Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Jan 16, 2020 at 6:11 PM
    #6341
    DG92071
    DG92071 Well-Known Member
    I was guessing their ratings were for a piece of material to be bent across the entire width of the brake. I was hoping with 1 1/2" wide material I could cheat a little bit and use thicker material. I guess it doesn't work that way lol.
    I've got a chunk of 6"x6"x3/8" angle iron so I think I'll use that and make my own because I can't afford one prebuilt for that thick of material. I saw some huge weld on hinges at the local metal supply I think I'll try.
    Thank you for the replies.
    mtip[QUOTED] likes this.
  2. Jan 17, 2020 at 11:23 AM
    #6342
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Well, he said he wanted to be talked out of it, so I gave it a shot :) Obviously it depends on your needs, but IMO you want a lot of shallow drawers and only a few deep drawers; I can always put a circular saw or belt sander on a shelf, but that doesn't work well with a pliers collection. And if you need 10 drawers now, you should buy something with 15, because you'll keep adding to your collection and will soon be out of room; forums are good for that!
  3. Jan 17, 2020 at 3:51 PM
    #6343
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
    Two options that will bend your steel, one is cheap and good enough but not perfect, the other is the least expensive proper way of doing it.
    You can easily bend 3/16" steel flat bar that's 1-1/2" wide if you use a $20 propane blow torch with the piece of steel in a vise, once the location of the desired bend is glowing hot, it needs to be positioned so you can hammer the steel, bend it over the vise jaw. Simple and does the job. Wear heavy gloves.
    Other method that plenty of us have done is buy the HF 20 ton shop press, about $145 with coupon, buy the SWAG Offroad press brake kit, about $200, and you can bend steel all day long with little effort. To me that is the least expensive, quality method for clean metal brakes (sharp bends).
  4. Jan 17, 2020 at 4:26 PM
    #6344
    DG92071
    That's the kind of info I was hoping for. Thank you. I'll research that option.
  5. Jan 28, 2020 at 9:32 PM
    #6345
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Has anybody tried the new Chief line of air tools?
    Can the 20% off coupon be used for that brand?
  6. Jan 28, 2020 at 9:34 PM
    #6346
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Looking at this one. Cheapest I've seen it at $29.99, with couponit would be like $31
  7. Jan 31, 2020 at 9:27 AM
    #6347
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    Thoughts on the continuous power inverter? For charging tool batteries and such, not to run any appliances in the OR rig.
    Tacosail likes this.
  8. Jan 31, 2020 at 2:35 PM
    #6348
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Anyone have a coupon for the 6 ton jack stands?
  9. Jan 31, 2020 at 2:42 PM
    #6349
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
  10. Jan 31, 2020 at 2:54 PM
    #6350
    Mitch76
    Mitch
    San Angelo, TX
  11. Jan 31, 2020 at 3:01 PM
    #6351
    Mitch76
    Mitch
    San Angelo, TX
  12. Jan 31, 2020 at 3:02 PM
    #6352
    spencermarkd
    Spencer
    Don't forget to click the "free coupons" on the top and get your free item :thumbsup:
  13. Jan 31, 2020 at 3:03 PM
    #6353
    spencermarkd
    Spencer
  14. Jan 31, 2020 at 3:31 PM
    #6354
    Yota_Ivan
    Arlington, TX
    Go to the "root" page https://www.hfqpdb.com and there is a blank that says "SEARCH DATABASE". Fill in a keyword of what you're looking for..
  15. Jan 31, 2020 at 4:43 PM
    #6355
    Mitch76
    Mitch
    San Angelo, TX
    The Pittsburgh 3 ton lo pro. Installing my lift blocks tomorrow and my 1.5 ton isn’t tall enough.
    Yota_Ivan likes this.
  16. Feb 1, 2020 at 7:02 AM
    #6356
    Toyko Joe
    Toyko Joe Here for the pictures
    Not sure what batteries you're charging but most power tool battery chargers draw 50-100w so you'd have more than enough capacity. Maybe also look into the manufacturer for a automotive 12v charger Milwaukee, Ryobi etc should have them a lot of people need mobile battery chargers.
  17. Feb 6, 2020 at 1:13 PM
    #6357
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think this has been the first time that I saw something at HF and thought: Oh hell no. I mean there are times when I think that something might fail, but this is the first when I knew it would fail in many different ways. I have no doubt it will lift 6k easily. It is the rest of it that scares me.
  18. Feb 6, 2020 at 3:34 PM
    #6358
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Nope. Not getting under that.
    Jimmyh and tonered[QUOTED] like this.
  19. Feb 6, 2020 at 3:39 PM
    #6359
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Imagine taking a wheel off and . . . Oopsie!
  20. Feb 6, 2020 at 7:27 PM
    #6360
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    It has really good reviews :notsure:
    shane100700 and tonered[QUOTED] like this.
