Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Jul 14, 2017 at 9:19 AM
    #1601
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    I bought the 90. It was cheap and works, but doesnt make great welds. I just bought it like someone mentioned above to play with to see if i want to invest in a nice welder.
  2. Jul 14, 2017 at 10:45 AM
    #1602
    la0d0g
    running for the hills
    For crawling not hauling
    Um, who doesn't carry a knife every day?
    Does not compute.
    EatSleepTacos, Bebop and CurtB like this.
  3. Jul 14, 2017 at 10:45 AM
    #1603
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Please, do not use dielectric grease on the inside of any electrical connection. That is not what it is for.
  4. Jul 14, 2017 at 10:52 AM
    #1604
    la0d0g
    When I read that post I was wondering if I was doing something wrong...
  5. Jul 14, 2017 at 11:01 AM
    #1605
    Toyko Joe
    Toyko Joe Here for the pictures
    Dielectric grease is electrically insulating and does not break down when high voltage is applied. It is often applied to electrical connectors, particularly those containing rubber gaskets, as a means of lubricating and sealing rubber portions of the connector without arcing. :thumbsup:
  6. Jul 14, 2017 at 11:07 AM
    #1606
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Negative, when used to "pot" a crimp connector, or applied to other mechanically compressed connections like chassis grounds, it provides a protection against corrosion. The crimp and/or mechanical compression brings the metals into solid electrical connection and displaces the dielectric grease at those points...
    99TacoDriver likes this.
  7. Jul 14, 2017 at 11:19 AM
    #1607
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    well okay then....crimping a connector completely removes the grease. Sure it does. I'm not saying that the connection will fail, only that it is not a good clean connection.
  8. Jul 14, 2017 at 11:57 AM
    #1608
    Toyko Joe
    For a sure connection always use solder ;)
  9. Jul 14, 2017 at 12:06 PM
    #1609
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    I needed a gag gift for my sister. One drill for me ...then a free coupon gave my sister this fine electric fly swatter.
    Its no joke. I put batteries in it and it lit up a bug like a Florida bug light. I gave her a six pack of PBR with it.
    Toynado, stbear, Nickel and 2 others like this.
  10. Jul 14, 2017 at 12:46 PM
    #1610
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Did you try sticking your finger in it?
  11. Jul 14, 2017 at 12:53 PM
    #1611
    cliffyk
    Cliff
    Saint Augustine, FL
    OK, I'm sorry I know nothing about this sort of thing--it would of course be much better to have trapped pockets of air and air gap intrusions between the wire strands leading into the crimp...
    Justinlhc likes this.
  12. Jul 14, 2017 at 12:58 PM
    #1612
    Sand Shark
    Erich
    Phoenix, AZ
    Nope... a small screwdriver. there was a huge arc for 2 AA batteries.
  13. Jul 14, 2017 at 1:07 PM
    #1613
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have. It did not feel good.
    tomwil likes this.
  14. Jul 14, 2017 at 1:09 PM
    #1614
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Leading into the crimp is not in the crimp, where good clean copper is connected. I think we don't understand each other. @Jimmyh
  15. Jul 14, 2017 at 1:35 PM
    #1615
    cliffyk
    Cliff
    Saint Augustine, FL
    We may be talking at cross purposes. My feeling is that for many (most?) DIY automotive applications in which connections are often subjected to damp and wet environments the long term positive aspects of the grease's added protection from same, within the crimped connector, outweigh the relatively minor impact the grease might have on the electrical characteristics of the crimped junctures.
    In a more controlled environment bare metal to metal crimps would have a margin of superiority, however tucked up behind the bumper of a 4x4 powering the auxiliary lighting I'd still pot the crimps with dielectric grease, most of which in addition to their arc reduction properties also have excellent anti-corrosion properties.
    "Engineering is an endless series of compromises--making what you want from what you have, or what you can get."
    -Me- from an adjunct lecture ca. 1985 (one of my finer moments)
    A conductive grease would 110% be better--good luck find such a product as your FLAPS.
    Subway4X4 and Nickel like this.
  16. Jul 14, 2017 at 3:51 PM
    #1616
    la0d0g
    Reported for quoting yourself from an outside source.
  17. Jul 14, 2017 at 4:42 PM
    #1617
    cliffyk
    Cliff
    Saint Augustine, FL
    Whatever...
    Benzdriver81 and Subway4X4 like this.
  18. Jul 14, 2017 at 7:04 PM
    #1618
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Has anyone tried out a 23ga nailer from hf? They're pretty pricy so for 25$ thinking i might pick one up. Carpenter for a living but its such a rarely used gauge maybe save 75$
  19. Jul 14, 2017 at 7:08 PM
    #1619
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I hope you guys don't mind my opinion on this. I do not use dielectric grease on anything other than the rubber seals of connectors as it is intended. It doesn't aid the electrical connection at all and in many cases it will make it worse. I see people recommend using it on the Tacoma's loose connections as in the AC / heater blower connectors which are sloppy to begin with and the grease will only make it worse as it is an insulator.
    Cliff makes a good point about the corrosion in exposed areas. However if I felt I needed grease in a crimped butt splice etc I would apply it to the opening where the wire entered the splice After the crimp is completed. I'm not very comfortable doing that either as the grease will creep into the strands and make it easier for the wire to pull out of the crimp. I have seen happen this myself.
    What I would advise if you are really concerned about contaminates in a crimp connector is use a self fusing tape as in this: http://www.xtremetape.com/ This is what I use in environmentally exposed areas.
    https://www.youtube.com/watch?v=LoyRoBYGKPk
    Toynado and Nickel like this.
  20. Jul 14, 2017 at 11:26 PM
    #1620
    Glocker23
    Glocker23 Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Yup. Cordless. My bad. Great info. Thanks
