Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Oct 17, 2017 at 9:48 PM
    #1941
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    exactly!
  2. Oct 17, 2017 at 10:18 PM
    #1942
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    My experience with any of their bits or saw blades has not been favorable. They dull quickly and/or break easily. I have NOT purchased any from them in the last 10+ years so it's possible my experience is somewhat "out of date".
    Slvr14tacoma[QUOTED] likes this.
  3. Oct 17, 2017 at 10:21 PM
    #1943
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Thanks for input though ill let you guys know
  4. Oct 18, 2017 at 7:06 AM
    #1944
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Unless you're doing a lot of welding you might want to stick to the smaller spools. Last time I was in the local welding supply place I was about to buy a larger spool and the guy recommended the smaller one after I mentioned I wasn't getting as smooth a feed. They sell Millers and he pulled up this page to show me.
    Electrode Wire: Exposed to moisture in the air or environment, welding wire not used for a period of time can develop an oxide layer. If feeding or arc instability problems occur after changing wire, examine the spool to make sure the wire is in good condition. If you’re not planning on using a spool of wire immediately, make sure to store it in a plastic bag in a dry environment, preferably with small packages of desiccant.
    Wire feeding issues can affect performance; good welds require a consistent wire feed supply. One way to test if wire is feeding smoothly is to feed wire against a block of wood and watch for continuous smooth wire coil up, which implies there is no obstruction to wire feed. If the wire does not coil smoothly, there is a problem somewhere in the wire feed process.
    https://www.millerwelds.com/resources/article-library/troubleshooting-mig-before-and-after-you-weld
    Just something to keep in mind.
    Has anyone tried their OmniPro multiprocess welder yet? It looks like a cheap way to get a tig setup if you don't need to do heavy stuff.
    https://www.harborfreight.com/omnipro-220-multiprocess-welder-with-120240-volt-input-63621.html
    06Tacooo likes this.
  5. Oct 18, 2017 at 7:19 AM
    #1945
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    :censored::rofl::rofl::censored:
  6. Oct 24, 2017 at 4:02 PM
    #1946
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    MigMax215! :ballchain:
    excorcist likes this.
  7. Oct 24, 2017 at 4:14 PM
    #1947
    troopah43
    troopah43 Blood Taco
    Ben
    Ashland, OR
    Cheaply Built ‘05 DCSB SR5
    Toytec Boss CMC Chinese Light Bar (front & rear) Stereo Other cheap DIY mods
    I have one of their smaller socket sets, I bought it because my ‘real’ set was in storage. I’ve ended up using the HF set instead since then.
  8. Oct 24, 2017 at 4:52 PM
    #1948
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yeah, I saw that add. They are just dangling the carrot in front if me...bastards!
  9. Oct 26, 2017 at 9:25 PM
    #1949
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Anybody have any experience with the Bauer lineup? I'm looking at the $59.99 drill/driver to give as a gift. :D Lmao
  10. Nov 6, 2017 at 6:50 PM
    #1950
    CarolinaSport
    CarolinaSport Well-Known Member
    South Carolina
    2015 DCSB 4x4
    My Harbor Freight trailer has been awesome! Pulls smooth and straight no matter what I put in it.IMG_20171106_202707.jpg
    Crom and Bulldogs129 like this.
  11. Nov 6, 2017 at 7:05 PM
    #1951
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Do you guys know if HF sells replacement wheels for this? Mine lost the bearings on two of them.
  12. Nov 6, 2017 at 8:46 PM
    #1952
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I did end up buying the 8750 generator. I am still breaking it in but I do like it so far. We shall see how it holds up. I have heard very good things about the predator engines in general though.
  13. Nov 7, 2017 at 11:23 AM
    #1953
    Bulldogs129
    Malcolm
    Mississippi
    I’m rebuilding a 1978-9(not exactly sure) snapper riding mower. What’s the best tool for sanding, scraping, sand blasting and so on... how would y’all approach removing rust on the entire rig, mowing deck, frame, etc
  14. Nov 7, 2017 at 11:26 AM
    #1954
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do you have an air compressor?
  15. Nov 7, 2017 at 11:30 AM
    #1955
    Bulldogs129
    Malcolm
    Mississippi
    @EatSleepTacos
    I have a harbor freight special
  16. Nov 7, 2017 at 11:33 AM
    #1956
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If I were to attack it, I'd go with an air needle scaler, depending how bad it is, and also an angle grinder with a flap disc or wire wheel. Or something with a sand blaster, but you'd have to do it in smaller chunks because I doubt that air compressor could handle running 100% of the time.
    Bulldogs129[QUOTED] likes this.
  17. Nov 7, 2017 at 11:40 AM
    #1957
    Bulldogs129
    Malcolm
    Mississippi
    I’ll definitely p/u an air needle scaler.:hattip:
    Do you know much about the different sand blasters? There are a couple different media options - sand, beads, glass, shells...:notsure:
  18. Nov 7, 2017 at 11:41 AM
    #1958
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I haven't a freaking clue. Also keep in mind I've never done a project like that before, but that's just the route I'd take. Take that for what it's worth :D
  19. Nov 7, 2017 at 11:46 AM
    #1959
    koditten
    Kirk
    Central Michigan
    I tried the HF blaster. It was a pain. It lives in my scrap pile.
    Take the mower to someone that does blasting. It will be cheaper and quicker.
    Bulldogs129 likes this.
  20. Nov 7, 2017 at 12:03 PM
    #1960
    Bulldogs129
    Malcolm
    Mississippi
    That’s probably not a bad idea, I’ll call around and price it.
    EatSleepTacos likes this.
