Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. May 20, 2020 at 12:45 PM
    #6721
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    The "it" was intentional
    Jimmyh and Beretta4x4[QUOTED] like this.
  2. May 20, 2020 at 2:19 PM
    #6722
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    Didn't read the manual since I wasn't using them for safety, really. There are tabs? LOL
  3. May 20, 2020 at 2:23 PM
    #6723
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Sure are! Prevents the pawl from coming out as well as going all the way down.
    jproffer[QUOTED] and Beretta4x4 like this.
  4. May 20, 2020 at 2:25 PM
    #6724
    eon_blue
    Azusa, CA
    I believe they're talking about this piece that's supposed to get bent inward
    however that is not a way to prevent the jack stand from failing under load. Copy/pasted this from another forum -
    Those tabs are for the following
    A. Stops the Y support from falling out when transferring (prevents injury and prevents damage to surroundings and the Y support itself (dropping can damage teeth / put difficult-impossible to notice fracture in support / nick surface to form stress riser in support... All very very bad).
    B. Stops user from loading the support in an over extended condition (locking tooth at bottom of Y instead of in the teeth of Y... again very bad).
    C. Stops user from mixing similar looking Y supports between different stands (Incompatible teeth / geometries that seem to work but in reality do not. Different rated load supports. Again very bad...)
    [Also, depending on the support it maybe even dangerous to switch up Y support between same matching models].
    If you want a jack stand with added safety feature, get ones with the safety pins that slide into them. The Harbor Freight ones don't have those safety pins like this
    06Tacooo, tacoma2g, rob1208 and 4 others like this.
  5. May 20, 2020 at 2:28 PM
    #6725
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Having to read the manual to find out some tab has to be bent for the safety to operate sounds ab-so-fucking-lutely stupid to me. Then put a huge warning label on the stand by the tab with an arrow. Thinking someone is going to read a user manual for something as simple as a jack stand is like thinking someone is going to read the user manual for their new hammer.
    Beretta4x4 likes this.
  6. May 20, 2020 at 2:59 PM
    #6726
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    On my failed jackstand a couple teeth broke off, probably more due to casting quality.
    Beretta4x4 and spencermarkd like this.
  7. May 20, 2020 at 3:03 PM
    #6727
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    So the people that hate on buying the chinese HF stuff, are you of buying the same item in snap on labeling that came from the same assembly line?
  8. May 20, 2020 at 3:11 PM
    #6728
    tacoma_ca
    Good question. I am probably one of the haters you mention. These days I have 2 heavy steel ramps but usually I just put 2 wheels up on the curb. If I needed to get jackstands again yeah I would probably shop for the best ones I could find.
  9. May 20, 2020 at 3:20 PM
    #6729
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i have the 29 dollar 4 gallon backpack sprayer. ive used it for 3 years to clean the siding on my house with a bleach / water mix. For a quarter of the price of the competition its fantastic.
    I have a hammer drill, oscillating cutter, reciprocating saw that i cant kill, Jack Stands (non recall), Ditch lights w/wiring kit, torque wrench, various other tools. i dont have alot of bad things to say about the tools that i bought there besides im supporting chinese businesses
    if it comes to trying to do a job with the wrong tool that cost me hours vs the right tool that does it in minutes ill have to make the drive to harbor freight. Granted if i plan on using the tool alot i do buy quality. Most of my air tools are name brand used and rebuilt
  10. May 20, 2020 at 3:49 PM
    #6730
    HawkShot99
    Kingston, NY
    A few yrs ago, Snap On was caught selling a floor jack that was identical to the harbor freight Daytona jack. They were made on the same assembly line, just painted different. The prices were also significantly different, but many people I'm sure would trust the snap on while trashing on the harbor freight.
    https://biztimes.com/snap-on-harbor-freight-settle-floor-jack-case/
  11. May 20, 2020 at 4:47 PM
    #6731
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Does anyone know if Harbor Freight sells a Bull Shit Detector?
    Asking for a friend.
  12. May 20, 2020 at 4:49 PM
    #6732
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Just ordered 2 sets of the same 6 ton Prolifts earlier today.
    eon_blue[QUOTED] likes this.
  13. May 20, 2020 at 6:01 PM
    #6733
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Anyone used the McGraw 20 gallon oil lube compressor?
  14. May 20, 2020 at 7:43 PM
    #6734
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Wonder why HF just doesn't let the factory bend that tab in?
    Toy4me and eon_blue[QUOTED] like this.
  15. May 20, 2020 at 7:53 PM
    #6735
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    It's so they can put the stands in a smaller box when the extension is packed on the side of the main body of the stand.
    tomwil[QUOTED] and auskip07 like this.
  16. May 20, 2020 at 7:57 PM
    #6736
    Fire Chicken
    Fire Chicken Aka 'Panda Express'
    Charles
    2019 Tacoma TRD Off-road 4x4; 1979 Pontiac Trans Am WS6
    To add to that, how much would a machine cost to bring the two pieces of equipment together? I imagine they arent made in the exact same place, then putting the extension in place and bending the tab would be another machine function, more maintenance, less parts in a container therefore increasing the cost to ship + cost of extra material. All of this would increase the price or decrease the profit margin. Just telling people to bend the tab is way cheaper. How much more would people be willing to pay for their stuff vs going to a "higher quality" name brand? Pretty sure my husky set didnt come pre bent either.
  17. May 20, 2020 at 8:42 PM
    #6737
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Y’all are fools if you use jack stands from HF. I buy shit from there but nothing that my life would depend on. We all know it’s cheap shit so why trust your life with it?
  18. May 20, 2020 at 9:56 PM
    #6738
    tacoma_ca
    Same aisle as the sale priced 22hp vertical shaft predator engine.
    mtip, Hunterdc1, teamhypoxia and 5 others like this.
  19. May 21, 2020 at 3:52 AM
    #6739
    koditten
    Kirk
    Central Michigan
    Bwahaha!
    Hunterdc1 and tacoma_ca[QUOTED] like this.
  20. May 21, 2020 at 4:35 AM
    #6740
    auskip07
    Skip
    Atlanta, Ga
    you would be a fool to only trust jack stands no matter what brand. you always want a backup. Jack + Jackstands etc holding the car up one primary one secondary.
