Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. May 21, 2020 at 5:27 AM
    #6741
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    I looked at mine...the blue ones from HF...they don't have a tab, but they do have a bolt that does the same job. And I actually had put them in....I know....I was shocked too :)
    spencermarkd and koditten like this.
  2. May 21, 2020 at 7:57 AM
    #6742
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have some HF jack stands but don't like them as I had a failure where the roll pin that holds the pawl sheared (not sure how) and then the pawl wasn't fully engaged into the tooth on the cast support. Scared the sh!t out of me when I lowered the vehicle on it as the stand dropped all the way down. I have a set of pinned home made ones that my dad made, and I recently bought a set of Esco. You can get the Esco also with steel top for axle tubes.
    https://smile.amazon.com/ESCO-10498...ywords=esco+jack+stands&qid=1590072695&sr=8-2
    tacoma_ca likes this.
  3. May 21, 2020 at 7:58 AM
    #6743
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Is it worth getting an HF torque wrench? Or should i get a better one?
    rob1208 likes this.
  4. May 21, 2020 at 7:59 AM
    #6744
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Get a HF torque wrench.
  5. May 21, 2020 at 8:01 AM
    #6745
    jproffer
    Jim
    Perryville, MO
    I have all 3 sizes. They seem to be ok. I've never checked it with a digital gauge, but some on here have and say they're dead on. I didn't care that much. If it's off a pound or 2 or 5, it's not the end of the world...I'm not rebuilding engines...and if I was, I'd probably buy a better one.
  6. May 21, 2020 at 8:04 AM
    #6746
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The HF torque wrenches are just as accurate as any other clicker type.... which is mostly ok. The digital gauge is good to have to get a reference on the first use of the day as day to day temperature can mess with a clicker type wrench.
    tacoma_ca and jproffer[QUOTED] like this.
  7. May 21, 2020 at 8:09 AM
    #6747
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    To answer your question about the cost difference: most horizontal shaft engines have different bearings as they are expected to handle loads approximately commensurate to their weight axially or radially. Most vertical shaft engines handle loads predominantly radially, but axial accessories can be driven at higher loads. In this case, there is likely a big difference in the bearing design for the vertical shaft so it can handle a greater load axially.
    Definitely some key distinctions for differences in bearing design, engine balancing as well as mounting too.
    koditten[QUOTED] likes this.
  8. May 21, 2020 at 8:14 AM
    #6748
    jproffer
    Jim
    Perryville, MO
    By digital I meant those little digital torque gauges you add to a regular ratchet...but still it's good to know a way to check a clicker, if you want to.
    I'm no professional by any means, but AFAIK most bolts, with the exception of bolts within the engine, aren't that critical when it comes to torque. Some on the front end are semi-critical, but most can be tightened and calibrated to a "UHHHH...ok, that aint goin anywhere" and that's close enough. Naturally it's better to torque to specs if you can, but on some things you just can't do it (driveshaft mounting comes to mind...both ends).
  9. May 21, 2020 at 9:26 AM
    #6749
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Should go without saying but so should not depending on HF for life items. I use stands and jack AND if the tire has been removed, I slide it under the LCA or frame also.
  10. May 21, 2020 at 9:46 AM
    #6750
    nd4spdbh
    SoCal
    Honestly thats with anything not just HF tools. Never rely on a single point of failure, always have a backup (whether it be a tire under a frame, floor jack up under a jack point with no pressure on the jack, but the pad right at the jack point)
  11. May 21, 2020 at 10:43 AM
    #6751
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I just got my pair of 6 ton jack stands refunded today.
    Since I got them on sale for $39.99 plus tax that is what they put on the store gift card ($43.37). I would have done an even swap for newer ones but none were in stock or on sale.
    There is really nothing in the entire store I would like to purchase as I switched to Tekton for hand tools and I'm not real fond of China crap right now.
    Guess when the 6 ton jack stands are back in stock and on sale for $39.99 I'll get another pair. Hope the store credit doesn't expire.
    And all those times using the recalled jack stands there was this little voice telling me to back up the jack stands with one or more of my floor jacks, glad I listened!
  12. May 21, 2020 at 11:46 AM
    #6752
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    How do they know what you paid for them? Should be credit for a new pair of stands. Id be pissed if they never go on sale for that amount again, and I have to shell out extra $ to get a new set.
  13. May 21, 2020 at 11:51 AM
    #6753
    rcarpio19
    rcarpio19 Well-Known Member
    Ronnie
    2019 Cement Tacoma TRD OR
  14. May 21, 2020 at 11:54 AM
    #6754
    eon_blue
    Azusa, CA
    jubei, GHOST SHIP, boston23 and 6 others like this.
  15. May 21, 2020 at 11:56 AM
    #6755
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    WHAT RECALL ARE YOU TALKING ABOUT :goingcrazy:
  16. May 21, 2020 at 12:04 PM
    #6756
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    I think the bigger issue in the background is most of these stands are made in China. I'm a little concerned about alot of them now. There is no room for error in something that can save your life.
    I have some craftsman stands but they are probably made at the same factory. I need to find quality jack stands and pay up for them.
    Do we know if there are cases of folks being killed using these, or was it a precaution?
    w.adventures likes this.
  17. May 21, 2020 at 1:24 PM
    #6757
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
  18. May 21, 2020 at 2:24 PM
    #6758
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  19. May 21, 2020 at 4:35 PM
    #6759
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    :amen:
    auskip07[QUOTED] likes this.
  20. May 21, 2020 at 4:43 PM
    #6760
    burrito782
    08 TRD Off Road
    Hopefully they were just minor injuries. I know anytime I'm working underneath my truck and have that evil split second thought of, "...what if this thing were to fall on me right now?..." I then find myself thinking that hopefully it kills me as I'm not sure I want to survive being a crushed vegetable the rest of my life.
