Hankook Dynapro ATM wear update
Discussion in 'Wheels & Tires' started by Badwin45, Dec 3, 2010.
  1. Dec 3, 2010 at 7:00 AM
    Badwin45
    Badwin45 [OP] Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    FWIW...
    I bought a set of gently used Dynapro ATM's in 265-70-16LT's from another member here about 3 months ago and have been tracking the tread depth for giggles.
    The tires had approximately 7K miles on them when I bought them and 13.5/32 of tread remaining. Since then, I've put 7300 miles on them myself. As of last night, I have 12/32 of tread left.
    Running the calc's, that means the tread is wearing down at a rate of approximately 1/32 every 5k miles. If wear continues at that rate, I should get another 50k out of the tires. (replacing at 2/32 remaining tread) That would yield about 64k miles for these tires. (fingers crossed) Wear across the tread has been very even so far.
    I try to drive fairly gently and not mash either pedal to the floor so my results may not be typical.
    UPDATE: 6/26/12
    As of this afternoon, these tires still have 7/32 tread remaining and have approximately 61K miles on them. Since the first post I've put about 41k miles on them and worn the tread down 5/32. That calc's to approximately 8200 miles per 1/32" of wear.
  2. Dec 3, 2010 at 7:08 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Glad to hear it. I put 265/75r16's on mine. So far I love them but it's only been a few hundred miles.
  3. Dec 3, 2010 at 10:59 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    This sounds great... I am considering them as an inexpensive replacement for the Rugged Fails because the economy is still in the crapper and I don't think I can afford the General Grabbers I have been wanting!
    How is the highway noise (if any)?
  4. Dec 3, 2010 at 11:38 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    I've got 11K on my ATM's (P 265/75-16) and have nothing bad to say about them. I've had my Prerunner in about 5" of fresh snow with no problems, gravel roads are no problem and a few fairly high speed runs in the high desert gave no issues. They pack up a bit in the mud and pick up a lot of rocks (don't most all terrains?) but that's all I can complain about.
    They are quieter than the All Terrains a friend has on her 06 Tundra (same size) and seem to work better off road. I go places with my 2wd that she struggles with in 4wd.
    I tried to measure tread wear at 5K but there wasn't enuf wear to measure and they look the same now as they did then. As a side note the worst tire took 2 3/4oz total (inside and outside combined) to balance. As a Tire Rack installer I see much worse on "high end" car tires mounted on OE rims from Porsche, M/B and BMW.
    Overall I'd buy them again w/o hesitation. Next time (if they wear out before I get a new truck) I'll stick with the stock 265/70 as the ATM's seem to run a bit tall and the truck wants to downshift a lot more than before. Lost almost 400rpm at cruise speed, just enuf to put it below the torque curve.
  5. Dec 3, 2010 at 12:09 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I've got 25k on my Dynapros and they show basically no signs of wear.
  6. Dec 3, 2010 at 7:01 PM
    Badwin45
    OKC
    They're noisier than the dunflops that came on the truck but I'd say they're not much different than the Firestone Destination AT's I have on my other truck or the old style Dueller AT's I ran for 6 years before that.
  7. Dec 4, 2010 at 5:10 AM
    David K
    OK... as long as they are not like the Cooper STTs I had on my '05! Wow!
  8. Jun 27, 2012 at 1:20 PM
    Badwin45
    OKC
  9. Jun 27, 2012 at 2:59 PM
    David K
    What does that (BTT) mean?
    Since you bumped this up from Dec. 2010, I might as well add (for those who had not yet seen my other Hankook posts) that I did get the Dynapros put on in Feb. 2011 and have basically really liked them a lot.
    They now have almost 20,000 miles on them, the wear is minimal, and someone I know just saw them, and thought they were new! The BFGs were ready to be replaced at 20,000 miles... and these Hankooks have only just begun to live!:cool:
  10. Jun 27, 2012 at 3:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Back to ( the ) top ?
  11. Jun 27, 2012 at 3:27 PM
    David K
    Thank you OZ-T! I am sure that's it... BTTT (Bump To The Top) would also work, eh?
  12. Jun 27, 2012 at 3:45 PM
    Badwin45
    OKC
    The OZ has it!
  13. Jun 27, 2012 at 3:48 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I have a little over 30k on mine and rotate them at every oil change. I am starting to see some wear and they are getting noisey now. To me they are still in good shape. My daughter complains it is noisey when she drives it. Who cares, it is a truck. Still not as noisey as my old ford was with the mudders on it.
  14. Jul 18, 2012 at 2:46 PM
    Badwin45
    OKC
    Update 7/18/12
    I lost a tire this morning. I was driving at low speed, say 30 mph when the TPMS indicator lit up. I pulled over as quickly as I could to assess the situation and found that the left front had split at the sidewall just below the shoulder. I bought the tires used but while I have had them, they've never been driven significantly under inflated, been overloaded or suffered an impact. Approximate mileage on the tire is 62k.
  15. Jul 18, 2012 at 2:52 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    That sucks, but it looks like maybe whoever had them before you didn't keep them inflated or abused them. I've got the same tires, maybe about 25,000 on them. I'll be keeping an eye out for that type of damage.
  16. Jul 18, 2012 at 3:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  17. Jul 18, 2012 at 4:38 PM
    Badwin45
    OKC
    I dunno but I've put 50K on them since I bought them for $175/set so I'd say that I more than got my money's worth out of them. I paid $172 OTD for the replacement in P-metric! (before anyone howls, I'll be replacing the remaining tires with p-metric soon)
    I noticed the cracks starting quite a while before this but the depth was less than 1/8" on the one that failed so I decided to monitor it and keep driving.
  18. Jul 18, 2012 at 4:43 PM
    OZ-T
    Peter North
    British Columbia
    X2
  19. Jul 18, 2012 at 4:45 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    What tire pressure do you run?
  20. Jul 18, 2012 at 10:24 PM
    Badwin45
    OKC
    32 psi
