Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Jul 10, 2019 at 6:12 AM
    #5001
    G.T.
    G.T.
    CONUS
  2. Jul 10, 2019 at 6:34 AM
    #5002
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Bad idea. Watered down latex will cover extremely shittily, and you'll need to refill that 1qt container a bajillion times to do even a small area.
  3. Jul 10, 2019 at 7:56 AM
    #5003
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I just bought this..... I need to stain my pocket fence. Something like 30 panels double sided.....hopefully it works well.
    Blackout14 likes this.
  4. Jul 10, 2019 at 8:04 AM
    #5004
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    We have the cheap stain sprayer. Has worked well for our fence. It eats up a lot of stain though in general with the atomizing though
  5. Jul 10, 2019 at 8:07 AM
    #5005
    HawkShot99
    Kingston, NY
    Bought one of these 12 volt water transfer pumps last week. I wanted a 12v one as it was needed to clean my buddies boat. We spray deluged bleach on the pontoons carpets, then power wash it off. He decided to launch it real early this year before cleaning it, now we needed to figure out how to do the job.....no power at the dock and its across the street so can't run a hose or extension cord.
    So 12v option we could hook up to the boats batteries, and use my gas pressure washer. The pressure washer has a flow rate of 2.6gpm, and the pump is 290gph= 4.8gpm(over 2gpm then the pressure washer can use).
    The pump moves nowhere near the advertised amount of water. I could not get full power out of the pressure washer as it just didn't have the flow needed. It did the job in the end, just way slower and not the full job I really wanted, but the boat is clean.
    After we were done, we cut off the quick connect wires and hard wired it to the boat. The pontoon is a 2 story and has a water slide off the roof. The pump for the slide has stopped working so we are using this as the replacement. For that job much less water flow is needed so all good.
    Skyway likes this.
  6. Jul 10, 2019 at 8:11 AM
    #5006
    HawkShot99
    Kingston, NY
    The stain I'm using has a range of coverage of 150-400 sq ft. I went with a thought of 200-250 for my expected calculations. Raw wood, and how efficient the gun will be. If it works better, I can always return the extra stain.
  7. Jul 10, 2019 at 8:16 AM
    #5007
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    x2
  8. Jul 11, 2019 at 7:51 PM
    #5008
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    Got a metal file, free magnet light and a Holt Grease Gun. im very pleased with the gun. it worked like a charm...
    w.adventures likes this.
  9. Jul 14, 2019 at 9:02 AM
    #5009
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Any current coupons? Need to buy some jack stands
  10. Jul 14, 2019 at 10:25 AM
    #5010
    andrewb
    andrewb Well-Known Member
    NC
    2015 Tacoma
    Hfqpdb.com
  11. Jul 15, 2019 at 12:05 PM
    #5011
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    There are always 20% off coupons.
    w.adventures[QUOTED] likes this.
  12. Jul 15, 2019 at 1:53 PM
    #5012
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    There is a HR app you can download to your phone. Has all the up to date coupons. I would check there or the website that someone posted above.
  13. Jul 15, 2019 at 2:33 PM
    #5013
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Here is a code number for 20 percent off 1 item.
    221995800003
    la0d0g likes this.
  14. Jul 15, 2019 at 2:45 PM
    #5014
    EPBlueTaco
    EPBlueTaco Well-Known Member
    Ted
    El Paso
    07 DCLB SR5
    None yet
  15. Jul 16, 2019 at 10:09 AM
    #5015
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Any exclusions?
  16. Jul 16, 2019 at 10:10 AM
    #5016
    koditten
    Kirk
    Central Michigan
    The usuals. No Jack's, tool boxes, welders...yada, yada, yada. You know the drill.
    Markcal[OP] and T4RFTMFW like this.
  17. Jul 16, 2019 at 11:03 AM
    #5017
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    No drills! Excluded as well.
    Markcal[OP] and GHOST SHIP like this.
  18. Jul 16, 2019 at 12:42 PM
    #5018
    koditten
    Kirk
    Central Michigan
    Bwahahaha!
    Markcal[OP] likes this.
  19. Jul 16, 2019 at 2:14 PM
    #5019
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    If you're reading this thread, you should probably bookmark this website: https://www.hfqpdb.com/
    You're welcome.
  20. Jul 16, 2019 at 2:32 PM
    #5020
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Anyone know how often they run that 15% off coupon with no restrictions?
