Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Aug 16, 2025 at 6:35 AM
    #9961
    PaintFadeParade
    PaintFadeParade Active Member
    Joe
    2010 Black Access Cab
    Anybody have any input/experience regarding Harbor Freight Daytona jack stands?
    I'm a bit torn between trying to pick up a set for $30 at the sale alongside either a Pittsburgh bottle jack or a Daytona hydraulic jack.
    Alternatively, there are Big Red 3 ton jack stands available from Home Depot for about $33, and those scored much better on a pretty thorough review video from ProjectFarm on Youtube.
    Daytona or Big Red? Bottle jack or hydraulic? Any advice?
  2. Aug 16, 2025 at 7:01 AM
    #9962
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    My Daytona 3 ton jack stands have been good but I've only had them for about 8 months, if I am getting under the car I do still put the removed wheels under the frame in case the jack stands fail. I had the 1.5 ton aluminum Daytona jack for about 4 years without issue till it died.
  3. Aug 16, 2025 at 7:03 AM
    #9963
    PaintFadeParade
    Joe
    Good to know! Definitely agree with you on the secondary means of support. Playing with fire otherwise.
  4. Aug 16, 2025 at 7:17 AM
    #9964
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    For the truck I ended up getting a set of their 6 ton stands. The height is a better match, I was always on the last rung of the 3 ton stands which felt a little sketchy. Extra weight rating is good peace of mind too
  5. Aug 16, 2025 at 7:18 AM
    #9965
    joeyv141
    New Jersey
    This is a good point, I already owned 6 ton ones for the tacoma height, the 3 ton ones are for the civic
    TACOTU3[QUOTED] likes this.
  6. Aug 16, 2025 at 7:35 AM
    #9966
    PaintFadeParade
    Joe
    I didn't know the 6 ton stands had better height, that really changes things. Not to mention the added safety margin.
    TACOTU3 likes this.
  7. Aug 16, 2025 at 7:43 AM
    #9967
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Bigger stands are the way to go, Have 12 tons for the front and 6 tons for the rear. Much less play in the stands when they are setup lower.
  8. Aug 16, 2025 at 8:40 AM
    #9968
    545
    545 Well-Known Member
    2015 Access Cab
    You’d probably be better suited with an oxy propane setup
    Dunno if you can convert the harbor freight set
  9. Aug 16, 2025 at 9:40 AM
    #9969
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I've used oxy/acetylene before, but never oxy/propane. What's the thought process behind using propane instead?
