Harbor Freight $10 Off Road Lights
Discussion in 'Lighting' started by goufcustom, Jul 27, 2012.
  1. Sep 17, 2012 at 10:40 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    FWIW; I would put a relay in the system. I don't like the idea of a 20A switch running into my cab. Keep the high current out of the cab, install a relay under the hood and use the switch or an OE style switch to control them.
  2. Sep 17, 2012 at 10:54 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Looks like they may be decent on a front bumper mounted lightbar. Depending on how bright they are. If the housings are decent it would be a good platform for an HID retofit maybe
  3. Sep 17, 2012 at 11:02 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
  4. Sep 23, 2012 at 1:31 PM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    I got them sorta wired in today, but only one light of the two works... Looks like they are coming out and going back to HF. You get what you pay for, like many of you have already said. I am going to try the one out when it gets dark, but will be taking them out very soon.
  5. Sep 29, 2012 at 3:17 PM
    anotherreject
    anotherreject Well-Known Member
    i bought 2 of the $10.00 lights about 9 months ago. there are lots of reviews where people added water proofing and spray painted them to stop rust. i just spray painted mine black and i have no rust on them. a tiny bit of water has seeped in someplace and they have a little water inside them. so far they are holding up, i rarely use them, like the OP i just wanted some lights that looked cool and i could still use once in a while. they are not very bright.
  6. Sep 30, 2012 at 7:13 PM
    goufcustom
    MD
    So I got them wired up, what a pain that was, but not really by any fault of the lights.
    SO it got dark and I tried them out, first things first, only one of the lights worked, I tried a few things, and it is just a bad light.
    Just the one light, I was about 4ft from my garage door:
    With my headlights on:
    Now keep in mind that only one of the lights worked, and the light is behind my grill, and the mesh and letters get in the way. But, didnt really do a ton, since the one like was broken I didn't see the point in driving around with them. They were removed the next day, and returned for a full refund a week later. I currently just have the bracket in there and nothing else. Thinking about a set of Hellas, but not sure if I want to bother, because the grill obstructs them a lot, and I dont want to mount them on the outside, nor do I want to change my grill.
  7. Sep 30, 2012 at 7:24 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Nice good old harbor frieght
  8. Sep 30, 2012 at 7:24 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Good luck with anything harbor freight sells.
  9. Nov 13, 2012 at 4:38 PM
    goufcustom
    MD
    I returned these for a easy full refund, no questions asked after I told them that only one of the lights worked. So I took the money and ordered some Hella 500 FF Driving Lights, should be here in a week or two, backordered...
