Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Oct 4, 2019 at 6:13 AM
    #5621
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Weller.
    LTDSC, hotboatrod and G.T. like this.
  2. Oct 4, 2019 at 6:13 AM
    #5622
    hotboatrod
    hotboatrod Well-Known Member
    Rod
    El Cajon
    1996 Tacoma 4X4 V6 auto
    2 1/2" front lift and bigger tires and wheels
    I have a Weller cordless soldering iron. It was $25. The HF is $20 and has good reviews. For light soldering jobs you can't beat a cordless. They heat up a lot quicker and also can be used as a heat gun to shrink shrink tubing or to shrink crimp connectors that have that capability.
    Check out these connectors. The middle stripe is solder, the outer stripes are seals/glue that shrinks to the wire. They work great for boat trailers or anywhere where a connector might get wet. I used them on military tank simulators that I used to help assemble. These cordless soldering irons work great on these connectors.
    Toy4me and G.T. like this.
  3. Oct 4, 2019 at 7:48 AM
    #5623
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Buy a butane one. Weller makes a good one.
    hotboatrod likes this.
  4. Oct 4, 2019 at 9:29 AM
    #5624
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Good to get some actual feedback on these things. An ad for them keeps popping up on my insta feed and I was curious. I found them on Amazon and have them in my want list as a reminder but haven’t pulled the trigger. Guess I’ll give them a try.
    hotboatrod[QUOTED] likes this.
  5. Oct 4, 2019 at 9:34 AM
    #5625
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    The newer offerings are greatly improved over the old school ones- they're now very fine tooth ratchets and they hold the bits. I have a couple by VIM, who makes quite a few variations. VIM also makes fantastic bits and bit sockets.
    https://www.amazon.com/Vim-Tools-HBR3-Bit-Ratchet/dp/B002Y05COI
  6. Oct 4, 2019 at 9:47 AM
    #5626
    Steve_P
    TN
    I have a Weller WES 51 station. It used to be the standard for the less expensive stations, but it looks like they don't make it anymore. I also have a portasol butane kit for portability- but I've found that I almost never use the butane, since I work in my garage and there's an electric cord reel right there.
    I'd recommend starting with a decent station, see what's well rated on Amazon, and then over time you can decide if you want to add a butane or cordless.
    T4RFTMFW likes this.
  7. Oct 4, 2019 at 10:45 AM
    #5627
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Ive got a Weller WLC100 (40watt station) I use a decent amount. Works well.
    Also have a small butane one I used infrequently. Only grab it when needing to do 1 solder type stuff. A Weller ML500MP. I just dont care forbutane if doing multiple areas of soldering (say a wiring harness) As there never seems to be a good place to set it. I do keep one in the truck toolbag though
    I also used a Ryobi corded/cordless electric soldering station a bit ago and liked it. Uses their 18v batteries (which i have plenty of). Its nice having the full station and not needing to be plugged into the wall. Ill probably pick up my own at some point
  8. Oct 4, 2019 at 10:57 AM
    #5628
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    jubei likes this.
  9. Oct 4, 2019 at 12:36 PM
    #5629
    hotboatrod
    Rod
    El Cajon
    Although your comment does make sense and is accurate, I'm wondering why you prefer to be attached to a cord, why you want to wait an extra 5 or so minutes for it to heat up every single time, and why use a corded model over a cordless model for light and quick soldering jobs?
    These cordless deals work far too well for old school thought patterns, IMO, but to each their own. I use my cordless iron for almost every single soldering job I do, regardless of where the work is being done. If I'm doing extremely fine (tiny soldering points on a pc board such as on a chip) or a BIG soldering job I'll use the corded version.
  10. Oct 4, 2019 at 12:39 PM
    #5630
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
  11. Oct 4, 2019 at 12:41 PM
    #5631
    hotboatrod
    Rod
    El Cajon
    ACEkraut[QUOTED] likes this.
  12. Oct 4, 2019 at 3:48 PM
    #5632
    3 Blade Rage
    3 Blade Rage Active Member
    Central Pa
    2010 Brown Mica Tacoma Sr5
    I just picked up the Yellow Daytona 3 ton floor jack. So far it is fantastic. My little 1 1/2 ton only had about a 14" lift and with my new lifted Taco it was sketchy at best cribbing it up with wood. I made sure I had my wife see what I had to go through just to take off a tire. After she did she gave me the green light to get it. I almost bought the red 3 ton and saved 90 bucks but I figured I may as well treat myself to the best.
    w.adventures likes this.
  13. Oct 4, 2019 at 8:00 PM
    #5633
    sapperguy
    sapperguy Well-Known Member
    craig
    09 SR5 DCLB
    Made my first Harbor Freight purchase since being added to the coupon email list. Paid for a pair of lashing straps for my kayaks and the 37 piece impact socket set (on sale for 19.99), and got a 25ft tape measure, package of microfiber towels, and a tarp for free. I see this being a problem in the future...
    EnonEye, G.T., TomTwo and 1 other person like this.
  14. Oct 4, 2019 at 9:30 PM
    #5634
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    It already is. Lol
    TomTwo likes this.
  15. Oct 5, 2019 at 5:03 AM
    #5635
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I think I've posted this in the past but... This place is just like a women's shoe store but for men! :rofl:
    Gunshot-6A and Bigdaddy4760 like this.
  16. Oct 5, 2019 at 6:51 AM
    #5636
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    What kind of men want women's shoes? o_O
  17. Oct 5, 2019 at 9:08 AM
    #5637
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    me waiting 5mins for it to heat up is fine, im not in a rush to do anything lol Im a big corded guy i have corded saw, impact, and drills. Batteries die eventually, straight power from the wall is consistent. feel like theyre more reliable. Butane may work..hmmm Ill check them all out tonight when i have some time. thanks for all the recommendations!
  18. Oct 5, 2019 at 10:45 AM
    #5638
    hotboatrod
    Rod
    El Cajon
    To each their own. Butane powered cordless soldering irons heat output is extremely consistent and extremely quick, are perfect for smaller jobs, cheap AF to run, but if you don't mind and if you enjoy waisting your time with no actual benefit then feel free to do so. No offense meant! Facts only!
  19. Oct 5, 2019 at 10:57 AM
    #5639
    T4RFTMFW
    I used a butane once. Not for me.
  20. Oct 5, 2019 at 11:07 AM
    #5640
    sapperguy
    craig
    09 SR5 DCLB
    Any feedback on the Mauer impact drivers?
