Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Jun 7, 2020 at 10:08 PM
    #6881
    dclbYak
    dclbYak Well-Known Member
    19ssmDCLBtrdOR
    Now u got me thinking what i can do with the extras I have!
  2. Jun 7, 2020 at 10:14 PM
    #6882
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    I thought the same thing. Don't do it! Once you start you'll get pulled into a deep hole. I took the old tuner dial from the console and wanted to see if I could get the light working, so I cut up an old USB cable and did some testing. Got it to work, now I don't know what to do with it.
  3. Jun 8, 2020 at 11:55 AM
    #6883
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Use of a torque wrench of any kind is actually one of the most inaccurate ways to torque a bolt. There is a great Aviation Mechanic, Mike Busch who has many webinars and articles about this topic. In his research he found that measuring the bolt stretch is actually the best way to properly torque a fastener. Because you cannot measure that for fasteners in blind holes, the next best method is to use angle measurements, this is what high-end race teams do. They snug up a bolt, then tighten a specific number of degrees of rotation.
    As far as using a torque wrench, he had many suggestions, because technique can change results drastically. His recommendation is to lube the bolt and/or nut with STP before assembly. Then you snug the bolt, then you torque to half the final spec, then you complete the final torque to the final value you need. It is incredibly important that with each torque you move the wrench in ONE fluid motion, not "bouncing" it to reach the final value. Frictional loss and not being fluid with the movement can vary your final result wildly.
    His favorite torque wrench is the digital type as they use the most accurate sensors.
    davidstacoma likes this.
  4. Jun 8, 2020 at 12:02 PM
    #6884
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I have a suspiciously similar one from a different brand. They aren't a safe per se, but they'll keep your kids, or dumb friends from messing with your stuff.
    shane100700 likes this.
  5. Jun 8, 2020 at 2:50 PM
    #6885
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Anyone have either one of the pop up canopies? I’m a fan of the straight leg version because the offer more shade and you can join multiples together to cover a larger area. Just wondering: at double the cost of the slant leg, are you getting double the canopy? The straight leg version is labeled “heavy duty”.
  6. Jun 8, 2020 at 3:00 PM
    #6886
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Many times the “dry” torque spec is different than the “wet” torque. If you lube the bolt and torque it to a dry spec, you may be over tightening it.
  7. Jun 8, 2020 at 3:05 PM
    #6887
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Academy has their 10x10 on sale for $39 right now. I assure you, it’s better quality than that one.
    theredofshaw likes this.
  8. Jun 8, 2020 at 3:40 PM
    #6888
    GHOST SHIP
    GHOST
    “we are an able to ship to CA at this time.”
    :pout:
    MolonLabeTaco[QUOTED] likes this.
  9. Jun 8, 2020 at 4:21 PM
    #6889
    tamer
    tamer hamerworx.com
    NorCal
    That's basically what I was getting at. Unless you are very meticulous, it doesn't really matter what torque wrench you use, the error will be there.
    Bolts used in high vibration and engine assembly are really the only ones that require that much attention to detail.
    koditten likes this.
  10. Jun 8, 2020 at 7:02 PM
    #6890
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Added an end cabinet on my gen1 cart. Love the extra spave. Next purchase will be the 44” roller.
    also bought the new Fortress 27gal air compressor, but it only came with one bolt for the wheels and it seems to have a leak somewhere I cannot find by spraying soapy water on all the connections. I’m going to be taking it back. Might get the Kobalt quiet tech 26 gallon instead.
    Burns and shane100700 like this.
  11. Jun 9, 2020 at 6:36 AM
    #6891
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I want an end cabinet, just think they're overpriced.
    Anyways, coming from someone who has a 44" and love it, go ahead and get one size up if space allows..
    Gunshot-6A likes this.
  12. Jun 9, 2020 at 6:42 AM
    #6892
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Just be mindful if you fill the extra end cabinet up, itll become a bit more tipsy in that direction. Not a big deal if you dont move it around but something to consider when pushing it. Ive seen guys eith add casters under it or move the fixed casters from the orginal cart to under the cabinet (with spacers)
    G.T. likes this.
  13. Jun 9, 2020 at 6:54 AM
    #6893
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    the 44” with the top cabinet will probably be perfect. Just not now, don’t have space. Need a detached garage first.
  14. Jun 9, 2020 at 6:54 AM
    #6894
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    yeah I know. It’s a heavy SOB to be a small cabinet. The cart stays stationary 99% of the time so it’s not an issue.
  15. Jun 9, 2020 at 1:30 PM
    #6895
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    So far into hardpack with some rocks not bigger than a softball. I need to put a lime tree into pure untouched clay, will update with how that goes.
    malburg114[QUOTED] likes this.
  16. Jun 9, 2020 at 9:33 PM
    #6896
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I used the coupon I posted earlier and picked up the 30" shop fan. This thing is a beast. I think I'm going to hang it upside down from the rafters in the corner of the garage to save space.
    Hyperion, 916carl, ACEkraut and 2 others like this.
  17. Jun 10, 2020 at 9:11 AM
    #6897
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Ned bolt/D ring project in the works
  18. Jun 10, 2020 at 9:12 AM
    #6898
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Fack, all my 3 local HF stores look like this. No comments. :facepalm:
    shane100700 and whitedlite like this.
  19. Jun 10, 2020 at 9:35 AM
    #6899
    whitedlite
    USA!
    3RD Gen TRD 4WD
    hahaha, i bet it's weird being in there without any natural light.
  20. Jun 10, 2020 at 9:50 AM
    #6900
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    $39.99 at Wal-Mart
    This is the 2nd one I buy. It's good for seasonal use. For heavier duty I have the 13x13 Coleman from Costco.
    srspicer and Coolerman like this.
