Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Nov 25, 2016 at 7:25 AM
    #121
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    I've seen some DIY tear drop trailers made out of the HF 4x8 trailers. Many came out great. My wife and I have thought of doing one ourselves.
    I've always wondered about the welders from HF too. I've welded in school many, many years ago, but with oxy acetylene torches. So I consider myself a newb as well.
  2. Nov 25, 2016 at 7:45 AM
    #122
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I use their cutoff and grinding wheels. Never had a problem, but I also wear a full face mask and usually have a good work jacket on.
    They do have marine grade heat shrink. It comes in a plastic box with a bunch of different sizes. Though I usually run out of one size and buy that at napa while using the other sizes every now and then.
  3. Nov 25, 2016 at 7:53 AM
    #123
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I've used hundreds of their cutoff wheels and haven't had an issue with any of them.
    Also I used 20% on my 6 ton jacks, and have never been turned on on using it for anything. I'll have to read the print sometime. But if the jackstands are no good then that changed in the last 12 months.
    shakerhood and Markcal[OP] like this.
  4. Nov 25, 2016 at 10:52 AM
    #124
    windsor
    windsor Just a guy
    Homeless in Oregon
    I've been using a flux core welder for the last 6 years without major issue. Every now and then it skips on the feed, but that just takes loosening the spool retainer a little and it works fine after that. For heavy stuff, I pull out the Lincoln.
  5. Nov 25, 2016 at 11:10 AM
    #125
    vtdog
    vtdog Well-Known Member
    NH
    As long as it does not have a motor or engine their stuff is ok, not great, but ok
  6. Nov 25, 2016 at 11:15 AM
    #126
    windsor
    windsor Just a guy
    Homeless in Oregon
    I'm at 17 hours (including one 15 hour run) on my generator. Granted the first one had a broken motor mount when I unboxed it, the second blew up on first start. But, the third is working great.
    Cr47524, DustStorm4x4 and HawkShot99 like this.
  7. Nov 25, 2016 at 11:15 AM
    #127
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I used their impact sockets as well and can't beat the $20 price on them. So far they have held up just fine.
    I also have their rubber wheel chock, metal car ramp and used their 3 piece titanium coated step drill bits to drill out the holes on my frame for the rock sliders. I read people were having a hard time doing this and with drilling out pilot holes and using the jack method, a total of 8 holes was drilled with no issues and drill bit was still sharp after the last hole. I did use Wd-40 as lubricant while drilling as well.
  8. Nov 25, 2016 at 3:34 PM
    #128
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    They aren't bad but they wear out faster than better brands. Same with their flapper discs.
  9. Nov 25, 2016 at 3:36 PM
    #129
    T4RFTMFW
    Sure. But for the price (and for normal guy use) they work great.
    No legit production level equipment in that store.
    jowybyo likes this.
  10. Nov 25, 2016 at 3:38 PM
    #130
    jowybyo
    Joe
    Baltimore, MD
    No doubt.
  11. Nov 25, 2016 at 3:43 PM
    #131
    Justinlhc
    Justinlhc Not looking for a relationship
    I buy them because they're cheap and I don't care how fast they wear out at that price. I've actually had good luck with the flapper discs though. It's hit or miss I guess.
    I forgot I've got a brad nailer and staple gun that have worked great for me.
  12. Nov 25, 2016 at 3:50 PM
    #132
    jowybyo
    Joe
    Baltimore, MD
    I've found cheaper, better flappers discs for the shop @Mobtown Offroad. I love HF but not for flappers.
  13. Nov 25, 2016 at 3:57 PM
    #133
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Benchmark Abrasives for the win. They're cheaper than the ones from Harbor Freight and last 4-5 times longer.
    jowybyo[QUOTED] likes this.
  14. Nov 25, 2016 at 4:20 PM
    #134
    Markcal
    Markcal [OP] Well-Known Member
    One day I was checking out of HF and the sales associate said I should check out their online items, saying what they have in the store is only a fraction of the total items available.
    Has anyone ever order anything from HF and if you have what was your experience like and what items did you find there and not in the store?
  15. Nov 25, 2016 at 5:18 PM
    #135
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I have TONS of hand tools from there. Basically, keep it simple and you are good. No moving parts and they're not bad. Their toolboxes are actually pretty nice too.
    FJ2Tacoma likes this.
  16. Nov 25, 2016 at 5:24 PM
    #136
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    In a pinch you can even use there sockets as sinkers when you go fishing. Heck, if you lose one no big deal.
    DustStorm4x4, Evo1ve and Markcal[OP] like this.
  17. Nov 26, 2016 at 1:15 PM
    #137
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I have ordered from them online with no problems. Quick delivery (except one case where an item apparently was not in stock) and reasonable shipping charges. I don't recall anything on their website that is not in the store.
  18. Nov 26, 2016 at 4:02 PM
    #138
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Just picked up this little workbench. I need something for my garage at the moment. And if it sucks I'll put it in my basement storage area for small projects. Either way couldn't pass it up for $120.
    Once I get it put together I'll post some pics and review
    JPinFL and Markcal[OP] like this.
  19. Nov 26, 2016 at 4:07 PM
    #139
    T4RFTMFW
    Seen a few random reviews on that. Generally loved except for where the low quality materials were used in drawers and lower storage shelf.
    Cmurder likes this.
  20. Nov 26, 2016 at 4:39 PM
    #140
    Markcal
    A 4 star rating from 960 buyers = :thumbsup: (usually)
    Cmurder[QUOTED] likes this.
