Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Dec 11, 2020 at 1:07 PM
    #7321
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Extension cord not the best idea...more so welding galvanized is not a good idea at all!
  2. Dec 11, 2020 at 1:17 PM
    #7322
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    The trick is to just not inhale! :rofl:
  3. Dec 11, 2020 at 3:55 PM
    #7323
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Just went to look for an 8” bench grinder (the orange one). Stopped by three separate HFs and they were all out of stock but noticed that most of the bench grinders were on clearance. Website removed them as well. From my time in retail this usually means a new product is coming into replace current stock. Anyone have any heads up?
    Gunshot-6A likes this.
  4. Dec 11, 2020 at 4:02 PM
    #7324
    Tacomania
    Tacomania IG: _tacomania
    Crazy Mike
    86 4runner / 2016 SR5 Tundra
  5. Dec 11, 2020 at 4:10 PM
    #7325
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    The 15% off any item (including floor jacks) coupon is a better deal unless you're getting a really cheap jack.
    I picked up the yellow super duty floor jack this afternoon for $185 (coupon is 20% off with the inside track membership so I mooched my buddy's). Decided on it over the low profile long reach because it had bearings in alot of connections that were just a pin through a hole in the frame on the low profile long reach. Also liked the abundance of grease zerks on it. Pretty stoaked to try it out on some suspension work as soon as I get a break in the rain.
  6. Dec 11, 2020 at 4:21 PM
    #7326
    Tacomania
    Crazy Mike
    I have the one with tallest reach. I am pretty sure someone knows someone who has the club membership ;)
  7. Dec 11, 2020 at 4:25 PM
    #7327
    plurpimpin
    PDX
    True. I’m all for the right things from HF but I feel like everyone has that buddy that insists EVERYTHING there is just as good as the name brand... so naturally he’s a member of the club.
    Tacomania[QUOTED] and Kilowog like this.
  8. Dec 11, 2020 at 7:58 PM
    #7328
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    thoughts on this low profile long reach 3ton? These weigh 100lbs This is what you got? Only yellow color available Per below YouTube video, looks like HF jacked up the price from $209 eight months ago to now $229
    At 8:16 min
    https://youtu.be/bdroNFBPYFs
    TK-422 likes this.
  9. Dec 11, 2020 at 8:42 PM
    #7329
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I think we have the same jack. I’m pleased with mine. I’ve used it on my truck a number of times between my suspension swap and yearly snow tire swap.
    HawkShot99[QUOTED] likes this.
  10. Dec 11, 2020 at 9:12 PM
    #7330
    plurpimpin
    PDX
    I got the second one. I don’t think you can go wrong either way but went with the super duty. And yes only yellow on that one.
    It had bearings in a few pivots that the low profile long reach didn’t, more grease zerks, and the hydraulic piston was slightly larger. This appealed to me more than the extra 1” of travel.
    Also worth mentioning I picked this up Christmas shopping for myself so I wasn't paying for it and didn’t worry about the price difference.
    Lots of folks have also said great things about the low profile long reach on here.
    Also definitely 100lbs. They’re hefty, they carted it out to my truck on a hand cart.
  11. Dec 12, 2020 at 8:03 AM
    #7331
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    I know, I need to get a heavier gauge extension if I'm going to do that.
    I ground off what galvinized coating was left beforehand (that fence is the better part of 40 years old) it's mostly just paint covering it now. Plus I'm running flux core which helps take care of any galvinizing material left over.
    https://youtu.be/L2X96XByORo
  12. Dec 22, 2020 at 12:25 AM
    #7332
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Today I picked up a combo 1" x 30" belt sander and 5" disc sander. I have an old HF 3" belt/disc sander and it is a POS. When you try and sand on it there is not enough power and it just stops. I was worried that this might be the same but it is not. After some assembly required I kicked it on and grabbed a 3" screw since it was close and shoved it into the belt. Sparks went flying and it chewed the head off in seconds.
    Next I did the same with the disc. It was just as powerful. For what I will do next I replaced the 60 grit belt with a 120 grit one. The 5" disc is an adhesive backed one. I didn't look for replacements or other grits yet.
    So far I give it a big thumbs up.
  13. Dec 22, 2020 at 12:38 AM
    #7333
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    I would prefer the . although it doesn't have quite the reach as the Daytona it only weighs 63 Lbs. I have the 2.5 for years and it works great but might get the 3 at some point for the extra 1" of lift. The 2.5 is only 54 Lbs.
    I have had the full steel ones from HF in the past including the long reach one but got tired of lugging around all the weight of a steel jack and got rid of them.
  14. Dec 22, 2020 at 8:59 AM
    #7334
    GHOST SHIP
    GHOST
    You can add the pro eagle extension to your aluminum jack to add some height and versatility. I added the base plate to both my old Pittsburgh 3 ton steel jack and the 2 ton aluminum jack and I can swap the extension between the two as needed.
    I’d also recommend buying the pad and extension from Kartek rather than directly from pro eagle to save a few bucks.
    base plate:
    https://www.kartek.com/parts/pro-ea...s-into-their-extensions-has-a-1-116-hole.html
    extension:
    https://www.kartek.com/parts/pro-ea...34-to-7-78-has-three-1-adjustment-points.html
  15. Dec 28, 2020 at 9:21 AM
    #7335
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I don’t buy anything jack / jack stand related from a company until they have not one, but two recalls for the same thing. And a coupon. :rofl:
  16. Jan 1, 2021 at 2:31 PM
    #7336
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    The Apex 12k winch is 200 off right now. I love mine. Works great. Had to use it 4 times in one day.
    w.adventures and MCJohnston like this.
  17. Jan 2, 2021 at 12:01 PM
    #7337
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  18. Jan 5, 2021 at 9:46 PM
    #7338
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    My wife is a nurse working in the coov unit. She was eyeing my Uvex bionic face shield but it was a little heavy to wear for a 12 hour shift.
    I picked her up a which is still way more sturdy than the ones her work provides but still light weight enough to wear all night.
    She said it was a big hit at work and everyone was asking her where she got it.
    I stopped by one at lunch today and grabbed the three they had so she can share.
    Bleep100, Afilao, la0d0g and 20 others like this.
  19. Jan 20, 2021 at 8:15 AM
    #7339
    BCV
    BCV Active Member
    2014 Tacoma Texas Edition
    Picked up this cart to be able to roll tolls between garage and shop. Pretty impressed with it. It's as strong, it not, more durable than my neighbors blue point.
  20. Jan 20, 2021 at 3:50 PM
    #7340
    Slashaar
    Josh
    Kansas City, MO
    Mine survived flying off my trailer at 45mph on a corner getting on the highway. It went inverted and landed on the the lid and slide about 5 foot into the front of a ford f150. Luckily it lost its momentum by the time it hit the ford and did no damage, even though the guy was flipping out until he realized he couldn't extort us for money....side tracking here. Long story short, the thing is durable. The lock internally broke though, so I can pull drawers with the lid down, but I see that as a feature not a failure. Only thing that came loose was the handle on the lid, just screwed it back in. It was fully loaded at the time.
    davidstacoma and EPBlueTaco like this.
