Harbor Freight Jack Stand Recall- * Risk of Collapse 5/2020
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wabisabi, May 22, 2020.
  1. May 22, 2020 at 6:28 AM
    Wabisabi
    Wabisabi [OP] Active Member
    2012 SR5 2.7 5spd man 4x4 AC
    Hey Folks,
    Came across this online and then looks like osterhagen posted it in First Gen. Thought I would repost in 2nd Gen as well. Great weekend in NE to work on trucks, stay safe.
    Mine were 61196, had a werid feeling each time I used them, wondering if they were solid. They are going back!
    Nearly 1.7 million jack stands sold by Harbor Freight have been recalled due to risk of collapse. If you have any 6-ton or 3-ton models with the model numbers: 61196, 61197, or 56371 do not use them!
    From osterhagen post.
    https://www.roadandtrack.com/car-cu...NeY55TJFD2n5A0c2pyudT6N0oFci0t_N6wB0t1qABxEOU
    Recall 1:
    https://static.nhtsa.gov/odi/rcl/2020/RCLRPT-20E016-6561.PDF
    Recall 2:
    https://static.nhtsa.gov/odi/rcl/2020/RCLRPT-20E027-9959.PDF
  2. May 22, 2020 at 6:36 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  3. May 22, 2020 at 7:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Need to put this in the Harbor Freight thread, if it hasn't been already.
  4. May 22, 2020 at 7:12 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    HF is my go-to for last minute, one or 2 time use low torque cheap tools that I loan out to friends/neighbors when I don't expect to get back in a timely manner or ever. Isn't this a risk we all take when buying tools from HF?
  5. May 22, 2020 at 7:17 AM
    bradyv
    bradyv Adventure Enthusiast
    Brady
    2020 TRD OR DCSB 4x4
    Thanks for the heads up! Shared this with my father and he had 2 stands that were part of the recall. Appreciate it dude
