Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Dec 18, 2016 at 9:48 AM
    #381
    Markcal
    Markcal [OP] Well-Known Member
    I like that word....*note to use it in a sentence as an adjective next time. :cheers:
    spiffy (adj.) [​IMG]
    1853, of uncertain origin, probably related to spiff "well-dressed man." Uncertain relationship to spiff (n.) "percentage allowed by drapers to their young men when they effect sale of old fashioned or undesirable stock" (1859), or to spiflicate "confound, overcome completely," a cant word from 1749 that was "common in the 19th century" [OED], preserved in American English and yielded slang spiflicated "drunk," first recorded in that sense 1902.
    TXpro4X4 likes this.
  2. Dec 18, 2016 at 9:56 AM
    #382
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Anyone use any of their winches?
  3. Dec 18, 2016 at 9:59 AM
    #383
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Not personally but there's a thread somewhere on them. Appears it's hit or miss - you can get a good one or a dud, 50/50.
    As with many other HF machine tools, a thorough disassembly, regrease and adjustment/assembly is usually the key to success.
  4. Dec 18, 2016 at 10:45 AM
    #384
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I have one of their smaller winches. The 120V one (so not for our trucks or atv's) that i use for lifting my RTT on and off. Its worked fine for the year ive had it though it only gets used a few times a year.
    I did have one issue with it but it was 100% my fault. I ended up pulling to the side (with no fairlead or anything to guide it) and it got between the spool and motor and seized up. But took it apart and reassembled and it still works just fine.
  5. Dec 18, 2016 at 10:53 AM
    #385
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I swung by Harbor Freight on my way home from work while ago. I grabbed a set of 6 ton jack stands and a set of 12 ton's....Not because I NEED 12 ton, but because of their extended height. They all have ANSI safety rating, so can't be too marginal....They'll do what I need. I've got an old set that were NAPA house brand jack stands that are roughly equivalent to the 6 ton, just shorter. That, a 4 ton and a 3 ton floor jack, 3 20 ton and 2 10 ton bottle jacks, a Snap On porta-power, and a Hi-Lift jack.....aughtta be able to lift a corner of a Tacoma when I need to!
    Nickel and Biscuits like this.
  6. Dec 18, 2016 at 10:59 AM
    #386
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Got the 12k.
    Used many many times.
    After a couple of years, I pulled it apart and regreased it, didn't look like it even needed it.
    Just had the shop guys at work install one on a flatbed trailer to load dead trucks with. Seems to be working fine as well.
    Biscuits and TXpro4X4[QUOTED] like this.
  7. Dec 18, 2016 at 11:01 AM
    #387
    Markcal
    I watch a Youtube channel by someone that recovers used riding mowers, fixes them and flips them. He attached a winch in his bed, using a battery jumpstart to power it and seem useful to have that handy, incase there was something like a riding mower you wanted to load in your bed using ramps.
  8. Dec 18, 2016 at 11:05 AM
    #388
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Where good winches set themselves apart from mediocre winches is the waterproofing. Gear drive is important, but far more of them end up not working after a dunk in a creek or a deep mud hole. Warn and some of the Smittybilt models have a good rep for water tight construction.
    Also, long sustained hard pulls have a tendency to heat 'em up and burn out motors on the less expensive brands. Use them intermittently to allow them to cool off and the life span is a little longer in most cases.
    Markcal[OP] likes this.
  9. Dec 18, 2016 at 11:10 AM
    #389
    Markcal
    The last time I went to HF my printer was low on ink and wasn't printing legibly, so I wrote everything out, including the coupon code. I told the associate about not being able to print the coupon and he said that was OK and just typed in my code to give me credit. I was always under the assumption that you needed to always print the coupon out, but just writing down the code is good enough.
  10. Dec 18, 2016 at 11:30 AM
    #390
    Harry
    Santa Fe NM
    I just pull up the coupons on my iPhone and have them scan em from there.
  11. Dec 18, 2016 at 11:31 AM
    #391
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Same here
  12. Dec 18, 2016 at 1:13 PM
    #392
    Markcal
    I'm embarrassed to admit this, but I still don't own a smartphone. :oops:
    nfs257, Nickel and Biscuits like this.
  13. Dec 18, 2016 at 1:34 PM
    #393
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I've had one for about a year, they ain't that damned smart. ;)
    Nickel and Boerseun like this.
  14. Dec 18, 2016 at 1:44 PM
    #394
    Markcal
    Someday I will join the rest of humanity in the 21 Century and drop my landline. :rolleyes:
  15. Dec 18, 2016 at 2:36 PM
    #395
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    As i tell my mother who cant use hers, "Sometimes its the user, not the smartphone."
  16. Dec 18, 2016 at 3:04 PM
    #396
    Markcal
  17. Dec 18, 2016 at 3:22 PM
    #397
    Justinlhc
    Justinlhc Not looking for a relationship
    How do you surf TW without a smartphone? :confused:
    One of those big, bulky computer board things?
    Biscuits, TXpro4X4, Thelgord and 2 others like this.
  18. Dec 18, 2016 at 4:10 PM
    #398
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    LOL
  19. Dec 18, 2016 at 4:12 PM
    #399
    Markcal
    I still have my HP desktop I bought new in 2002 and it uses Linux, but mostly I use a Aspire one laptop. I would really appreciate having a smartphone, mostly to compare prices and for emergency on the road, so I just need to save up some money, then join the rest of you in the 21 century.
  20. Dec 18, 2016 at 4:14 PM
    #400
    Harry
    Santa Fe NM
    Linux? Go on ...
