Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Jul 6, 2019 at 7:51 PM
    #4981
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I can't like this post enough.
    The next cheapest welder is 10x better than this turd.
    Unfortunately, it is a great seller because most peeps do not research this thing.
    They see the cheepest price and go all in. They use the thing and think they can't weld and they walk away from welding forever. It's kind of a shame.
  2. Jul 6, 2019 at 8:39 PM
    #4982
    Gus87
    Gus87 Well-Known Member
    Chicagoland
    16 trd sport
    I definitely didn't think it was me except for I would clean the shit out of the steel and it would not make a good contact. I ended up buying a used Lincoln and I didn't even have to think when I was using it.
    koditten[QUOTED] likes this.
  3. Jul 6, 2019 at 10:09 PM
    #4983
    karatescotty
    karatescotty Well-Known Member
    Beaverton, OR
    2019 TRD Pro
    Picked this up for today, not bad for $20. I use a Proto ratchet at work, it feels pretty much the same.
  4. Jul 8, 2019 at 10:20 PM
    #4984
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
    Some work well. Both of mine--the original dud and its replacement--weren't worth the amount to gas it took to drive to the store. But the $8 AAA worklight is a gem.
  5. Jul 9, 2019 at 11:18 AM
    #4985
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I got two of those from Amazon. They’re so much better than piling all my pliers on top of each other!
    Blackout14 likes this.
  6. Jul 9, 2019 at 12:36 PM
    #4986
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    then you won't get a flywheel off a 4cyl as they use 12 pt bolts. You need both.
    BassAckwards and Bleep100 like this.
  7. Jul 9, 2019 at 12:41 PM
    #4987
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    It's nice to have both 6 and 12 point sets and sometimes you need both .
    TomTwo likes this.
  8. Jul 9, 2019 at 1:48 PM
    #4988
    GHOST SHIP
    GHOST
    Joe...
    WD40 those pliers.
    :bananadead:
  9. Jul 9, 2019 at 2:03 PM
    #4989
    GHOST SHIP
    GHOST
    I have a habit of reviving my dad's old tools just because. I have a couple of his sledgehammers that I sanded and stained the hickory handles and on one I wanted to fully polish out the hammer. Random other tools get the same treatment. Also have a 36" pipe wrench that he had and was all rusty. I have no idea where he got it from or what he'd even use it for, but there it was in the corner of his garage. I removed all the rust and repainted it bright red and now it hangs in my garage if I ever need it. I think I had mentioned the "Ford" adjustable that I painted ford engine blue too.
  10. Jul 9, 2019 at 2:18 PM
    #4990
    GHOST SHIP
    GHOST
    Tag me. I'll see what I can do.
  11. Jul 9, 2019 at 3:40 PM
    #4991
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    Contact Milwaukee with the model number and they might be able to get what you need or can tell you who might have “new” old stock parts. Maybe even a remanufactured part. Check here :
    https://www.googleadservices.com/pa...=2ahUKEwiFrq2R9KjjAhXCGM0KHdzVDbMQ0Qx6BAgPEAE
    Markcal[OP] and Blackout14 like this.
  12. Jul 9, 2019 at 3:48 PM
    #4992
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Best work light I've ever used. Rechargeable 18650 with usb charging makes it very convenient for me. Sadly while I was doing an alignment on my truck I turned the steering wheel and the tire made contact with the light and broke it at the hinge. Another excuse to go back to hf.
    Markcal[OP] and koditten like this.
  13. Jul 9, 2019 at 4:13 PM
    #4993
    Markcal
    Markcal [OP] Well-Known Member
    I just liked your comment because it's a reminder that I need to get this done too. maintenance on tools is important especially when we spend so much on them.
  14. Jul 9, 2019 at 6:00 PM
    #4994
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Just so you guys know. For the blast cabinet a shower drain works best for the hole on back.
    Threaded and sealed without any gluing, comes with two bushings, and collapses on factory bushing.
    MSN88longbed, Slashaar, CS_AR and 7 others like this.
  15. Jul 9, 2019 at 6:32 PM
    #4995
    SpanishTaco
    SpanishTaco Well-Known Member
    CT
    2015 Blue DCSB TRD Sport
    Like the concept, good way to recycle those buckets too! :hattip:
  16. Jul 9, 2019 at 6:52 PM
    #4996
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Well since I’m not using vacuum hose I’m not that flexible on bucket placement. I overpaid for the hose, but it’s what Lowe’s had. I want to make a platform in a way the bucket can roll with the cabinet.
    The cabinet is already on a Herc-U-Lift by Rigid now.
    I don’t care for blasting in my garage, so I want to be able to just run an extension and airline under my garage door and blast right outside.
  17. Jul 9, 2019 at 7:03 PM
    #4997
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I use liquid gun blueing on my pliers. Slows down the rust process and makes them easier to wipe down after I am finished with them.
  18. Jul 9, 2019 at 7:19 PM
    #4998
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    That's a great idea.
    TomTwo[QUOTED] and Markcal[OP] like this.
  19. Jul 10, 2019 at 5:12 AM
    #4999
    G.T.
    G.T.
    CONUS
    Psssst, google 3/8 drive sockets and wrenches.
    koditten and Blackout14 like this.
  20. Jul 10, 2019 at 6:06 AM
    #5000
    Steve_P
    TN
    Pssst, if you ever replaced a flywheel with 12 point bolts, you wouldn't be posting. The torque is something like 90 ft-lb plus 90 degrees rotation. That's well into half drive territory and you're not doing that with a wrench as it's recessed. And don't worry, I also have 3/8 drive 12 point sockets.
    Toyota also uses a 12 point axle nut on some cars. It's 30mm IIRC. Good luck with your 3/8 drive on it
    EatSleepTacos likes this.
