Harbor Freight 10% jacks/stands
Discussion in 'Deals & Coupons' started by muddog321, May 12, 2023.
  1. May 12, 2023 at 2:00 AM
    muddog321
    muddog321 [OP] Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Thur 5/14 Sunday coupon code 37943595 for 10% off any single jack or jack stands.
    Take your wife to get both if you can drag her into the store ha ha.
    TRDRed likes this.
  2. May 12, 2023 at 5:23 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    It's too bad they don't carry high jack stands. Normal height are just a few inches too low for some of my needs when working under the truck. Ama-zon has a pair of 10 ton high jacks for $315 but that's the best price I've seen.
  3. May 12, 2023 at 5:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    These suckers have 30" of height, that's not enough?
    japjoe7 and SR-71A like this.
  4. May 12, 2023 at 5:50 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Ive got the new 3 ton set. Typically need a slab or two of 2x10 under each when Im working on the truck.
    NorrinRadd[QUOTED] likes this.
  5. May 23, 2023 at 6:50 PM
    BulletsBurritosBeagles
    BulletsBurritosBeagles Well-Known Member
    ‘18 TRD OR SB
    Use the money you save to up your life insurance!
    /s I'm sure they are fine for the weekend warrior
