Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Nov 6, 2024 at 7:16 AM
    #9701
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Predator power stations coming out in 2025.
    Plus new solar panels, also in 2025.
    Definitely intrigued by some of that stuff.
  2. Nov 6, 2024 at 10:32 AM
    #9702
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I don't know how the harbor freight boxes connect but I bolted a 1/2 inch sheet of plywood between my top and bottom boxes where the top is 1 inch wider. I painted the plywood black to match top box, unless your looking for it you wouldn't notice.
    atc250r, SR-71A and koditten like this.
  3. Nov 6, 2024 at 4:45 PM
    #9703
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I have been itching and waiting for that new trailer since Sema 2023. Finally we have a definitive preorder date (early december)and date of pick up date (end of January).
    jpereira2 and atc250r like this.
  4. Nov 6, 2024 at 4:50 PM
    #9704
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    What size is the deck?
  5. Nov 6, 2024 at 5:27 PM
    #9705
    crashngiggles
    Jared
    5x10.
    atc250r[QUOTED] likes this.
  6. Nov 7, 2024 at 4:25 AM
    #9706
    atc250r
    Orange County, NY
    Cool. I've got a old 5x8 from Lowe's that's very similar for my quad. It fits nice and leaves just enough room for a decent sized cooler behind the quad. An extra two feet would be useful. I'll have to keep an eye out for when it becomes available around here. Nothing on the HF website yet.
    wilcam47 likes this.
  7. Nov 9, 2024 at 1:36 PM
    #9707
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Picked up the Bauer version for free with the 79.00 battery pack deal,just to keep it in the same batteries I have, worked great on The tractor.
  8. Nov 9, 2024 at 5:20 PM
    #9708
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Every time I hang my christmas lights I'm reminded that this guy is worth its weight in gold: If you're a big baller, battery electric is clearly the way to go, but for $35 full price (does anyone pay full price at HF?) SO worth it to not have to use a manual staple gun several hundred times if you already have an air setup. I use it with my little 1 gallon hotdog compressor at around 60psi and it gets perfect depth without crushing the cable.
  9. Nov 9, 2024 at 5:50 PM
    #9709
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have this stapler. It works great! Sacrifice 3-4 staples while dialing in the pressure regulator and you will love it!
    Most aren't aware that you need to adjust the pressure via regulator valve to get correct penetration or prevent complete blow thru.
  10. Nov 27, 2024 at 9:55 PM
    #9710
    ivanjo3l
    ivanjo3l Well-Known Member
    Ivan
    DFW
    2019 Cavalry Blue Tacoma TRD Off Road
    Last Icon tools haul… Now to get everything organized in the toolbox / fab some custom mounts for TQ wrench / handle :thumbsup:
  11. Nov 28, 2024 at 7:36 AM
    #9711
    EL Taco Verde
    EL Taco Verde Well-Known Member
    2021 TRD Off Road
    Factory lift kit. Lomax tri fold Tonneau.
    Mini toolbox. Even came with liners. Just had to have it! Available in blue, black or red.
  12. Nov 28, 2024 at 9:26 AM
    #9712
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I've got a garage fab project coming up and needed a decent metal cutting saw. This setup, $200 during BF is a smokin deal. This replaced a bigger floor model HF metal bandsaw I used to own and IMO it blows that saw away. To make sure I got the stuff before BF I joined their club ($27) for early access, the store is stupid busy on BF.
    Vert config
    The only downside IMO is it's lack of a table vice to hold cutoff material. I picked up a HF drill press clamp that looks like half a vice grip and it holds stuff well.
    I considered a metal cutting saw but the blades are expensive, they tend to spew chips and worst of all they're LOUD, not ideal inside an attached garage. Band saws are quiet, blades are $17 for 2 and the debris collects under the saw in a small area where it's easy to vacuum up. Usually they're large and not worth the real estate in a small space unless you use them often. This setup is about the size of my miter saw, easily stored away.
    Chop setup
    I squared everything up and did a practice cut on some 2x2" .180 tubing and it was surprisingly square when stood on the cut end. I couldn't ever get those kind of results on the much bigger (Red) HF bandsaw I previously owned. When this is setup vertical this has the same cut depth the bigger version ($400) has. I have to rate this my #1 HF purchase.
  13. Nov 29, 2024 at 12:34 AM
    #9713
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    I bought the stand and the $99 5 amp hour battery that came with the free tool to get the bandsaw Wednesday. Also bought the Milwaukee thin and thick cut blades. I used it that night to cut tube for some DIY rock sliders. I’m really happy with it and I’m definitely a Milwaukee fan boy. For as often as it’s probably gonna get used it’s definitely a lot of bang for the buck. I must have been hurrying through the instructions because I completely missed it stands up too.
  14. Dec 1, 2024 at 11:43 AM
    #9714
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    A couple of months back I had to buy a new bandsaw blade. HF had blades for about $11, so I bought it. Not impressed with the performance. It cut, but very slowly.
    After being frustrated cutting some fairly hard steel, I went back and bought a "supercut" blade for almost triple the price. Now this one cuts like a blade should. I normally get blades from work which are Starrett bulk packs (I get the leftover pieces), and this new blade is comparable. The old blade has already been put in the recycle bin.
    Don't cheap out on blades, it just isn't worth it.
    ridefreak and Kwikvette like this.
  15. Dec 1, 2024 at 5:15 PM
    #9715
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    Took advantage of the Black Friday deals and snagged a Badlands Jack and an Icon Tap & Die Set.
  16. Dec 6, 2024 at 12:44 PM
    #9716
    spencermarkd
    Spencer
  17. Dec 7, 2024 at 12:14 PM
    #9717
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Hey guys, I just received the badlands 3 ton jack from the BF deal and it's a really solid unit. Only question I have is did anyone else get an extra nut that fits the axle? After inspecting the jack and parts diagram I don't see anything missing but it's always concerning seeing extra hardware floating about. It's not a nylock like the other axle nuts, but I have no idea what it's for.
  18. Dec 7, 2024 at 2:33 PM
    #9718
    crashngiggles
    Jared
    I did not receive an extra axle nut on mine, but who knows, it could have been a return or something else. Check out this thread.It is very informative.
    https://www.tacomaworld.com/threads/harbor-freight-badland-3-ton-off-road-jack-discussion.786678/
    Jojee117[QUOTED] likes this.
  19. Dec 7, 2024 at 2:51 PM
    #9719
    EL Taco Verde
    2021 TRD Off Road
    you can find a assembly diagram in the manual. Shows every part.
  20. Dec 7, 2024 at 3:57 PM
    #9720
    Jojee117
    Joe
    MT
    Yeah, I went through that but didn't see it on there which is why I'm a little confused.
