Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Mar 14, 2023 at 2:54 PM
    #8921
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Interesting, I just youtube'd it. I've owned marine, rv and portable gensets and didn't know this was a thing. thanks.
    la0d0g and dumontrider like this.
  2. Mar 14, 2023 at 5:06 PM
    #8922
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I have heard this asked, but don't really know ow what it means.
    For now, I drove to my parents and am borrowing their Harbour Freight generator, I think the 4k size. I'll look into what flashing is, but I'm not very good with electronics so we shall see.
  3. Mar 14, 2023 at 5:51 PM
    #8923
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    I have no generator and had not heard that term before, but I was curious so I looked it up;
  4. Mar 14, 2023 at 6:19 PM
    #8924
    HawkShot99
    Kingston, NY
    I'll look into this more now since I have a loaner generator.
  5. Mar 15, 2023 at 8:47 AM
    #8925
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    https://youtu.be/5r3hoxMryEI
    This reminds me I haven’t exercised my generator in quite a while.
    EL Taco Verde likes this.
  6. Mar 16, 2023 at 10:16 AM
    #8926
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    You're paying for the motor. The chinese HF engines are OK, but they are not Hondas. Which is why a Honda generator costs 3x more.....
    Edit: Honda is 5.5x more.
    https://powerequipment.honda.com/generators/models/em6500
  7. Mar 23, 2023 at 6:51 AM
    #8927
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Well, I need to pull my Chicago Electric flux core welder apart. Was finishing the last (thankfully) weld on my log splitter trailer and it stopped feeding. If I release the tension roller, it will spin the feed motor. However, once there is tension, it will feed for about a second then stop.
    So, I am hoping it is just a loose connector and the motor shifts just enough when put under tension.
  8. Mar 23, 2023 at 7:01 AM
    #8928
    szidls
    szidls Well-Known Member
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    Does it need a new liner in the whip? Tip good? Just checking.
    golfindia likes this.
  9. Mar 23, 2023 at 7:25 AM
    #8929
    windsor
    windsor Just a guy
    Homeless in Oregon
    Liner is good, tip is brand new. Swapped the tip right after it stopped. Wire is not binding, I can freely move it by hand. The motor itself is not turning on.
    Because it works for about a second after tension is released and re-applied makes me think it might be a connector.
    Gen3TacomaOBX likes this.
  10. Mar 23, 2023 at 7:41 AM
    #8930
    szidls
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    Trying to help troubleshoot. Possibly a connection in the trigger? Hope it's an easy fix.
    windsor[QUOTED] likes this.
  11. Mar 23, 2023 at 4:18 PM
    #8931
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Purchased the Bauer 1600 heat gun. Needed it for some heat shrink/solder wire connections for my auxbeam switch panel and ditch lights. Works good and gets very hot. On sale for $5 off right now.
  12. Apr 1, 2023 at 7:15 AM
    #8932
    szidls
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    Does anyone have experience with this sprayer for staining? I’m rebuilding about 10’ of cedar fence and a gate. Thanks
  13. Apr 1, 2023 at 9:00 AM
    #8933
    HawkShot99
    Kingston, NY
    I have it. Used it to stain my moms 6' privacy fence a few times. Works well, but really needs a bigger holding tank as I was draining it so fast.
    Cleaning it when your done is super important so all the little passes don't clog up.
    szidls[QUOTED] likes this.
  14. Apr 1, 2023 at 3:28 PM
    #8934
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    My store hasn’t gotten the 1/4” gold ratchets in yet, whomp whomp.
    Did walk out with a 30” service cart though. Coupon had them down to $99 and I added on a 4 drawer tech cart side shelf thing. Only two of the four holes line up for it, but seems sturdy enough.
    Loooon820, Drainbung and Kwikvette like this.
  15. Apr 1, 2023 at 3:31 PM
    #8935
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just bought mine 2 days ago!
    Put it together and haven't touched it since; was wondering if I should've bought that side table or just make one.
  16. Apr 1, 2023 at 4:02 PM
    #8936
    spencermarkd
    Spencer
    I mean, I know you’re looking to cut more things haha but can you get materials and hinges for under the $25 the table costs?
    Edit: only thing I’d add is maybe some magnets or rubber to keep it from rattling while it’s folded and being moved around.
  17. Apr 1, 2023 at 4:05 PM
    #8937
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    The April Fool's shit is hilarious.
    All my metal is left over from "orders" (paid for) so really I'd just need hinges.
    spencermarkd[QUOTED] likes this.
  18. Apr 1, 2023 at 4:20 PM
    #8938
    HawkShot99
    Kingston, NY
    Just got home with the 6500w generator. $640, and then 15% off all predator stuff this weekend for Inside Track Members.
    wilcam47 and spencermarkd like this.
  19. Apr 7, 2023 at 3:14 PM
    #8939
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Tool Box.jpg I ran out of room so I added another set of the 14" Drawers today.
  20. Apr 15, 2023 at 6:41 PM
    #8940
    spencermarkd
    Spencer
    I had to do it :anonymous:
    Slashaar, rob1208, jackn7 and 8 others like this.
