Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Jan 17, 2025 at 8:18 PM
    #9741
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    The click is there, but it’s mighty subtle, and easy to miss.
  2. Jan 17, 2025 at 8:50 PM
    #9742
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    So this past weekend i was finally able to order the brand new haul master 5x10 trailer at the store with no date on when it is going to come in, but for my purposes, that is more than ok with me. I have no garage and needs to be built. The greatest thing was that i got to use the 15% off anything in the store coupon on it last weekend so I got.a 1 ton trailer for $850. I have been waiting for this thing for a long time and if it is going to be as good as i think it will be, it is going to.turn the trailer industry on its.head. With its price and modularity, i am not sure if anything will beat it.
  3. Jan 19, 2025 at 7:31 AM
    #9743
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Last week I received the new handle and lock cylinder for my new-to-me series 2 lower box.
    I got the new cylinder in place and tested the lock. Upon trying to unlock it, I pushed in on the key to get it past the detent and started to turn when something inside went "snap" . The key just freewheeled and couldn't unlock the closed upper drawer, effectively locking me out of the box.
    I had to drill out the center of the lock then use a step bit to remove 98% of the trim ring on the cylinder so that I could shear off the remainder. I got lucky that the drill bit was able to basically remove the internal bits so that I was left was just the slotted brass stud attached to the metal rod that goes to the unlocking mechanism.
    I had to support that part up with a piece of romex that I was using as a hook while I grabbed it with some long needle nose pliers to turn the rod. It took about a dozen attempts before I was successful in getting the stupid thing to unlock.
    I made a wooden dowel that attached to the rod and sticks out of the key hole so that I can unlock the box for the time being.
    The HD customer service person took care of me and us sending another replacement lock set free of charge.
    EL Taco Verde likes this.
  4. Jan 19, 2025 at 7:56 AM
    #9744
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I purchased their bi-metal bandsaw blades (18T) and have used up two of them on my trailer build since I started. Each blade lasted quite a few cuts of 1/8 3/8 and 1/4" material.
    I observed some metal (I purchased) being cut off at the metal store on their big bandsaw and it wasn't noticeably faster than the HF bimetal blades on the HF Portaband. I cut the same pieces of metal 20min later so it was a decent comparison.
    The bandsaw setup has been great, I feel like it's already paid for itself and it has when I consider what the metal place charges per cut ($2.50)
    TacoSR523, Inyo_man, windsor and 2 others like this.
  5. Jan 23, 2025 at 7:39 AM
    #9745
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Doing sheet metal work on my car and decided to give the HF spot welder a try.
  6. Jan 24, 2025 at 3:25 PM
    #9746
    2ndhandTacoman
    Walter
    Maryland
    I have to say, HF customer service came through for me. Brown Santa's truck stopped in front of my house this afternoon, the driver handled me the box with the new lock cylinder/key set. 20 minutes later I got the lock to function again. No more twisting the wooden dowel!
  7. Jan 28, 2025 at 3:45 AM
    #9747
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    Anyone here have the Icon T7? Is it worth the price? I'm really tempted to grab one today.
    koditten likes this.
  8. Jan 28, 2025 at 5:52 AM
    #9748
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm not sold on it. A TopDon or Launch unit is a little cheaper.
    The only advantage that I really see is this is wireless. I don't want wireless when graphing many sensors at once.
    If the price drops to under $400, I think it would be very attractive.
    herecomesace[QUOTED] likes this.
  9. Jan 28, 2025 at 6:35 PM
    #9749
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    It's back on sale (40 off), 1/27 - 2/9. "While supplies last" - lol
    Edit: picked this up and am loving it. No more x4 2x4’s used with the Arcan. This thing with the extension attached handles everything.
  10. Jan 31, 2025 at 3:10 PM
    #9750
    crashngiggles
    Jared
    So I just got the most peculiar voicemail from Harbor Freight. I was finally Able to order the brand-new Haul master trailer from Harbor freight a couple of weeks back and able to use a %15 coupon. Obviously with the trailer having a year and a half long birth before finally becoming real, I was really hoping that by ordering it might take a long time before it actually comes in due to not having a garage and it being winter so I would have to bring the parts and pieces into my basement.
