Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Aug 5, 2018 at 10:19 AM
    #3221
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    304 is not considered a soft metal. It work hardens very easily especially when trying to do any type of hole cutting. Best to use a cobalt drill with plenty of cutting fluid or flood coolant. SFM is important but kind of tough to gauge if using a hand drill. 303 has easier machiniability but probably does not come in the material type/shape you need.
    Biscuits and Speedytech7[QUOTED] like this.
  2. Aug 5, 2018 at 10:23 AM
    #3222
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I was out of spray lube so I used some rapid tap. I'll have to get some Cobalt bits though.
    zero4[QUOTED] likes this.
  3. Aug 5, 2018 at 10:29 AM
    #3223
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Keeping it cool is most important, which means plenty of lube & not too fast. You can look up recommended SFM for the drill size & type you are using online. Once you work harden it, that's it, your bit is not going to cut anymore. You would then need to either grind the hardened area or use a carbide drill.
    Biscuits likes this.
  4. Aug 5, 2018 at 5:43 PM
    #3224
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I've got one of these cheapo blasters, it actually works fine for small projects but if you try to do much more you'll have to stop and reload it a lot.
    5Sport likes this.
  5. Aug 6, 2018 at 6:25 AM
    #3225
    NepaTaco
    NepaTaco Well-Known Member
    Rich
    Pennsylvania (NEPA)
    Black 2006 Taco
    This forum needs a section to post when your relationship marriage etc had been adversely affected or not ended up in divorce due to the time and money we spend on all the wonderful toys and mods we find here.
    Biscuits and EatSleepTacos like this.
  6. Aug 6, 2018 at 7:06 AM
    #3226
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    I bought this same blaster to use with baking soda instead of an abrasive media. It worked decent on some dirt bike wheels and hubs. Some tips, drill out the feeder tube so that it can flow better and use a water filter.
  7. Aug 6, 2018 at 11:45 AM
    #3227
    Bajatacoma
    SC
    Yep, it won't run with pool filter sand without opening it up a little; of course then you'd have to refill it even sooner. I'm only using it on small parts so I just use the silica bead blast media. I've used it on a couple of gun parts before parkerizing and it did just fine.
    Pork Chopper[QUOTED] likes this.
  8. Aug 7, 2018 at 5:53 AM
    #3228
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    Ive had this set for several years and they have worked great for me whenever I needed them.
    Thebubble likes this.
  9. Aug 7, 2018 at 6:45 AM
    #3229
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I have been sitting on a approved form 1 for a .30 cal can and those step bits look perfect for drilling the holes
  10. Aug 7, 2018 at 7:35 AM
    #3230
    Pork Chopper
    Dallas, TX
    07 DC 4x4
    Good to know cause my next project is some gun parts!
  11. Aug 9, 2018 at 8:13 PM
    #3231
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Recycled for a better use.
    up·cy·cle
    ˈəpˌsīkəl/
    verb
    past tense: upcycled; past participle: upcycled
    1. reuse (discarded objects or material) in such a way as to create a product of a higher quality or value than the original.
      "the opportunity to upcycle trash, or turn it into new products, was vast"
  12. Aug 10, 2018 at 7:08 AM
    #3232
    Bajatacoma
    SC
    I bought a box of this blast media (using a 20% off coupon of course) and so far it's worked fine. It is messy as hell though, I can't find my hood so last time I used it I wore safety glasses and a face shield, and definitely wear a mask.
  13. Aug 10, 2018 at 8:50 AM
    #3233
    Pork Chopper
    Dallas, TX
    07 DC 4x4
    Good deal, I need to buy a mask anyways so this will give me an excuse.
  14. Aug 10, 2018 at 10:40 AM
    #3234
    NepaTaco
    Rich
    Pennsylvania (NEPA)
    Black 2006 Taco
    Would this media and this work ok for blasting some taco wheels?
  15. Aug 10, 2018 at 10:54 AM
    #3235
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Yeah that will go the job. Just make sure you have a compressor
    Slashaar likes this.
  16. Aug 10, 2018 at 5:03 PM
    #3236
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    I've used the soda ( ) on motorcycle wheels with good success and you can just hose it off when done. The only issue I had was after a while it started to cake and would clog the blaster. I think once you open the bag you have to use it all.
  17. Aug 10, 2018 at 6:07 PM
    #3237
    Bajatacoma
    SC
    Did you have a dryer on your line? Harbor freight sells them as well including a disposable model. Any moisture in your lines and the stuff starts caking.
  18. Aug 17, 2018 at 8:12 PM
    #3238
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Now that the HF trailers are back, can I ask a favor of you guys? Can you scan your local adds to see if there is a coupon for the trailers?
    Thanks in advance
    Kirk
    wilcam47 likes this.
  19. Aug 17, 2018 at 9:08 PM
    #3239
    icetreye
    icetreye If I ain't lurkin', then I must be jerkin'.
    Kevin
    SoCal
    '14 BRM Prerunner TRD OffRoad
    TacomaMike37 and Biscuits like this.
  20. Aug 17, 2018 at 9:26 PM
    #3240
    koditten
    Kirk
    Central Michigan
    Thank you.
