Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Sep 30, 2023 at 8:52 AM
    #9161
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I’ve had the 3 ton Daytona low profile/long reach jack for about a year and it’s been great. I’ve also had the 2 ton aluminum racing jack for about 15 years, and it still works good too.
    Coolerman[QUOTED] likes this.
  2. Sep 30, 2023 at 8:52 AM
    #9162
    Kwikvette
    Fresno County
    4 run, 2 don't
    Disregard, their sub $500 model looks close
    But I'm betting the Eastwood is a thicker top
    They always use metric to measure those tops but ideally you want 6mm which is close to 1/4" or better yet 8mm or 3/8"
    Sociopenguin likes this.
  3. Sep 30, 2023 at 8:55 AM
    #9163
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    It's a good table, @Slashaar and I have used many times to build schtuff.
    Slashaar likes this.
  4. Sep 30, 2023 at 8:55 AM
    #9164
    Kwikvette
    Fresno County
    4 run, 2 don't
    The flip up has always been their welding tables; tons of Amazon vendors call it something else but it's the same one that HF and Eastwood sells
    This is new from HF, and what stuck out immediately was "Kutch"
    Only 4mm which is 5/32" or, close to 9 gauge
  5. Sep 30, 2023 at 8:56 AM
    #9165
    Kwikvette
    Fresno County
    4 run, 2 don't
    At over $200, a sheet of steel and getting it laser cut locally is the best way really
    But for under that, looks like HF is going to be a hit
  6. Sep 30, 2023 at 8:57 AM
    #9166
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Mine crapped out the 4th time I turned it on. Made a big spark and never turned on again. Went with a dual-range Porter Cable after that and never looked back
    szidls[QUOTED] likes this.
  7. Sep 30, 2023 at 8:59 AM
    #9167
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    At the time, I just wanted a solid table. I can say it wasn't near what they are asking for it now.
    Slashaar and Kwikvette[QUOTED] like this.
  8. Sep 30, 2023 at 9:01 AM
    #9168
    Kwikvette
    Fresno County
    4 run, 2 don't
    Raw material is only going up and up
    I just need to score some 3/8" for cheap or free so I can get it lasered here locally
    I wouldn't want to ream out a ton of holes on such thick steel if my plasma cutter causes a little beveling in the holes, and I don't have a mag drill :(
    Sociopenguin[QUOTED] likes this.
  9. Sep 30, 2023 at 9:03 AM
    #9169
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    You ain't kidding on material pricing. I really wanted a larger top but damn they were pricey even then.
    Kwikvette[QUOTED] likes this.
  10. Sep 30, 2023 at 9:07 AM
    #9170
    Kwikvette
    Fresno County
    4 run, 2 don't
    I made myself a small extension to my table
    Will cut out the remaining underside slats once I score more free 3/16" :laughing:
    If it wasn't for this, that table I mentioned would've been perfect as a second table/fixture
  11. Sep 30, 2023 at 9:18 AM
    #9171
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    We have the Jegs version of these at my buddy's shop, I welded a couple angle iron straps to the bottom and they've been good can really clamp the shit out of stuff without the table deforming first now.
    jubei and Kwikvette[QUOTED] like this.
  12. Sep 30, 2023 at 9:25 AM
    #9172
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice
    Yeah a little stiffening and it'll be solid for most people really
    When I saw the reviews and stuff posted, I was intrigued until HF pulled it
    Maybe waiting to announce it on their new tool Tuesday or Thursday ads?
    I forget what day of the week they do that
  13. Sep 30, 2023 at 11:28 AM
    #9173
    szidls
    szidls Well-Known Member
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    treyus30[QUOTED] likes this.
  14. Oct 2, 2023 at 6:02 AM
    #9174
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    With all the reinforcement, do you have enough room for the clamps to go 360? Otherwise you're gonna be cursing.
  15. Oct 2, 2023 at 10:52 AM
    #9175
    Kwikvette
    Fresno County
    4 run, 2 don't
    Absolutely
    If you look at the two that parallel each other you'll see that's as close to the edge as it gets
    If you look at the half-triangle from the slat that runs perpendicular to it, you'll see all the room left in between
    If something needs to go closer to the center of the table, that's where the holes come into play for a top mount clamp
    I've made items for the city, county, and even Disneyland all on a flat surface welding table as plenty could be done without a welding table-fixture
  16. Oct 3, 2023 at 12:18 PM
    #9176
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    Bought some of their clamps , theyve been holding up suprizingly good imo.
    EL Taco Verde and dumontrider like this.
  17. Oct 7, 2023 at 2:15 PM
    #9177
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Picked up 4 Braun T8/T12 LED bulbs for fluorescent fixtures and they actually worked. Hoping I no longer have to replace them every year. Winter kills fluorescents.
  18. Oct 7, 2023 at 10:07 PM
    #9178
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    @Kwikvette - I saw this and immediately thought of you...
    rob1208, mtip, Slashaar and 3 others like this.
  19. Oct 7, 2023 at 10:30 PM
    #9179
    Kwikvette
    Fresno County
    4 run, 2 don't
    I need to buy myself a lathe, and or a mill...turn my own stops and whatnot for these tables :drool:
    I made one, but would you believe I have a larger one out of 3/8" being cut on a laser for me? Should be ready this coming week
  20. Oct 9, 2023 at 8:07 AM
    #9180
    Slashaar
    Josh
    Kansas City, MO
    That's pretty slick. I have one of those toolboxes...
