Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Apr 11, 2018 at 6:58 AM
    #2741
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I got one of these at the end of last year: I've only used it a few times, but it works great. It usually goes on sale for $40.
    At that price, it is crazy not to give it a go.
  2. Apr 11, 2018 at 7:44 AM
    #2742
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I have this one also. It works and gets the job done. I have loaned it to a neighbor too. But for the occasional use it works.
    tonered[QUOTED] likes this.
  3. Apr 11, 2018 at 7:56 AM
    #2743
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I haven't had a cordless drill in over a decade and was getting desperate for an impact after screwing with a couple nuts on a crankshaft that needed a floor jack handle as a cheater on a ratchet. Smooth, right? A friend's battery powered impact was pretty impressive. My corded drill has been good enough, was cheaper, and I don't have to worry about battery packs.
    I was ready to pony up for the highest torque battery powered one that HF had, but I couldn't be pulled away from the price of that corded one. I don't mind cords most of the time these days.
    I have been meaning to test this out with the Taco's 400w plug. Some folks say that higher draws can work, sometimes. I just haven't figured out what gets tripped if I go over the limit. At 7A, that is a bit over 800w. I'm just not sure if those short pulses would trip anything or not?
    Coolerman[QUOTED] likes this.
  4. Apr 11, 2018 at 8:03 AM
    #2744
    simplehuman
    simplehuman Well-Known Member
    I'm new to this thread so apologies if this is old news.
    If you're not familiar with this guy I HIGHLY recommend him. He's an enginerd and super smart when it comes to tools. Harbor Freight (Hazard Fraught) is one of his favorite to review: https://youtu.be/jqWypTAG4Hw
    Konvict KROG likes this.
  5. Apr 11, 2018 at 9:27 AM
    #2745
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I tried to run a circle saw on the bed plug. Nothing tripped and the blade did turn but no where near as fast as it should. As soon as I tried to cut wood it just stopped.
    Konvict KROG and tonered[QUOTED] like this.
  6. Apr 11, 2018 at 9:30 AM
    #2746
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! It looks like those pull about 15A.
  7. Apr 11, 2018 at 2:54 PM
    #2747
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    If it trips, you just have to turn it back on.
    I doubt the running power is anywhere near 7A probably just starting power, HF electronics are many times grossly over-rated (like the little 2.5 hp compressor)
  8. Apr 11, 2018 at 2:56 PM
    #2748
    Konvict KROG
    Louisiana
    I did that as well. My shop vac runs at a reduced power too.
    I have used that little plug a lot, I plan to put a 2000w inverter in under the seat and wire it to that plug some day.
    tonered likes this.
  9. Apr 11, 2018 at 4:00 PM
    #2749
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Won't a 2k inverter require to be directly wired to the battery? I'm thinking you will need some heavier leads from the battery to the inverter as well to get 2k watts.
  10. Apr 11, 2018 at 5:38 PM
    #2750
    Konvict KROG
    Louisiana
    Definately
    My plan is to move the stock inverter plug to the console inside, and wire up a 2k inverter to the bed mounted plug
  11. Apr 11, 2018 at 5:41 PM
    #2751
    koditten
    Kirk
    Central Michigan
    Cool. My fear was you were gonna use the existing wires. Glad you were aware. I just wanted it to be clear to others that what you were doing would require additional wiring.
    Thanks
    K
  12. Apr 11, 2018 at 6:33 PM
    #2752
    Geeder48
    Geeder48 Well-Known Member
    Colorado Springs
    2017 Tacoma TRD Off Road
    Hefty Fab Rock Sliders
    I think I was gone before they started running that line. The only thing I can say about the welders is that we rarely if ever had any come back, but at the same time, we rarely if ever sold any either. I knew a lot of guys that would come in for the welding cart, the masks, and other welding tools and supplies, but they typically recommended spending the money and getting a quality brand name welder.
    koditten[QUOTED] likes this.
  13. Apr 11, 2018 at 6:34 PM
    #2753
    Geeder48
    Colorado Springs
    No, sorry.
  14. Apr 11, 2018 at 6:35 PM
    #2754
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Cheap welders are accessible but don’t change the price of fabricating. Most of those $100 HF welders are for ranch and farm use to booger something back together.
    Hobbyists aren’t generally buying them.. lot of associated cost with welders and supplies/reason to weld in the first place.
    BikerinBlak909 likes this.
  15. Apr 11, 2018 at 6:39 PM
    #2755
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    I'm going to pick up the omnipro220 as soon as I get new coupons mine all expired April first.
  16. Apr 11, 2018 at 7:07 PM
    #2756
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    They are somewhat close in retail price, but I'm willing to bet there's quite a bit different about them. They probably have the same profit margin, but the Rigid sells for $40 less. That's gotta come from somewhere. Mostly likely lower grade switch and electronics, cheaper motor, cheaper gears, etc. Might look similar, but I bet it much different.
  17. Apr 11, 2018 at 7:09 PM
    #2757
    T4RFTMFW
    They’re definitely not the same.
    Lower grade everything - still good, but not as good.
  18. Apr 12, 2018 at 6:55 AM
    #2758
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! I'm going to give it a try.
  19. Apr 12, 2018 at 7:32 AM
    #2759
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my 1/2 HD slow RPM drill still works great and drives in 10 in long x 1/2 lag bolts with ease, even broke a few bolts
    always use the extra handle or you will hurt something
    tonered likes this.
  20. Apr 12, 2018 at 7:38 AM
    #2760
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You know me. Ha!
