Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Aug 15, 2021 at 2:59 PM
    #7641
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    By the specs the lumens are different but only by 50 lumens. Then the CRI is slightly off.
    Most likely they are made by the same manufacturer.
    tacoma_ca[QUOTED] likes this.
  2. Aug 15, 2021 at 6:31 PM
    #7642
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    The are in Calabasas, CA
  3. Aug 16, 2021 at 9:03 PM
    #7643
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    I used it to make a house number plaque and it turned out decent, considering I haven't used one since high school (many decades ago). The saw seems well built and solid. Worked great and no complaints.
    CJREX, BOMBS, Burns and 8 others like this.
  4. Aug 17, 2021 at 4:46 AM
    #7644
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    I don’t know, I think “decent” is an understatement. That looks pretty good!
    CJREX, 916carl[QUOTED] and Slashaar like this.
  5. Aug 17, 2021 at 7:01 PM
    #7645
    ReefSR54X4
    ReefSR54X4 JerzeeBwah
    Jersey
    2016 BB AC SR5
    anyone ever use one of these for bed light?
    Slashaar likes this.
  6. Aug 17, 2021 at 8:57 PM
    #7646
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I have 6 of those as rock lights. Pretty good actually. Construction seems top tier (heavy cast aluminum and epoxy sealed housing) and the light output is really good for a work light/wide beam pattern.
  7. Aug 17, 2021 at 10:02 PM
    #7647
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Pics?
  8. Aug 17, 2021 at 10:06 PM
    #7648
    GHOST SHIP
    GHOST
    Pics never do justice to anything lighting but this is the best I got.
    My outdoor lights are on but you can see the spread of light with a light in each wheel well and another under the rocker panel between the door jambs.
  9. Aug 17, 2021 at 10:28 PM
    #7649
    Slashaar
    Josh
    Kansas City, MO
    Too bad the leafs block a lot of the light behind the tire. Front and rockers are good for night wheeling, rear is good enough!
    I'm considering doing a split front camera setup with two feeds, one over each tire to an aftermarket head unit so I can spot myself if need be.
  10. Aug 18, 2021 at 7:12 AM
    #7650
    ReefSR54X4
    Jersey
    2016 BB AC SR5
    cool. Nice set up!!
    I was going to install in the storage bin in the bed. Leaving slack so I can pull it out to move around. And use the wire kit with switch, relay and fuse
  11. Aug 18, 2021 at 7:27 AM
    #7651
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Their business model is affordable tools but I welcome some internal testing so they don't sell crappy pot-metal stuff that breaks on first use.
    My opinion is that if Harbor Freight, Lowes and HD continue on their current trajectory then Lowes and Home Depot may be known as the "expensive junk tool companies."
    Personally I'm a fan of having both inexpensive and heavier quality items. My last visit to Harbor Freight I had the choice of a $24 Pittsburgh torque wrench or a $104 Icon. I chose the $24 model as I use it infrequently and is easy enough to calibrate.
    I'm a fan of HF but it may take some time for them to lose the "Hobo Freight" endearing nickname. :)
  12. Aug 21, 2021 at 11:34 PM
    #7652
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    is that a talon? If it is have you had any major issues with it?
    Delta09[QUOTED] likes this.
  13. Aug 22, 2021 at 6:03 AM
    #7653
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yup. It's a '95 Non-turbo. Its got gobs of issues, mostly rust. Has the usual rusty rockers and has some rot in the drivers shock tower that I'm gonna have to figure out how to fix. The engine leaks and smokes, but has over 237K. I bought it back in April from an old friends mother to use as a go to work beater. Actually helped replace the engine in it back when I was in high school in 2006. Thing has quickly been a thorn in my side ever since I bought it :rofl:
  14. Aug 22, 2021 at 6:16 PM
    #7654
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Did it have any major issues...
  15. Sep 4, 2021 at 10:20 PM
    #7655
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They cannot even build a decent extension cord.
    Hardscrabble likes this.
  16. Sep 4, 2021 at 10:39 PM
    #7656
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Who uses the ground plug anyways? Now you can plug it into any power strip or non-grounded extension cord. Imagine the new possibilities.
  17. Sep 5, 2021 at 12:44 AM
    #7657
    6 gearT444E
    Deep South
    Herculiner Hootus
    ground is over rated. You don’t need it until you need it….oh wait.
  18. Sep 8, 2021 at 8:02 PM
    #7658
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Ha. My $20 angle grinder has definitely paid for itself several times over between cutting off bedsides, cab mount chop, grinding off rusted bolts, using the flap discs to clean up crusty leaf springs and prep armor for touch ups, cutting ubolts, adding a hinge to the boat trailer, trimming up plexi to replace a broken window on my shell, and various house projects over the years. Sometimes is does struggle cutting thicker metals but for the most part it has been unstoppable.
    Glueman, Chuck X1, Wulf and 6 others like this.
  19. Sep 8, 2021 at 8:20 PM
    #7659
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Any long term reviews on the Hercules table saw? Been looking at the one with the rack and pinion..
  20. Sep 8, 2021 at 9:02 PM
    #7660
    Scottysan
    Scottysan Well-Known Member
    I was just thinking along those lines, that a few of these would work well as cargo lights under the cap.
