Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Mar 6, 2018 at 5:04 PM
    #2481
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I have one - and I'm pretty sure I paid less than $29.
    I wouldn't use it as a recovery strap as I have a kinetic rope for that. But they come in handy as an extension or tree strap. Keep it clean, dry and out of the UV - don't subject it to strong, sharp loads - and it should do OK.
    Until it breaks :p
    seniorredwood[QUOTED] likes this.
  2. Mar 6, 2018 at 5:15 PM
    #2482
    seniorredwood
    seniorredwood Assistant to the Regional Manager
    Pennsylvania
    2017 TRD Sport, 4x4, MT, DCSB, MGM.
    It snapped?? Maybe I'll return it.
  3. Mar 6, 2018 at 5:40 PM
    #2483
    Sigarmsp226
    Sigarmsp226 Well-Known Member
    Mark
    2012 Tacoma Pre-Runner SR5
    Sand Shark - What a beautiful dog. What kind is he/she?
  4. Mar 6, 2018 at 6:25 PM
    #2484
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    A spoiled one.
  5. Mar 6, 2018 at 7:41 PM
    #2485
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Anyone know if their torx sets are any good? I need to pull apart my tailgate.
  6. Mar 6, 2018 at 7:45 PM
    #2486
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Yes they're good.
    Slashaar[QUOTED] likes this.
  7. Mar 6, 2018 at 7:46 PM
    #2487
    T4RFTMFW
    T4RFTMFW Well-Known Member
    For a tailgate they’re plenty good. Those bolts thread into plastic.
    Slashaar likes this.
  8. Mar 6, 2018 at 8:10 PM
    #2488
    Slashaar
    Josh
    Kansas City, MO
    Yeah I wasn't sure about that. Thanks.
  9. Mar 7, 2018 at 12:32 PM
    #2489
    Sigarmsp226
    Mark
    Actually if he or she was spoiled they would be in the front seat not the back.....:D
  10. Mar 7, 2018 at 12:44 PM
    #2490
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    didnt see any reviews for the "industrial solder iron"
    so heres my impression after a few uses: works great and quick compared to typical pen style solder irons. i used the thin solder that came with and havent had any issues with it melting fast. although the actual tip that heats up would bend as if it was getting too hot while heating up the wire and holding it down. its not anything crazy bent but i would try to heat it the other way every other time. it does come with 2 spare tips as well.
    overall easy to use and works well.
  11. Mar 7, 2018 at 1:05 PM
    #2491
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    I have bought the torque wrenches from the 1/4 up to the size 1/2 Drive. We have a torque wrench calibrate verify machine at work and the HF wrenches were not off by much considering the price. In a range of 20fb -120 it was only off by 1-2 fb. good enough for home mechanic work IMO.
    KaptainH and CurtB like this.
  12. Mar 8, 2018 at 12:13 PM
    #2492
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    Thanks...Oliver is a Labradoodle. He is spoiled rotten. My "bad 'ole puppers".
  13. Mar 17, 2018 at 11:59 AM
    #2493
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    25% off coupons for Easter weekend are out.
    :playball:
    wilcam47 likes this.
  14. Mar 17, 2018 at 12:05 PM
    #2494
    koditten
    Kirk
    Central Michigan
    I want to know when the trailers are going to be out? This recall BS is harsh!
  15. Mar 17, 2018 at 1:07 PM
    #2495
    koditten
    Kirk
    Central Michigan
    I don't think they are almost the same. With the coupon HF offered, the trailers could be bought for $270 out the door.
  16. Mar 19, 2018 at 9:39 AM
    #2496
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    Anyone use this? Doing brakes this weekend, most likely by myself...
  17. Mar 19, 2018 at 9:45 AM
    #2497
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Yeah, I have it... Works pretty good and makes the process much quicker/ easier / cleaner... It will help ALOT if you put some teflon tape on the threads of the bleed nipples as air likes to come through there. I usually finish up with a few pumps of the old brake pedal method and all is good.
    How about the gas chain saw? anyone have experience with it? : I will just be using it camping it won't be seeing heavy use. Wish they had a 14'' or 16'' version
    SeanBonham[QUOTED] likes this.
  18. Mar 19, 2018 at 9:47 AM
    #2498
    plugnickle64
    plugnickle64 Member
    black 2010 Taco TRD Sport 4D LB
    Ranch King brush guard, Husky floor liners, Husky low profile tool box
    There is a recall on trailers?? which and how far back??
  19. Mar 19, 2018 at 9:48 AM
    #2499
    excorcist
    Reno, NV
    For the tires, not trailers themselves AFAIK.
    Speaking of that anyone take their tires off? How hard is it?
    Blackout14 likes this.
  20. Mar 19, 2018 at 10:02 AM
    #2500
    plugnickle64
    plugnickle64 Member
    What do I like about HFT?? wow, long list...My best experience was with their Hardwood flooring nailer....I was having new floors installed and found a couple of guys that were between jobs but didn't have a nailer ... I picked up 2 just in case one failed they could keep working....$99 each Long story short the first one worked great and I sold it to them for $100 and then I returned the 2nd one unopened. Boy was I happy!!!
    My worst experience has been with drill bits...After breaking way too many...dulling way too quickly no more HFT drill bits for me. My work bought a set ( I warned them)...One of our techs was using a 3/8" in a piece of aluminum and it hung up...when he reversed the drill it untwisted the bit I have never seen any other bits do that...wish I had kept the bit or at least taken a picture of it...
    I have had a HFT 4x8 trailer for 10 plus years and I have pulled that thing all over the state of Va. while my son was racing in the VCHSS plus many trips to Myrtle Beach and I pull it every week end in mowing season. Two sets of tires and lights and still going strong. I just grease it twice a year.
