Hannemann fenders on stock 4x4?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vroomy, May 19, 2011.
  1. May 19, 2011 at 7:24 PM
    vroomy
    vroomy [OP] Member
    01 Hilux
    hey new here, im from Australia and have just bought a set of Hannemann 4" glass fenders and bedsides. Im wanting to know if anyone else has installed these on a stock 4x4 pickup? i dont have a long travel front end so it doesnt have the extra width and im curious if it may look a little silly? i basically got them to run 33" tires with no lift, but now ive got them the look really wide.... has anyone got some pics or opinions for input? will be greatly appreciated
  2. May 19, 2011 at 7:46 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Welcome to TW!!!
    I have the Hannemann fenders and bedsides. I have the rear LT done but not the front. I'm not running anything wider in the rear. Just the factory axle but certainly needed the fenders because of the amount of uptravel.
    Up front I just have a set of coilovers and TC UCA's, but same width as factory.
    Here's a couple pix. Loads of pix in my build if you want to see more
  3. May 19, 2011 at 10:46 PM
    vroomy
    vroomy [OP] Member
    01 Hilux
    awesome looking truck you got there! my fenders are slightly different, i got the 'flat top' ones. Looking at them i reckon they will over hang about 2" past the tire, do you think that will look ok? what width are your rims 8 or 9's? also are you familiar with our version of the Tacoma they are badged as a Hilux, its an 01 model but they still run the torsion bar front end im curious if they is anyone doing a kit to convert them to a coil-over suspension?
  4. May 20, 2011 at 7:28 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    my truck long ago... these are my old glassworks 3.5" fenders
    my wheels have 4.5" backspacing, thats why they tuck in so far in the wheel well. if you run a wheel with less back space then the wheel and tire will stick out more
  5. May 20, 2011 at 8:03 AM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    On stock height with stock size tires, I dont think it will look good. While the two people who posted pics have stock width front track, they're at least lifted, so it gives you a different look.
  6. May 20, 2011 at 8:15 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    bingo.
  7. May 20, 2011 at 8:51 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Thanks. My wheels are 8" wide with a 4" backspace. If you get a wheel with less backspacing it will push the tires out more and kinda level it with the fenders. I think you'll need to put a lift on though to clear 33's.
    I'm not too familiar with Hilux. But a torsion bar is a torsion bar. You can crank down on those and bring the front end up. Ride quality will go to shit and you will lose down travel. Torsion suspension is certainly not my specialty though.
  8. May 20, 2011 at 11:48 PM
    vroomy
    vroomy [OP] Member
    01 Hilux
    what about wheel spacers? are they an ok idea the widen the wheelbase or do they cause problems?
  9. May 21, 2011 at 11:36 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    :rolleyes:
  10. May 22, 2011 at 11:47 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    lol that would cost more than a set of fenders:p
  11. May 22, 2011 at 9:38 PM
    TACOtuesday 21
    TACOtuesday 21 Member
    nick
    alpine,ca
    '97 4x4 extra cab
    fabtech coilovers, flowmaster exhaust, 31'' bfg's, HID headlights, 2 12'' kicker CVR's, deckplate mod
    i have flares on my 4x4 and all i have done is 2.5'' in front with fabtech coilovers
  12. May 22, 2011 at 9:47 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    they are fine, a lot of different opinions but if you install them correctly and maintain them they will be fine.
  13. May 22, 2011 at 9:50 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I would imagine that spidertrax would work with the hilux. I run a set myself and have no issues whatsoever.
    Make sure you get a wheel adapter and not just a wheel spacer. An adapter spaces the wheel out by attaching itself to the hub and then the rim via a second set of studs and lug nuts. A spacer simply slides over the existing studs and can cause some issues if your studs aren't long enough.
