Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Apr 23, 2019 at 7:44 AM
    #4421
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    -25%
    EatSleepTacos likes this.
  2. Apr 23, 2019 at 7:47 AM
    #4422
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I'll put it together later and see.
  3. Apr 23, 2019 at 8:13 AM
    #4423
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    o_O I think you should double check your math.
  4. Apr 23, 2019 at 8:20 AM
    #4424
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I meant less vs what I paid with the $10 off the old coupon, I should have been more clear. :)
    tonered, JGO, Slashaar and 1 other person like this.
  5. Apr 23, 2019 at 8:20 AM
    #4425
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Great comeback ....
    JGO, Slashaar and EatSleepTacos like this.
  6. Apr 23, 2019 at 8:21 AM
    #4426
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I have Harborfreights $30 jerry can for 3 years now. No problems what so ever.
    Bigdaddy4760 likes this.
  7. Apr 23, 2019 at 8:22 AM
    #4427
    TacomaMike37
    13' DCLB MGM
    Math is hard for some people. Ha
  8. Apr 23, 2019 at 8:24 AM
    #4428
    deadpocketss
    deadpocketss Dingus
    Colorado
    '24 Subaru Crosstrek Premium
    Has anyone used any of their bench top "mini" appliances (drill press, table saw, belt sander, mitre saw, etc)? Was looking at them the other day and they're fairly cheap and don't take up a ton of space but I'm wondering about quality here.
  9. Apr 23, 2019 at 8:28 AM
    #4429
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I’ve had a 1x30 bench grinder for years. No complaints.
  10. Apr 23, 2019 at 8:29 AM
    #4430
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I've used the miter saw for plenty of proyects, it broke a piece and they gave a new one under warranty no problem. I've been thinking about the drill press for some time.
    Slashaar likes this.
  11. Apr 23, 2019 at 8:32 AM
    #4431
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Interesting. Might pull the trigger on one this coming 25% off coupon.
  12. Apr 23, 2019 at 8:43 AM
    #4432
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Had the 8” drill press and found it to be a bit underpowered but functional. As long as you don’t force the bit, it would work. If you lean on the handle too much the bit would bind and the belt looses grip on either pulley so you you have to turn it off and disengage the bit from the workpiece to restart. Annoying but it’s a reminder to let the bit do the cutting and not force it. I got a good deal on a vintage floor drill press so I passed the HF drill press to my brother who would use it a lot less than me so it would be fine for him.
    Also have the 4” belt/disc sander and kind of the same deal. One interesting thing I found was that it actually likes the HF belts. I bought Norton belts for it but they would never stay centered and I was constantly adjusting them as I worked and they still wanted to walk off the drum. The HF belts always stayed centered so it was more convenient to just buy a few and start with a fresh belt every few uses. I also though the guard and little table were garbage so i removed them pretty much immediately. The guard made it a pain to swap belts out anyway. Now I can just loosen the tension arm, swap and get back to work.
  13. Apr 23, 2019 at 9:01 AM
    #4433
    paw1371
    paw1371 Member
    Pete
    2019 TRD Off Road
    Stock for now
    Bought the ten inch wet saw with hopes of making it most of the way through my stone fireplace. Lasted the entire project and through a retaining wall project as well. I didn’t take it easy on the saw at all. The closer I got to completing the project the harder I was on it. Did have to replace the water pump once with a Lowe’s pump, but as stated, I was hard on it.
    I guess when you start with low expectations, ok results seem great.
    JGO, Biscuits and jafrisi like this.
  14. Apr 23, 2019 at 1:46 PM
    #4434
    EPBlueTaco
    EPBlueTaco Well-Known Member
    Ted
    El Paso
    07 DCLB SR5
    None yet
    I have the drill press and I like it so far. I have not used it all that much. Works well for my needs
  15. Apr 23, 2019 at 1:53 PM
    #4435
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    This philosophy is apt for things beyond Harbor Freight.
  16. Apr 23, 2019 at 5:49 PM
    #4436
    T4RFTMFW
    No expectations = no disappointment.
    TheGoat, Bruce988jl, Kpatt9 and 2 others like this.
  17. Apr 23, 2019 at 6:50 PM
    #4437
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Think twice about their cheap drill press, it's lowest speed is too fast to drill steel or stainless steel .
  18. Apr 23, 2019 at 6:55 PM
    #4438
    FitzTaco84
    FitzTaco84 Well-Known Member
    USA
    2018 DCSB TRD OffRoad 4x4
    Anyone have a HF angle grinder? I need a cheap angle grinder.
  19. Apr 23, 2019 at 7:05 PM
    #4439
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Watch the clearance rack at Menards. I snagged one for $30. Open box special.
    Biscuits likes this.
  20. Apr 23, 2019 at 7:06 PM
    #4440
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I have had a few of the cheapest ones. I seem to end up breaking off the handle on them if dropped hard. Hard to use after that so usually just get another.
