KY & Charleston, WV
    06 DB CAB TRD Sport 6speed
    Kenwood DNX 573s, ICON lift kit with Dakars,
    I have a stock 06 TRD Sport and was looking at getting the Dynapro ATM RF10s based off of what I have read on this site. However, I'm not sure if I should get the P metric size in 265/70/17 or LT 265/70/17. I drive a lot of city and some off roading when I go hunting and just for fun. I'm looking for something that will be good both on road and off road but that won't be too stuff for the weight of my truck, any advice would be appreciated.
  2. Dec 3, 2011 at 9:25 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You'll be fine with P rated if you aren't climbing all over rocks .
    Your ride will be less stiff on road as well .
  3. Dec 3, 2011 at 10:58 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    P is 'normal' and LT is extra heavy duty... what ever your budget allows. I have yet to see long term mileage ratings for either... I have 12,000 miles on my P rated and they are doing just fine.
  4. Dec 4, 2011 at 12:04 AM
    OZ-T
    Peter North
    British Columbia
    LT is also E rated , so stiffer ride
  5. Dec 4, 2011 at 4:12 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2
  6. Dec 4, 2011 at 5:53 PM
    DNG
    DNG Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    LT tires are also heavier. Heavier = less mpg
  7. Dec 27, 2011 at 5:48 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    anyone have any info on the tread life warrenty, there website says 50,000 ( pretty sweet) but when i look at them through a retailer it doesn't mention it
  8. Dec 27, 2011 at 5:51 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Been using "P" s in the Nevada desert for a while now. No problems here. Also, p's are lighter which equals better mpg's. Prolly not noticeable though.
  9. Dec 27, 2011 at 5:55 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Got them as gift for christmas just looking into them a little more and discovered the warranty on the site. Just thought I would ask if anyone else noticed this
  10. Dec 27, 2011 at 6:11 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I've loaded the piss out of my truck with the P rated tires and they held up okay. I would say if you are going to be carrying heavy loads consistently then consider a different load rating but if the majority of your time is spent on the road with some light off road duty then the P rating will suit you just fine. Also, I have 22k miles on my set with little signs of wear.
  11. Dec 27, 2011 at 6:16 AM
    FIRTH4X4
    FIRTH4X4 Well-Known Member
    Eric
    Wyoming
    98 Taco 2.7L 5spd
  12. Dec 27, 2011 at 6:30 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    no one cares about the warranty :( lol
  13. Dec 27, 2011 at 7:37 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Warranty means very little these days since it is a pain to get it honored.
    Typically you get a warranty on P rated but I have yet to see a LT tire with a warranty since most commercial trucks would run them then.
    I had a set of bridgestones that they would not warranty with obvious problems. I also have a tacoma that they will not warranty with know problems.
    Just go by peoples reviews and see if they tire and price meets your goals.
    I have the Hankook ATM and cannot say anything bad about them besides them saying hankook. BFG just looks better but I can live with that.
    Dealers will honor factory warranty but they have to send in the tires now adays and cover the cost until they get the kick back from the manufacturer for the defect. Downside is most dealers will not warranty them unless it is a for sure problem with the manufactorer and not from the customer. That is why I said the warranty is pointless, look at the link and read what they can state the problem is which would not be under warranty.
    http://www.hankooktireusa.com/Serv/Warranty.aspx?pageNum=3&subNum=1&ChildNum=1
  14. Dec 27, 2011 at 7:49 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Lj97gm,
    Thank you for the info. I got the tires for Christmas present and I was looking through the info from Dunn Tire and it did not mention the tread warranty that is listed on the hankook website for 50,000. I didnt know if this is something I should bring up when I go to put them on?
  15. Dec 27, 2011 at 5:40 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    I have the 265-70-16LT's with 42k on them and they're wearing very well. New, they had 16/32" tread depth and now they're at 9.5-10 32nds. I'll be buying them again but in P-metric.
  16. Dec 27, 2011 at 5:52 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
  17. Dec 27, 2011 at 6:10 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    when i got mine the guy(dad has known him for a long time) did say about a warranty.it is pro rated for what they give to the 32nds left on the tire.but it sounded like a no hassle deal with my guy.never needed to use it though so not a 100%
  18. Dec 27, 2011 at 6:20 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    The warranty hankook has is like any other tire warranty out there. It is warranted down to the last 2/32 and then considered dead.
    As I stated the warranty is up the manufacture in the end. If you take your tire to a tire shop they have to send in the tire with a valid and 100% correct fault against the manufacturer. If the manufacturer rejects the claim the tire shop is the loser, this is why they are very picky on which tires they will state are faulty under warranty.
    You have to keep them rotated, properly inflated, etc etc. They will reject some for tire wear and state it is an aggressive driver and so on. Tire checking and cracking is covered typically for the first 3-5 years depending on manufacturer. Most will state a tire gets louder over time as well and will not see it as a valid reason unless the noise is very excessive.
    The easy was to change out a tire is a broken belt, tread seperation, large crack, chunks falling off. These are not terribly common but they do happen.
    By a tire based on your needs and cost not on the manufacturer warranty is what I am stating.
