Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Sep 24, 2023 at 9:35 PM
    #9121
    RedSingleCab
    RedSingleCab Well-Known Member
    Socal
    2008 RC 4x4
    Just found this thread. Harbor Freight can't be beat for a lot of things if you're a hobbyist like me. If you're just a little discerning, you can save so much at HF vs. Home Depot or Lowes for tools that are as good if not better, and don't get me started on the auto parts store-branded tools. Anecdotal (and definitely not recommended), but my 6-year old HF torque wrench I bought for $20 has outlasted two Tekton torque wrenches that both had strange catastrophic failures. Calibration doesn't seem off, but I've only compared it to the aforementioned Tektons.
    Laxtoy and EL Taco Verde like this.
  2. Sep 25, 2023 at 12:15 AM
    #9122
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    I’ve been considering swapping the synthetic rope eventually. I’ve only ever used steel cable though, how does the rope hold up to the weather?
    wilcam47 likes this.
  3. Sep 25, 2023 at 6:46 AM
    #9123
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    Synthetic rope hold up well in the weather. It's original use was in the marine industry.
    Laxtoy likes this.
  4. Sep 25, 2023 at 6:55 AM
    #9124
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Public service announcement. I blew out 2 daytona jacks in the span of about 1 year. The first 3 ton daytona lasted about 9 months. It suddenly wouldn't lift anymore. So I swapped it out for the same jack. That one only lasted 3 months!
    So after some research, the instruction manual mentions bleeding the jack before use. I read they can blow out seals if you don't bleed out the air. I upgraded to the daytona super duty. This time I bled the air and sure enough there was air in the hydraulic system. Bleed them jacks!
  5. Sep 25, 2023 at 5:56 PM
    #9125
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Bought the icon screw extractor 25 piece set today and am pleasantly surprised with the quality, I am not sure what I will ever use the 7/8 inch extractor for though. Ive already got Snap On and Mac screw extractors sets but I needed very stubby ones for a special job with about 2 inches of space to work in. I would still rather the traditional longer extractors for when there is enough space, especially if the bolt is rusty.
  6. Sep 25, 2023 at 10:55 PM
    #9126
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    It’ll rot after time, sun and rain will deteriorate it, but it’s so much safer and easier than steel. I hate spooling steel winch cable, birds nests if you don’t keep tension on it, super hard on the hands (I always wear gloves, still tough to deal with) and heavy. Gotta spool the synth line tight to make sure it won’t cleave into the wrap below it, not that difficult though.
  7. Sep 26, 2023 at 7:18 AM
    #9127
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Tekton has a great warranty program, did you get them replaced?
  8. Sep 26, 2023 at 9:59 AM
    #9128
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    Thanks! I’ve only ever used steel so like everything it’s a learning process. Steel is kind of a PIA to spool back up after use. Gloves are very important when dealing with the steel cable. Perhaps I’ll switch and see how it goes!
  9. Sep 26, 2023 at 11:02 AM
    #9129
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Correct- dyneema (UHMWPE/spectra) is great. Cheap, easy to splice. Holds up great, but it does weaken with UV exposure over time. The recovery industry has really run with some of the more niche stuff we used to have to custom make (closed loops, soft shackles, etc).
    Laxtoy[QUOTED] likes this.
  10. Sep 26, 2023 at 7:22 PM
    #9130
    la0d0g
    running for the hills
    For crawling not hauling
    Synth is so much better in every way. You'll never look back.
  11. Sep 26, 2023 at 11:25 PM
    #9131
    RedSingleCab
    Socal
    2008 RC 4x4
    Yeah I did, the 2nd wrench was the free replacement from Tekton, to be fair (which also broke under normal usage?)
  12. Sep 27, 2023 at 1:07 AM
    #9132
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    Thanks for the feedback. Being in Washington I always thought the constant state of being wet might help rot the rope but I’m sure that’s figured out
    la0d0g[QUOTED] likes this.
  13. Sep 27, 2023 at 2:22 AM
    #9133
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I believe you're supposed to soak it in silicone spray or something like that
    TacoGeeloor[QUOTED] likes this.
  14. Sep 27, 2023 at 2:34 AM
    #9134
    Neal4x4
    Neal4x4 Well-Known Member
    Southern California
    Truck.
    I have a set of their ratcheting straps that I've used on and off for at least 8 years, they still function as intended.
    Their electronics have been junk in my experience.
  15. Sep 27, 2023 at 4:37 AM
    #9135
    la0d0g
    I think of it as a consumable part. After five years (or however long) get a new one if needed. The key is to clean and inspect them.
  16. Sep 27, 2023 at 8:22 AM
    #9136
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I used cable on ATV, swapped to synthetic...synthetic was awful. Bound up froze, twisted, etc...i wont use it. I switched it back to cable.
  17. Sep 27, 2023 at 8:53 AM
    #9137
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    How are the heat guns here? I noticed they had a couple options.
    szidls, Toyko Joe and wilcam47 like this.
  18. Sep 27, 2023 at 8:54 AM
    #9138
    wilcam47
    Will
    Bourbon state
    I have one. Works great
    EL Taco Verde, szidls and Toyko Joe like this.
  19. Sep 27, 2023 at 8:56 AM
    #9139
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    I have the cheap one. Works well, just remember to run it on low heat for a while (30 seconds) before turning it off or it will cook the heater element.
    Kwikvette and OffroadJet like this.
  20. Sep 27, 2023 at 8:59 AM
    #9140
    medic2230
    Murph
    Bama! Roll Tide
    Wonder if that’s why every floor jack I’ve ever gotten quit working? Dammit. Who reads the manual on a floor jack?!?
