Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Mar 25, 2019 at 5:23 PM
    #4221
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Anyone rocking the 20 gallon 145psi or 21 gallon 125psi air compressors? Trying to figure out which one to go with. The 21 gallon is 10$ cheaper. $159 and $169.
    Any feedback on these. Plan on usin. Then to air tires and occasionally use an impact or ratchet for suspension, wheel/tire related jobs.
  2. Mar 25, 2019 at 7:30 PM
    #4222
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Are either of those enough for automotive air tools?
    I’d go with capacity over PSI.
  3. Mar 25, 2019 at 9:30 PM
    #4223
    93yotasr5
    Sacramento
    I have no idea to be honest.
  4. Mar 26, 2019 at 3:05 AM
    #4224
    UKJON
    UKJON Well-Known Member
    I bought a nail gun for a project the wife wanted done. She changed her mind on the project and I no longer needed the nail gun but being a man I kept it anyway. 16 months later I finally need it, get it out of the box, put the air fitting on, a little oil in it, load some nails, and it shot 3 nails out of it before it quit working. Called my local HF and they wouldn't exchange or refund it.
    I know it's my fault for not testing the nail gun when I bought it.
  5. Mar 26, 2019 at 5:49 AM
    #4225
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    You should call higher. I doubt they'd refund your money, but they should replace it.
    Although on second thought, I'm not sure if the lifetime is on everything..............probably not :( . Sorry about your nail gun.
    Good news is they're so insanely cheap, that if you ever need to drive another 3 nails................. :p
  6. Mar 26, 2019 at 8:38 AM
    #4226
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    20 gallons will work fine. 60+ and youd never have to worry.
    need to compare the cfm of the impact to the cfm of the compressor
  7. Mar 26, 2019 at 8:41 AM
    #4227
    Sacrifice
    KS
    DCSB OR 4X4 LT
    http://www.powermate.com/air_compressors/buying_guide.php
    Air flow required
    Compressors are measured in two main ways, PSI (pounds per square inch) and deliverable CFM (cubic feet per minute). These measurements determine the effectiveness of the air compressor in different situations. When selecting a compressor you need to identify the PSI and CFM requirements of your air tools. If you will only be using one tool at a time use the tool with the highest PSI and CFM requirement. If you intend to run multiple tools at the same time you will need to total the CFM's required by each tool.
    The key is to choose an air compressor that exceeds the PSI and CFM airflow requirements of your highest rated air tool. That way you're sure to not be under-powered. The best results are obtained when you purchase a compressor with 1.25 to 1.5 times more CFM airflow at the recommended PSI than your air tool(s) require. This method will ensure the performance of your air tool(s) will be maintained without over working the compressor and losing efficiency.
    Examples
    Single tool use: If a 1/2" impact wrench requires 5.0 CFM @ 90 PSI, then the compressor should deliver between 6.25 - 7.5 CFM @ 90 PSI.
    Multiple tool use: If you plan to run more than one tool at the same time, you must add the CFM of each tool together to determine your needs. If your compressor needed to power a Cut Off Tool (4 CFM @ 90 PSI) and a High Speed Grinder (4 CFM @ 90 PSI) you should look for a compressor that can deliver 10 - 12 CFM @ 90 PSI or higher.
    Slashaar and CanisLupus like this.
  8. Mar 26, 2019 at 9:06 AM
    #4228
    T4RFTMFW
    I was asking for both reasons.. I don’t think they’ll deliver enough air, and I also don’t think that capacity is enough unless it’s literally for an impact to bust lug nuts off with.
    If he ever wanted more tools, like a die grinder.. not going to work. Not enough air, not enough capacity unless you like motors that run nonstop and overheat. The small compressors aren’t bad, but those motors and pumps get overworked and may not fit in future plans.
    golfindia likes this.
  9. Mar 26, 2019 at 9:24 AM
    #4229
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    This can happen to any air tool if it's not oiled frequently. I had a harbor freight nail gun for almost 10 years. It crapped out after being stored in my shed for a year with no use.....
  10. Mar 26, 2019 at 9:33 AM
    #4230
    golfindia
    Yes.
    pickup truck
    I bought this model When the tank on my Sanborn rusted through. The HF pump will not keep up with grinders drills or sandblaster by itself. I Tee'd my sanborn 2 stage pump from the leaky tank into the HF tank and quit using the HF pump unless I need high volume. The HF unit is loud as hell, sounds like it's operating at like 4000rpm and about to explode. You can't even buy a new air tank for the price of the whole HF unit, so I'm not unhappy about the purchase
    tonered likes this.
  11. Mar 26, 2019 at 4:41 PM
    #4231
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    This jack is freaking awesome!
    Slashaar, EnonEye, Harry and 7 others like this.
  12. Mar 26, 2019 at 5:35 PM
    #4232
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    That looks sexy
  13. Mar 26, 2019 at 7:01 PM
    #4233
    jproffer
    Jim
    Perryville, MO
    So I made a little stop tonight....
    Had the boy with me, so all except the 1/2" drive sockets, the oil filter pliers and the finger ratchets were 30% off. Both 1/2" drive socket sets were 20% off, and naturally the crap ass tester and the tape measure were free. Full price around $90...out the door for right at $64. I realize we're not saving millions here, but it becomes like a mission lol...."I will not pay full price...I will not pay full price....I will not pay full price......"
    30% off is in store only, up to 5 items $10 each or less. My dumb ass tried to use it online and got "invalid coupon code"...then I read it.
    Anyhow, happy hunting folks.
  14. Mar 27, 2019 at 5:32 AM
    #4234
    TheDevilYouLove
    Marylandistan
    This link has been posted in this thread many times but I am posting it again just to keep it handy. I used the inside track coupons for an order today, even though I'm not an inside track member. They accepted the coupons anyway!
    http://www.hfqpdb.com/gallery/pct
    tonered and Hagendazsss like this.
  15. Mar 27, 2019 at 9:01 AM
    #4235
    jproffer
    Jim
    Perryville, MO
    I was wondering about that. Did you use them in the store or online?
    I've thought about it, but didn't know if they asked for a member number (if there is such a thing) or if they could see when you gave em your number that you're not a member, etc....
  16. Mar 27, 2019 at 9:08 AM
    #4236
    TheDevilYouLove
    Marylandistan
    I did it online so they def knew I was not an Inside Track Club member since I was obviously logged into my account.
  17. Mar 27, 2019 at 9:20 AM
    #4237
    golfindia
    Yes.
    pickup truck
    I am not a member but have used the inside track coupons a few times in the store. They looked at me wierd but scanned the coupon no problem. Those cashiers could care less how the process works as long as they scan it and the computer beeps.
  18. Mar 28, 2019 at 11:40 AM
    #4238
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    Grand opening here in Springifeld today :bananadance:Time for the flower boxes to come off the front porch, "honey I need a reciprocating saw" (OK):thumbsup:
    TheDevilYouLove, CurtB and tonered like this.
  19. Mar 31, 2019 at 6:58 AM
    #4239
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
  20. Mar 31, 2019 at 9:56 AM
    #4240
    TheDevilYouLove
    Marylandistan
    $5 is an amazing deal for those, but that link says they retail for over $100 which is absurd. Normal retail is $25