    And the voicemail went as follows:
    yes this message is for Jared my name is Shauna calling from harbor freight. I’m calling to let you know that the item that you ordered has come in. Due to its heavy nature by just ask that you call the store and advance when you like to pick it up. Just to be sure that we have enough staff on hand as well as forklift operators so we can assist you with it being 700 lbs.
    What have I gotton myself into…….
  11. Jan 31, 2025 at 4:38 PM
    #9751
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    So ugh you pick it up yet? :thumbsup:
    jpereira2 likes this.
  12. Jan 31, 2025 at 4:44 PM
    #9752
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Your going to need a trailer to go get it:anonymous:
    tacoma_ca, la0d0g, TjBjornsen and 6 others like this.
  13. Jan 31, 2025 at 4:51 PM
    #9753
    koditten
    Kirk
    Central Michigan
    :rofl:
    crashngiggles likes this.
  14. Jan 31, 2025 at 5:27 PM
    #9754
    crashngiggles
    Jared
    33° outside and pour rain.......we shall see how long they can hold it :D
    w.adventures[QUOTED] likes this.
  15. Feb 1, 2025 at 10:52 AM
    #9755
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Got a no restriction 25% off coupon. Cool. I could use the 24gun safe. Coupon expires Tuesday. I am scheduled to move into a new house on Friday. Worked the phone, no HF store in my general area would let me buy it and pick it up later. Almost talked one nice young lady into it, but she balked. Now I get to move it again next weekend.
  16. Feb 4, 2025 at 9:43 PM
    #9756
    2ndhandTacoman
    Walter
    Maryland
    Does anyone have any experience with the Bauer rotary hammer?
    I'm eyeing this up for some upcoming demo in my house. I've given up trying to score a decent used rotary hammer on Market Place and I really can't justify the cost of a brand new Milwaukee or Bosch.
  17. Feb 4, 2025 at 9:53 PM
    #9757
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I bought a HF engine hoist in the 80's and I swear they sell almost the same one for damn near the same price these days. Not sure the value of that thought, but here we are.
  18. Feb 4, 2025 at 10:36 PM
    #9758
    TjBjornsen
    TjBjornsen Active Member
    I brought one home and my wife thought it was hysterical, and very cute.
    The Mngr at my store said nothing had caused such a commotion in ages. Said they were selling like a palate a week, and were still running out.
    I think they're a riot.
  19. Feb 5, 2025 at 8:49 AM
    #9759
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    I have one similar to this. I want to say its the Bauer line as I believe it to be red and black in color. it came in a nice hard plastic case. Maybe mine is an earlier version of this one? Anyhow, mine has done great for what I have asked of it. I hope this helps.
  20. Feb 27, 2025 at 8:13 AM
    #9760
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    If any of you are having lunch with Eric Smidt today can you please pitch the following ideas:
    1. Hotties in the Harbor - Design/sell a solid competitor to the market leading hair dryer (which has a $500 retail.) An Atlas battery powered option is a bonus.
    2. High-end home accessory - Design/sell a market leading vacuum. Leverage the 80v Atlas and trounce the competition. Sell a status symbol.
    3. Harbor around, find out (HAFO) - Allow 3rd parties to accept the Harbor Freight credit card via Harbor Freight Official dealers (resellers) program. Where are the tool trucks?
    4. Welcome our robotic overlords - Consider hobbyist level CNC machine offerings. Think Langmuir Systems on a budget or Cricut on steroids. Open source the application code/drivers. Continue growing your army of builders/nerds/makers/fans.
    5. Glow-up and drip slay - Where's the cool swag? Perhaps a collab with a fav work-wear brand. Please don't insist on HF colors only. Neutrals please or maybe 70s 'far out' colors, thanks.
    6. IPO - To the moon in an Icon, Bauer, Hercules, Pittsburgh, Predator built rocket. Go public, we'd like to own a small sliver.
    teamhypoxia, koditten and colinb17 like this.
