Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. May 2, 2018 at 1:35 PM
    #2881
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    So they are both red and shaped like pliers? The channel locks do look very similar, but it's still not obvious that it's the same grade of steel, same heat treat, same forging operation, etc.
  2. May 2, 2018 at 1:40 PM
    #2882
    Markcal
    Markcal [OP] Well-Known Member
    After looking at a few comments on that video, some of the people that have used them agree with you about the quality of the metal.
  3. May 2, 2018 at 2:27 PM
    #2883
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    Has anyone used the HF inner the rod tool? Doing some work on a friends CRV and thinking about trying it out.
  4. May 3, 2018 at 6:45 AM
    #2884
    Tacoma HEART
    Tacoma HEART - - - - - - -
    Sam
    AA CO
    '14 DCSB TRD S Black
    Yawn...
    Used it when I worked in car shops. Handy tool to have with the exception of cars where the inner tie rod was too close to other parts and there wasn't enough clearance. You should be alright with this and the CRV. :thumbsup:
  5. May 3, 2018 at 7:47 AM
    #2885
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    They are $11 dollars for a set of four. Who cares
    tonered and T4RFTMFW like this.
  6. May 3, 2018 at 8:19 AM
    #2886
    jowybyo
    Joe
    Baltimore, MD
    I don't. I just wouldn't say they are the equivalent of MAC pliers for cheaper. They just pliers until we confirm these things.
    Edit: For the record, I have plenty of HF stuff. It's fine. I just don't make it a habit of assuming it's as good as more expensive stuff.
  7. May 3, 2018 at 8:29 AM
    #2887
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Nice work!, Now that it's finished it's time to start over and make that thing Long Travel :bikewhoops:
  8. May 3, 2018 at 4:21 PM
    #2888
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    New acqisition, definitely an improvement.
    tonered and Lord Humongous like this.
  9. May 3, 2018 at 6:20 PM
    #2889
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I know theres mixed feeling about it...
    But if anyone participated in the class action from last year watch for your checks.
    stbear and Rakso like this.
  10. May 3, 2018 at 7:10 PM
    #2890
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    is the hercules the new model they are carrying? i have the drill master too. gets the job done but nothing to write home about
  11. May 3, 2018 at 7:49 PM
    #2891
    Lord Humongous
    AZ
    I didn't need but I picked it up anyways because MOR TOOLS! It definatley made the job easier and would recommend !
    Tacoma HEART[QUOTED] likes this.
  12. May 3, 2018 at 7:50 PM
    #2892
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    I use the drill master, have no complaints-- would you recommend the Hercules upgrade and why?
  13. May 3, 2018 at 8:23 PM
    #2893
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    They have another one in between. Drill master one too weak for my project.
  14. May 3, 2018 at 8:24 PM
    #2894
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Yes I would, because it has a more powerful motor. Proved to work better for me.
  15. May 3, 2018 at 8:30 PM
    #2895
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  16. May 4, 2018 at 7:43 AM
    #2896
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Didn't work on the tacoma when I tried it. Ended up using a clamp ring with a 3/8th adapter on it that I bought for cheap on Amazon. It works on every tie rod I have ever tried so far.
  17. May 4, 2018 at 8:20 AM
    #2897
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    The Hercules stuff looks like an improvement but I imagine there's still the issue of getting replacement parts. I can repair my Milwaukee, if the Hercules shits the bed I imagine it goes in the trash (?)
    BikerinBlak909 likes this.
  18. May 4, 2018 at 9:48 AM
    #2898
    Markcal
    I subscribe to a YouTube channel called "Red Beard and The den of Tools". One piece of advice he gave was that some brand named tools are compatible with HF brands when needing replacement parts. I post a comment on his latest video asking your question and this was his response:
    Red Beard and The Den of Tools14 minutes ago
    Getting parts from HF is usually a non issue. As in it's not an issue because it will never happen. As to parts from other brand name tools for this... its a bit early to say how much of a duplicate will be.
    Rakso likes this.
  19. May 4, 2018 at 5:20 PM
    #2899
    Lord Humongous
    AZ
    In 10 years when I go to use on my 16 Tacoma I'm probably forget this and try it:crazy:
    Bruce988jl[QUOTED] likes this.
  20. May 6, 2018 at 8:13 AM
    #2900
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I've never needed parts for any of my HF tools, but then again I don't use them every day.
    tonered likes this.
