Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Feb 9, 2017 at 6:13 PM
    #921
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Those were free. They never send the coupon no more. :mad:
  2. Feb 9, 2017 at 6:15 PM
    #922
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I'll be looking I guess.
    Blackout14 likes this.
  3. Feb 9, 2017 at 6:20 PM
    #923
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    The motor has color coded leads that plug onto male spade terminals in its junction box. These can be configured to operate it on 120 or 240 VAC--a diagram showing what's what is on the motor label:
    To change it to 240 V operation:
    • the brown wire on terminal 5 is removed and reconnected to terminal 3;
    • the white wire on terminal 6 is relocated to terminal 5;
    The power cord and the lead from the switch to the motor are both 3 conductor SJ type cables--i.e. they have one black (hot), one white (neutral) and one green (ground) conductors--when connected to a single phase 120 V supply there is 120 V between the black (hot) and white (neutral) wires, and also between the hot and green (ground) as neutral and ground are wired in common at the branch circuit box.
    To use these cables with a "split phase" (actually 2-phase¹ though that is not common terminology) 240 VAC both the black and white wires will be hot, with 240 V between them, the green wire will be ground and there will be 120 V between both hot wires and ground. When doing this it is good practice to wrap black tape around the white wire at all connection points; i.e in the wall plug and in the pressure switch and motor junction box. This will alert a knowledgeable electrician that the white conductor has been re-purposed.
    ¹ - Most all residential power enters as 2-phase 240 VAC with two hot and one neutral wire, these are the outputs of the center tapped distribution transformer that "steps down" the "street power" to power for the residence. Diagrammatically it looks like this:
    Electrically it looks like this:
    Note that the end-tap outputs, when referenced to the center tap, are each 180° "out of phase" as compared to the other (when the voltage is high on one phase it is low on the other). This is the "split-phase" or 2-phase power. And because they are opposite in phase the voltage between the two end-taps is 240 VAC,
    In the entrance box of a residence the center-tap (neutral) is tied to ground, literally to a copper or copper clad rod driven into the ground. The white neutral wire in the residence's wiring exists only in that wiring and is tied to ground in the entrance box.
    T4RFTMFW and Blackout14 like this.
  4. Feb 9, 2017 at 6:21 PM
    #924
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    Wish I would have copied it. I just used mine to get a five pack for free last week.
  5. Feb 9, 2017 at 6:27 PM
    #925
    cliffyk
    Cliff
    Saint Augustine, FL
    I think it was you use of the term "positive"--there is no positive or negative with AC power...
  6. Feb 9, 2017 at 6:27 PM
    #926
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    Awesome cliffyk thanks
  7. Feb 10, 2017 at 10:46 AM
    #927
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    Does anyone have experience with hf biscuit jointer? I need one for a project and don't want to spend $100 +
  8. Feb 10, 2017 at 11:46 AM
    #928
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Same here, did stick, arc and spot welding. I should have put more effort into it, all i really made was ninja stars and weld my name into steel plates lol.
  9. Feb 10, 2017 at 7:22 PM
    #929
    Thelgord
    Augusta, GA
    I got the 170 amp mig welder today and un-boxed it. $169 with a coupon. Unfortunately my 220 outlet is 4 pin, so I will be going to Home Depot in the morning to get a 3 pin outlet to replace it. Then test it out and see what it can do.
    Soul Surfer and Blackout14 like this.
  10. Feb 13, 2017 at 10:54 AM
    #930
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
  11. Feb 13, 2017 at 4:13 PM
    #931
    Justinlhc
    Justinlhc Not looking for a relationship
    I've used the shit out of some husky and Kobalt tools. I have faith in those brands. I've got a Husky pressure washer that has been working great for years alongside a Husky compressor that has also worked great for years.
    Picked up these over the weekend along with some other crap. They smell weird and don't feel like real metal lol but we'll see if they last.
  12. Feb 13, 2017 at 4:20 PM
    #932
    Thelgord
    Augusta, GA
    A lot of people see these as junk, and treat them accordingly then say, "See! They are junk!". If you take care of them like any other tool most everything from HF will last. Except for the screw driver bits. Those are horrible no matter how you use them.
  13. Feb 13, 2017 at 4:38 PM
    #933
    Justinlhc
    I'm not sure how you can "take care of" a socket set besides not using them as chisels or smacking them with hammers?
    If the piece of shit snaps in half trying to loosen a nut(what it's supposed to do) I'm going to call it a piece of shit...because that's what it is. If it lasts and doesn't break immediately I'll be happy. I've been using my 10 year old Crapsman sockets on my impact for years and haven't broken one yet.
  14. Feb 13, 2017 at 4:40 PM
    #934
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Sockets from HF blow. End of story. The metal they use is as porous as a dish sponge.
  15. Feb 13, 2017 at 4:46 PM
    #935
    Justinlhc
    I've been using normal crapsman sockets on my impact for quite a while lol. I thought I'd give them a break and buy some sockets that were made for it. Especially since they were so cheap. :notsure:
  16. Feb 13, 2017 at 4:59 PM
    #936
    Justinlhc
    Similar to spacer lifts on TW :stirthepot:
    :spy:
    ...and diff drops :rofl:
    Thelgord[QUOTED] likes this.
  17. Feb 13, 2017 at 5:59 PM
    #937
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Just bought a breaker bar and torque wrench. Happy about the price and we will see about the quality.
  18. Feb 13, 2017 at 6:16 PM
    #938
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I just got a torque wrench. Ten bucks with the coupon!
    Benzdriver81 and ZachPrerunner like this.
  19. Feb 13, 2017 at 6:18 PM
    #939
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I love mine. Use it constantly and it seems to be on par with my Gearwrench.
    TACK[QUOTED] likes this.
  20. Feb 13, 2017 at 6:18 PM
    #940
    ZachPrerunner
    Southeast TN
    I got both and love them!
    bigfoote13[QUOTED] and 49erfan like this.
