Hankook Dynapro ATM wear update
Discussion in 'Wheels & Tires' started by Badwin45, Dec 3, 2010.
  1. Jul 19, 2012 at 4:37 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Hmm, just a theory, but I would call that a little underinflated for the p-series, which probably means definitely underinflated for the LT series. You would have significant sidewall flex at that pressure In the p-series. The LT would show less flex due to the thicker ply, but the sidewall is still less stiff than designed for at that pressure. What's the max pressure listed on the LT? The p-series is 44 psi. I run mine around 37 or 38.
  2. Jul 19, 2012 at 7:26 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Wut
    My LT275/70/17 ATm's have a max inflation of 80 psi , you think I should have them at like 70 psi ?
  3. Jul 19, 2012 at 7:32 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Chalk test is the best way to determine ideal PSI. 37-38 strikes me as a bit high. Mine were about 33 when i did the chalk test.
  4. Jul 19, 2012 at 9:19 AM
    Badwin45
    Badwin45 [OP] Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    At 32 psi, mine are wearing very slightly more in the center.
  5. Jul 19, 2012 at 1:05 PM
    Polymerhead
    Missouri
    Nope, but if the max is 77 then 32 might be a little light, don't you think?
  6. Jul 19, 2012 at 1:15 PM
    Polymerhead
    Missouri
    I'll say it again - the chalk test wont show underinflation until it's so severe that you lose ground contact. That's why it works with overinflation - because the edges of the tire aren't actually touching the ground. Think about it - you would have to be severely underinflated for the center of your tires to not touch. My dcsb showed significant sidewall buckling at 32 psi. I don't know how anyone can look at a tire like that and think it's OK to run a tire that looks half flat for daily driving. Of course the sidewall is going to go first.
  7. Jul 19, 2012 at 1:22 PM
    OZ-T
    Peter North
    British Columbia
    Mine run and wear great at 36
  8. Jul 19, 2012 at 2:39 PM
    Badwin45
    OKC
    Given that the "tire and loading information" sticker on my door jamb says 30 psi and my experience running my 1st gen taco for 12 yrs at the recommended 27-29 psi w/o problems, I b'lieve I'll be just fine.
  9. Jul 19, 2012 at 2:44 PM
    OZ-T
    Peter North
    British Columbia
    that's only relevant to the OEM tires
  10. Jul 19, 2012 at 3:24 PM
    Polymerhead
    Missouri
    x2.
  11. Jul 19, 2012 at 4:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Nope. It just means if your vehicle weight is at the tire's max rated load, you then need to pump up the pressure to 77 psi.
    According to a few other members here, 35 psi on the P-metric Dynapro ATm already shows faster center wear. That tire is designed to run with the sidewall bowed out.
  12. Jul 19, 2012 at 4:05 PM
    Polymerhead
    Missouri
    ...until the sidewall fails, apparently.
  13. Jul 19, 2012 at 4:06 PM
    KenLyns
    Belly of the Beast
    ^OP got 14,000 more miles out of them than warranty.
    Are the cracks just limited to this one tire, or are they showing on the other three?
  14. Jul 19, 2012 at 4:09 PM
    Polymerhead
    Missouri
    At any rate, I can't believe he continued to run them with those cracks. It looks like they're around the entire tire! That seems like a really good way to have a blowout.
  15. Jul 19, 2012 at 4:10 PM
    #35
    OZ-T
    Peter North
    British Columbia
    I agree , OP got his money's worth outta that set of boots
  16. Jul 19, 2012 at 4:12 PM
    #36
    Polymerhead
    Missouri
    Absolutely he did. I don't think I ever got even 40k miles out of a set in my Mustang, but that was mostly poor (fun) driving habits. I'm still on my first set in my Taco, if you don't count the 5k miles I had dunflops on it.
  17. Jul 19, 2012 at 4:21 PM
    #37
    Superdavert
    Superdavert Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    MB Legacy wheels 285/70 17 BFG KO2s ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock
    I have p-rated ATm's, and I run 38 front, 35 rear. 15,000 miles on the and they're wearing great. Still like new. Of course, I don't have as much side wall as you guys since I have 20's.
  18. Jul 19, 2012 at 5:27 PM
    #38
    Badwin45
    OKC
    It was just the one tire and I monitored it every time I rotated my tires. Like I said, it was less than 1/8" deep when I checked it last. I will note that there weren't nearly that many cracks in the sidewall.
    The tire placard in the door jamb says 30 PSI, the owner's manual says 30 psi for the 245/75/16's and 32 psi for 265/70/16. The manufacturer's website says follow the vehicle's tire placard but it also states that 90% of max inflation pressure is optimal.
    Color me confused. :confused:
  19. Jul 19, 2012 at 5:39 PM
    #39
    KenLyns
    Belly of the Beast
    ^Doorjamb sticker applies to the OEM tires only. The TX Baja trucks with the LT-rated BFG AT KOs would have a higher pressure on the sticker... and the TPMS would have been calibrated for that higher pressure.
    The fact only one tire out of the four developed cracks suggests either a manufacturing defect or some prior damage. If it's simply age or underinflation, you'd expect all four to develop cracks.
  20. Jul 19, 2012 at 5:55 PM
    #40
    mike1025
    mike1025 Well-Known Member
    mike
    Oceanside, Ca
    08 DCLB 4x4 SR5
    Firestone ride-rites airbag, bed speakers, bull bar and 14" light bar
    Same except I run 36 rear and only have 10k miles on them, they are wearing great(and by that I mean not at all :D)
