Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Oct 1, 2019 at 12:28 PM
    #5581
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I’ve used a vice maybe 3 times in my life.
    CurtB likes this.
  2. Oct 1, 2019 at 1:02 PM
    #5582
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    I thought they removed that section of Craigslist a few years ago...
    I actually have the 6 ton bench top one I bought to do the wheel bearings on our Honda Civic. It's not quite tall enough to fit the dies and everything in there, I had to get creative to get it to work but you could easily replace the 4 vertical pieces of angle iron with something a little longer and maybe even stronger to get a little more capacity.
    If you have a need for or don't mind the amount of space they take up then I say get the bigger one. But if you want to save space, don't need the higher working load and don't mind some minor modifying it will serve the purpose well.
    ACEkraut[QUOTED] and Twizted like this.
  3. Oct 1, 2019 at 1:15 PM
    #5583
    la0d0g
    running for the hills
    For crawling not hauling
    I have like four of them that I use everyday.
    G.T. likes this.
  4. Oct 1, 2019 at 1:30 PM
    #5584
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I have the 12 ton and for the price, it's a decent unit. Like most things from HF, the quality is good enough for an occasional use tool, but not for something getting used hard daily.
    ACEkraut[QUOTED] likes this.
  5. Oct 1, 2019 at 1:33 PM
    #5585
    T4RFTMFW
    :rain:
  6. Oct 1, 2019 at 1:40 PM
    #5586
    la0d0g
    Dont worry, they're enjoyable :D
  7. Oct 1, 2019 at 1:44 PM
    #5587
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Never dealt with vice, but use my vise alot.
    T4RFTMFW[QUOTED] likes this.
  8. Oct 1, 2019 at 2:11 PM
    #5588
    T4RFTMFW
    Clearly a vise isn’t my vice. :bananadead:
  9. Oct 2, 2019 at 5:01 AM
    #5589
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I had the 12T for 20+ years and recently upgraded to the 20T. Several times the 12T did not get the job done for me so I would recommend getting the 20T as the price difference isn't that great. On the 12T, I replaced the jack 2-3 times over the years because they leak after at while. I've had bad luck with HF jacks. Like all things HF, the 20T isn't the best as the frame depth is only ~4", and it's also not rigid enough- it flexes a lot under use. The 4" depth means you can't easily do things like the Tacoma front wheel bearings on it as the hub doesn't fit thru the bridge. You can do them, it just means stacking ~6" of plate on top to support the hub. Any press nicer than the HF is going to cost 4X as much so there's not a lot of other choices for the $.
    If you are going to do FWD wheel bearings, consider the Astro Pneumatic tool to do them on the car
    Edit : Astro #78825
  10. Oct 2, 2019 at 9:11 AM
    #5590
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Thanks for the feedback! I may have more floor space then workbench space.
    Thanks! That was the way that I was leaning in regards to one over the other.
    Thanks! I spent some time on YouTube and checked out the Astro 78825. I think that would work well! While I still would like a shop press and will get one some day probably not it the too distant future, I am thinking that the Astro tool might be the easier way to go. No need to remove the spindle that way.
  11. Oct 2, 2019 at 9:24 AM
    #5591
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How often do you see yourself needing a big press?
    I need one about 2x/year. I find it's easier just to stop by the local machine shop to do the press work . I don't need a big press taking up floor space .
    Bigdaddy4760, ACEkraut and G.T. like this.
  12. Oct 2, 2019 at 9:40 AM
    #5592
    ACEkraut
    Aaron
    Durham, Maine
    To be honest, I am not sure. But I also produce license plate brackets and have been toying with the idea of using the press to make my bends instead of using my Harbor Freight flat metal bender. I need to do a bit more research but if it would look like that type of a system might work then I could see my self getting one.
    And, I think I am addicted to tools and acquiring them. No, I AM addicted to tools. There, now I can start getting help for my addiction!
  13. Oct 2, 2019 at 9:51 AM
    #5593
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    The only help for an addiction like that is more tools.
    #askmehowiknow
  14. Oct 2, 2019 at 9:53 AM
    #5594
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Has anyone bought a sprayer from here for prepping frame and undercarriage for salt/brine?
    If you had success could you recommend the model? Woolwax gun is almost 100 bucks and once or twice a year application I’d like to see my results first.
    Edit. Spraying fluid film and hitting the sensitive areas with cosmoline.
  15. Oct 2, 2019 at 10:04 AM
    #5595
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I would buy the one from Kellsport/Fluid Film. I have it and it works well for spraying that product.
  16. Oct 2, 2019 at 10:10 AM
    #5596
    Steve_P
    TN
    I agree that I don't use the press very often- a few times a year. I also don't use my welder, drill press, oxy-acetylene torch, slide hammers, pullers...... very often. But, when you need them, you need them, and for me it's better to have them than have to take it somewhere.
    For FWD wheel bearings the Astro tool is the way to go because you don't have to remove the knuckle. I also have it :)
    koditten, Twizted and ACEkraut like this.
  17. Oct 2, 2019 at 10:14 AM
    #5597
    Steve_P
    TN
    HF used to make an undercoating spray gun, I have it, and it works great. But I can't find it listed there anymore. You screw the can onto the bottom of it so you'd need a mating can. I've used it for undercoating and rocker shutz. It looks like this. They also make one that comes with a cup on the bottom.
    Edit- updated link to Astro:
    https://www.amazon.com/Astro-4538-E...ing+spray+gun&qid=1570036452&s=gateway&sr=8-9
  18. Oct 2, 2019 at 10:25 AM
    #5598
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    ^^ that’s what I have also with the 2 plastic screw on containers, works good.
    verynearlypure likes this.
  19. Oct 2, 2019 at 10:57 AM
    #5599
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I use my press often enough where I can justify it. I’ll I have the swag press brake kit on it too. If you’re only casually using it or not going to bend heavy gauge steel with it, I’d say pass only because it sounds like you already have a system in place. If you do plan on getting the press, you should factor in the cost of the swag kit but also I can tell you from experience, you’ll want the air over hydro jack to save your shoulder every time you use it. It gets old using the pump handle for multiple repeated bends. And if that’s the route you’re going, you’ll obviously need a compressor that can handle that workload. You can see it really snowballs but if you’re actually going to use all those tools, there’s no way around it.
  20. Oct 2, 2019 at 11:18 AM
    #5600
    ACEkraut
    Aaron
    Durham, Maine
    Thanks for the info and for your time offering up your insight. I am unsure which path I will take right now, that is about all I can be certain of. I need to prepare myself better and gather more information before I actually start spending money without a clear understanding of what I want to accomplish.
