Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Apr 27, 2020 at 5:37 PM
    #6561
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    Thanks guys. Yes, I’ve cut the bristles off, and drilled/punched out the rubber inset (hence the name Rubberset), and soaked the inside with WD-40, and tried the kitchen rubber grip, but still won’t budge. I don’t have a heat gun, but this might be the perfect opportunity to hit HF this week, rather than use the wife hair dryer.
  2. Apr 27, 2020 at 5:56 PM
    #6562
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Try the hair dryer. No harm, no foul to the hair dryer. I mean it’s not like you are using the turkey blaster to remove brake fluid from the master cylinder. Not that I have ever done that before. :anonymous: o_O
  3. Apr 27, 2020 at 5:58 PM
    #6563
    Choco_Taco
    Tim
    Fredericksburg, VA
    :eek: I hope you bought a new one before you basted anything.
    ACEkraut[QUOTED] likes this.
  4. Apr 27, 2020 at 6:26 PM
    #6564
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Mmmmmmm. DOT 4
  5. Apr 27, 2020 at 7:13 PM
    #6565
    ACEkraut
    Aaron
    Durham, Maine
    Full disclosure, I was divorced at the time and living on my own. I mean it wasn’t like I was going to baste a turkey anytime soon. :notsure:
  6. Apr 28, 2020 at 8:29 AM
    #6566
    Choco_Taco
    Tim
    Fredericksburg, VA
    I GOT IT!! Soaked with WD-40 for the night, grabbed the two rubber lid openers we have, and twisted hard a few times! I know this isn’t HF related, just really happy!
    :bananadance:
    Martyinco, mtip, Steve_P and 7 others like this.
  7. Apr 29, 2020 at 7:57 PM
    #6567
    la0d0g
    running for the hills
    For crawling not hauling
    I keep one in my garage for just this purpose :thumbsup:
  8. Apr 30, 2020 at 3:49 AM
    #6568
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I second the Lisle 63600 for oil filters, been using it for probably at least 15 years, always removed any all filters without issue. Hopefully they’re still made in the U.S.A
  9. Apr 30, 2020 at 7:03 PM
    #6569
    rtkbowhunter
    rtkbowhunter Well-Known Member
    Southeast PA
    2011 Tacoma Quad Cab SR5
    So you guys that are using this welder, are you running it on a dedicated 30amp circuit?
  10. Apr 30, 2020 at 7:15 PM
    #6570
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm not sure what the breaker is on that circuit, just whatever outlet was open in my garage. I didn't have anything else that would be putting much load on it though. I was using a 15ft extension cord without issue all day. If I did my math right, I welded 36 feet. I would take breaks for myself but not due to the welder.
    shane100700 and w.adventures like this.
  11. Apr 30, 2020 at 7:18 PM
    #6571
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    I was so tempted the other day when I was in the store to buy heat shrink. It was almost an expensive day but I walked out with my $1.50 heat shrink and free light.
  12. Apr 30, 2020 at 7:20 PM
    #6572
    Reh5108
    Idaho
    Damn, idk if I ever walk out of there without buying more than I planned.
    Toy4me and w.adventures[QUOTED] like this.
  13. Apr 30, 2020 at 7:30 PM
    #6573
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Most 110v machines are fine on a 20 amp circuit but will most likely trip a standard 15 amp wall outlet circuit
    Reh5108 likes this.
  14. Apr 30, 2020 at 8:52 PM
    #6574
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I’ve always ran all my 110V welders on a dedicated 30A and my 220V on a dedicated 50A.
  15. May 1, 2020 at 2:45 AM
    #6575
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This is an argument that can go on for days.
    240 volt MIG machines run safely on a 30 amp breaker as long as the correct wire is feeding the plug from the breaker.
    The welder manufacturers confuse things by putting those 50 amp plugs on their machines. There is no wires bigger than 10 AWG in these welders.
    Manufacturers assume that most shops will change the cord and plug, so they just go generic and put on a ridiculous 50 amp plug and cord.
    tacoma_ca likes this.
  16. May 4, 2020 at 12:51 PM
    #6576
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Latest buys. Found gear wrench ratchet wrenches on eBay for around 4-8$ each so picked up a 8/10/12/14/15/17 for less than 25$. Harbor freight socket tray and wrench organizers
  17. May 4, 2020 at 5:14 PM
    #6577
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Anyone use the horizontal metal cutting bandsaw?
  18. May 4, 2020 at 5:51 PM
    #6578
    MightyQ
    MightyQ Well-Known Member
    2012 Reg Cab 4x4
    Does anyone have/tried out their line of hard cases called Apache? They seem like a fair priced alternative to Pelican cases but I was curious on the build quality, I understand it wont be upto pelican standard but if its anywhere near it I could save $100 plus per case.
  19. May 4, 2020 at 6:27 PM
    #6579
    Fire Chicken
    Fire Chicken Aka 'Panda Express'
    Charles
    2019 Tacoma TRD Off-road 4x4; 1979 Pontiac Trans Am WS6
    Anyone have their hedge trimmer? I only need to trim a few small bushes. Reviews seem good, just figured I would ask.
    rob1208 likes this.
  20. May 4, 2020 at 6:48 PM
    #6580
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    There are hundreds perhaps thousands of posting and groups all discussing how too tune-up these Chinese saws. The basic HF looking saw has been produced for many years under more names that you can imagine that all look like coming from the same factory or what looks to be the same original castings . There have been a few differences here and there through the years depending on who's name appears on them. I spent major time researching and then shimming, grinding, adding washers, using straight edges, bending and twisting to finally get a saw that I could use, meaning actually cutting square and @ 90*.
    The last time I used it was to cut the bottom off an old welding tank to make a bell, about 7-8" diameter. I must admit it was almost perfect, just not right out of the box. The thing is there is really nothing out there even at 4X the price that will do what these have the potential to do. Your experience may vary.
