Hankook Dynapro ATM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KevC, Jan 9, 2018.
  1. May 31, 2019 at 9:55 AM
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Might be better off with the Falkens then eh ?
  2. May 31, 2019 at 10:00 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Ive never run the Falkens so I dont know about them.
  3. May 31, 2019 at 10:00 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    What did you replace the hankooks with? Thanks
  4. May 31, 2019 at 10:04 AM
    Fclarke1982
    Fclarke1982 Well-Known Member
    Frankie
    2018 Tacoma TRD OR
    I have had both. Falkens are much better overall IMO
    Hank Heel and mgmdclb like this.
  5. May 31, 2019 at 10:32 AM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Michelin Defender LTX
    TacomaSport86[QUOTED] likes this.
  6. May 31, 2019 at 10:37 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I have these on my 2nd gen. I've got about 65,000 miles on them and I probably can get about 20k more miles. They wear great, balance well, low road noise, long life. I've had good experience with offroad grip in sand, rock, snow, and rain. The sipening in a bit tight so they don't clean out well in the mud.
    They're overall a great tire.
    Yes, they did run tall for me. I had crazy rubbing, but if you remove your front mud flaps, the rubbing goes away as well as replacing the front radiator support bushings helped with the rubbing.
    My main and only issue with them is that the sidewall is quite thin. I worry about airing them down and getting too much of a sidewall buldge and getting a sidewall failure. They even look low when aired at 35 PSI because of the sidewall buldge.
  7. May 31, 2019 at 11:34 AM
    maximum
    maximum Well-Known Member
    Works for me and it was readily available at the local tire shop. I'm no tire connoisseur so I have no technical comments on their performance.:)
    mgmdclb[QUOTED] likes this.
  8. May 31, 2019 at 12:15 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    i had the atm's for a while. I thought they were ok. I then regularly started going up to a friends house to shoot pool, and he lives several miles up a steep mountain road, that is heavily forested and never sees sun, and hence very snowy and icy right through winter. I would slip and slide all over the place on that road. Him and his wife both have tacomas, and both run duratracs. I dumped my hankooks and got a set of those. The difference was night and day. Expensive tires, but worth it for me. I've had them almost two years now, and they still look brand new. Very happy with them.
